 A/C only cool properly at high RPM's
2 posters
Marine1966
A/C only cool properly at high RPM's   Empty
PostSubject: A/C only cool properly at high RPM's    A/C only cool properly at high RPM's   EmptySat Aug 09, 2014 12:01 pm
Greetings..I am new to this site and is the proud owner of three Riviera's. I own two 95's and a 98..all supercharged.
One of the 95 and the 98 do not cool properly while idle. Your suggestions and or experiences are appreciated.
billfrank85
PostSubject: Re: A/C only cool properly at high RPM's    A/C only cool properly at high RPM's   EmptySat Aug 09, 2014 5:22 pm
Look into automatically adjusting orifice tubes. They make the A/C perform better at low speeds/idle by stabilizing the balance between high/low pressure more efficiently. Rockauto sells them for the Riviera.
Marine1966
PostSubject: Re: A/C only cool properly at high RPM's    A/C only cool properly at high RPM's   EmptySun Aug 10, 2014 10:43 am
[quote="billfrank85"]Look into automatically adjusting orifice tubes. They make the A/C perform better at low speeds/idle by stabilizing the balance between high/low pressure more efficiently. Rockauto sells them for the Riviera.[/quote
Thanks for your reply.. I shall ASAP have this done and give you some feed back.
» High RPMs but no power!!
» ac compresser , RPMS, pass Vents
» how to turn car off properly
» FAQ: Side Mirror Problems (heated, auto-dimming, tilt)
» So my asshole buddy cant close a door properly.
