 FAQ: Engine Oil - What type and change intervals?
95rivy
florence_x
Sweepspear
KillaKeninaRiv
TheNewEra95
97rivsc
EASHER
zombiesarebad
Ironclad-454
98RiviSC
duster_do_little
riviera2454
96rivgirlla
manofmany
captshiner
dboy
98RIV7777
97rivman
GothicVash
HirohataMerc
dan
TType_Riviera
SilveR
urbsnspices
lionfish
SilverArrow102
SoCal Riv
robertwolf86
97Ultra
NO 4 EVR
62 posters
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10
rivren
Name : Ren Bortignon
FAQ: Engine Oil - What type and change intervals? - Page 10 Empty
PostSubject: How do I Send You Photos   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptySat Jun 19, 2010 10:18 pm
AA: You wanted to see photos of my car plus the TDM bypass module. How do I get them to you? I need your email address. Rivren
PostSubject: Re: FAQ: Engine Oil - What type and change intervals?   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptySat Jun 19, 2010 10:39 pm
florence_x wrote:
What are you going to flush? The crankcase? I would not recommend it. What makes you think it needs to be flushed?
Yeah, the crankcase. I'm sure the engine (inside) is probably filthy. I'm not sure when the last time my dad (previous owner) had the oil changed on it before I took over the title, especially since there were battery issues prior to my owning her. And I doubt it's ever been seriously cleaned on its inside parts since he bought her so many years ago.
Basically, I just want to start taking better care of the car, especially now that she is getting up there in mileage. I really think a thorough cleaning would help her perform better, though she runs fine as it is.
I'm assuming the "flush" is something similar to like a Seafoam product, that I would only need to do once every 10k miles or so? Unless I'm totally confusing what everyone here means by a flush during the oil change.
sorry this is a month behind....
If the motor sludge is gritty/holds grit then it probably pays to flush it out.
If you open the oil cap and the valve train (what you can see of it) looks pretty clean, maybe you don't want to have a sense of urgency for that motor flush.
I've not flushed the motor in my Riv, and currently don't plan to.
PostSubject: Re: FAQ: Engine Oil - What type and change intervals?   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptyWed Aug 11, 2010 5:22 pm
I've noticed Mobil Clean 5000 conventional "Performance Motor Oil" is usually on sale at AutoZone. At $9.99 for a 5+ quart jug, it's hard to resist. I've used it 3 times so far, at 3000 mile intervals.
FAQ: Engine Oil - What type and change intervals? - Page 10 Image
Features:
• 16 percent more cleaning agents than our conventional oil, extra cleaning power helps your engine run cleaner than with other conventional oils — even with today’s longer oil change intervals.
• extra cleaning performance to help prevent the formation of sludge and harmful deposits.
• guaranteed to provide excellent performance and protection for all car engines for up to 5,000 miles or six months, whichever comes first.
• meets key industry and OEM requirements. Designed to exceed most engine warranty requirements.
• official lubricants of NASCAR.
PostSubject: Re: FAQ: Engine Oil - What type and change intervals?   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptyWed Aug 11, 2010 5:31 pm
I've seen that too. i normally pick up a qt or so at walmart when i need to top off a car. it's super cheap...make you wonder though.
Mobil 1 synthetic is one of the most expensive oils (and other products) out there, why is their dyno-oil dirt cheap?
Anyone seen a reputable test pitting it against the others like castrol, or penzoil's dyno stuff?
FAQ: Engine Oil - What type and change intervals? - Page 10 Dsc_0110
Merit : 104
PostSubject: Re: FAQ: Engine Oil - What type and change intervals?   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptyThu Aug 12, 2010 12:17 am
Well, even if it is just another dino-oil, 3,000 miles is fine... When I've used syn-blend or full-syn, I still change it at 2/3 of the rated mileage.
PostSubject: Re: FAQ: Engine Oil - What type and change intervals?   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptyThu Mar 08, 2012 1:51 am
What will CA think of next?
http://articles.latimes.com/2011/dec/15/business/la-fi-autos-oil-change-20111215
werdstrave
werdstrave
PostSubject: temp   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptyTue Mar 20, 2012 12:19 pm
Just out of curiosity. I heard through the grape vine that switching over to synthetic oil on my aged vehicle might not be a good thing. I'd like to hear it from you guys though. I've been running conventional oil for the car's entire life. Should I switch or not?
Merit : 149
PostSubject: Re: FAQ: Engine Oil - What type and change intervals?   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptyTue Mar 20, 2012 4:21 pm
You MIGHT develop some seepage or a leak, maybe. I started running Amsoil full synthetic oil in my Riviera when I bought it in 2004 with 86, 000 miles on it. Never a problem. I change it every 6 months. By law, all motor oils must be compatible. You can mix it with conventional oil, and switch back anytime you like.
werdstrave
werdstrave
PostSubject: Re: FAQ: Engine Oil - What type and change intervals?   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptyTue Mar 20, 2012 8:36 pm
Yes I was warned against the seepage.
PostSubject: Oil 5w30 synth? 10w30?   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptySat Jun 07, 2014 11:40 pm
What oil are you guys running right now? I am at like ~160k miles on my Riv. How will 5w30 full synth be for it? 10w30 full synth? 10w30 dino?
PostSubject: Re: FAQ: Engine Oil - What type and change intervals?   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptySat Jun 07, 2014 11:53 pm
10w30 dino (valvoline mostly) took my Riv to 246k miles with plenty of high revving. As you know the failure was not oil-related. Bill said the cylinder bores were perfect, so my rebuilt engine now gets the same treatment.
PostSubject: Re: FAQ: Engine Oil - What type and change intervals?   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptySun Jun 08, 2014 12:06 am
Hey, it all worked out for the best, you got a rebuilt engine.  cool
I have been considering getting all the parts for the xp cam and have Bill use them for a build and have him do the swap. Would there be any benefit in doing this though? Would I achieve any gains from a fresh built engine compared to my ~160k block?
PostSubject: Re: FAQ: Engine Oil - What type and change intervals?   FAQ: Engine Oil - What type and change intervals? - Page 10 EmptySun Jun 08, 2014 12:23 am
After the rebuild, I noticed an improvement in throttle response from a roll. This was due to increased compression from the new rings, and the cleaned valves/seals. It just pulls harder and more abruptly when you put your foot down. Cleaning the intake plumbing also didn't hurt.
To know how much improvement you'll see, do a compression check. 130-140 psi is what I've read for stock bottom end. If you're low, then a rebuild will give you some power. If not, then not so much. Another way to know your rings are leaking is if you noticed a quart or more of oil being burned (not leaking) between changes.
Page 10 of 10Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10
» Knocking Sound?
» OH NO... Got my oil change.......SOLVED
» Write-Up: Changing Supercharger Oil
» Write Up: Transmission Fluid & Filter Change
» SUPERCHARGER OIL CHANGE
