 Write-Up: Modified Air Box CAI
EASHER
12 posters
Write-Up: Modified Air Box CAI Empty
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyFri Jul 27, 2007 2:02 pm
my work so far...
Ive cut the intake hole about 40% or so larger:
Write-Up: Modified Air Box CAI 2003003683245840516_th
Write-Up: Modified Air Box CAI 2003073517830413122_th
i cut a little more closer to the fender but didnt take another shot.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyFri Jul 27, 2007 2:19 pm
you can see the extra cut from the bottom view. no, ive never used a metal cutting saw until now.
Write-Up: Modified Air Box CAI 2006182925532623008_th
and from the top - still waiting for replacement intake but thats next. like that duct tape? lol, talk about heat trap.
Write-Up: Modified Air Box CAI 2006130218423130242_th
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyFri Jul 27, 2007 2:57 pm
Cool, so you just removed the bottom half of your stock air box and kept the panel? That's a great idea!
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyFri Jul 27, 2007 3:09 pm
i cut the box bottom to match the cut panel...surprisingly, 1st try was pretty close. about as much surface are you can get exposed on a panel filter.
Merit : 66
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyFri Jul 27, 2007 3:24 pm
awesome. Probably not measurably worse than a FWI. I say keep it.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyFri Jul 27, 2007 6:56 pm
Looks nice. Came up with a new idea that maybe someone can use that doesn't want to do a true FWI. Or can't find the right fitting pipes for.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyFri Jul 27, 2007 7:34 pm
Going a step further, you could build another box around the existing stock air box if there is room. It would act as a heat shield, the trapped air between the boxes acting as an insulator. Air is better than most solid materials at blocking heat transfer.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyTue Jul 31, 2007 11:29 am
in the following pics, I am simply wrapping up the intake tube in reflectix. I just used zip ties. They dont look pretty, but cosmetics on the motor dont interest me....only performance. And zipties hold great even in the heat.
in the first one, I just sprayed it down with engine detailer...not for appearance as it will be covered...only to help protect it from cracking like my last one...and everything else rubber in the engine bay.
Write-Up: Modified Air Box CAI 2005060426909006927_th
Write-Up: Modified Air Box CAI 2005063586032340986_th
continued...
Write-Up: Modified Air Box CAI 2005045900472046225_th
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyTue Jul 31, 2007 11:30 am
the last 2 are installed.
Write-Up: Modified Air Box CAI 2005029295913382741_th
Write-Up: Modified Air Box CAI 2005015692413638759_th
i may go back and secure it more, or maybe just do a true CAI in the future...but i'll be the odd man out on intakes and try my idea for now.
also got a compressor write up on the way and gauge installations for mech oil pressure and elec. fuel pressure installs.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyTue Jul 31, 2007 12:18 pm
Would be a good idea to take some IAT and MAF readings at various temps and driving speeds to compare to those of a true someone with CAI or FWI. You may have found something better here. Nice work!
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyTue Jul 31, 2007 9:52 pm
i can only scan with my inconvenient PT, and it reads in Celcius. Know how to change that? But I got an aeroforce on the way so I can get some more accurate IAT readings. But that will take a week or more to arrive according to the vendor.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyWed Aug 01, 2007 8:22 am
I'll show you mine if you show me yours!
Merit : 66
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyWed Aug 01, 2007 8:50 am
why don't you just post it in celsius? You could always convert it after.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyWed Aug 01, 2007 9:04 am
Converting ºC would be better anyways so we can compare apples to apples - scanners show what the PCM sees, not sure how the aeroforce gauge works. Maybe it uses the PCM's numbers too?
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyWed Aug 01, 2007 9:11 am
The aeroforce hooks up to the OBDII too. Shows the same numbers just not as many paramaters I don't think.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyWed Aug 01, 2007 9:45 am
Cool, good to know.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyWed Aug 01, 2007 6:06 pm
i was getting mid-hi 40's C I think last time I scanned with the old cracked intake setup and no insulation.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyThu Aug 23, 2007 12:18 am
I'm a little confused about this mod.
You cut the intake hole larger with a metal-cutting saw, I see that.
But then, do you just bolt the bottom of your stock airbox back in there, or what?
That's the confusing part. Do you have to modify the bottom part?
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptySat Aug 25, 2007 3:41 pm
naw, the box is really just lying there. The intake tube puts enough pressure on the box to hold it in there. There is one bolt holding the box in I think.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptySat Aug 25, 2007 5:43 pm
Theres 2 bolts holding the box in. Both are different types.
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptySat Sep 01, 2007 1:34 pm
well, there was 2 holding in my box, but I kinda tore one out and didnt bother fixing/replacing it.
PostSubject: Stealth FWI   Write-Up: Modified Air Box CAI EmptyFri Oct 17, 2008 10:59 am
I am considering an Idea that I will call the Stealth FWI. I have already gutted my airbox, but now I am considering mounting a filter in the fender well and removing the one in my air box. The cone filter would be in the fenderwell, but intake would be thru the original airbox and hose thus it would look stock with the hood up... OK, you guys have more knowledge than I ... would I gain anything by doing this? scratch
PostSubject: Re: Write-Up: Modified Air Box CAI   Write-Up: Modified Air Box CAI EmptyFri Oct 17, 2008 11:04 am
Sounds Kool If you are trying to fool people into thinking your stock
http://www.Chitownracing.com
EASHER
EASHER
Name : ERIK M. ASHER
PostSubject: LOVE THE SLEEPER STOCK LOOKING IDEA!!!!   Write-Up: Modified Air Box CAI EmptyFri Nov 07, 2008 9:43 am
I think I will follow your lead and install a cone filter in the f/w, remove the stock air filter and keep the airbox and stock air tube in place.
You don't even have to relocate the IAT since the box remains in the car.
Where did you get the insulation wrap for the box and tube?
I am willing to bet it works as well as some of these fwi setups others have done.
http://snardfarker.ning.com/profile/ERIKMASHER
» Cams & Rockers
» ZZP 1.9:1 Ratio Modified Rockers
» Write-Up: Front & Rear Bumper Modification
» Write-Up: Inner Tie Rods
» Write-Up: Custom CAI
