Two Rivs, no waiting Special
Name : Edward H. Joined : 2024-04-10 Post Count : 9 Merit : 1
![3800 gm crank angle relearn Empty](https://2img.net/i/empty.gif) | Subject: 3800 gm crank angle relearn Thu Jun 06, 2024 9:46 am | |
| Any advice on the "crank angle relearn" procedure? This question is not specific to my Riv, as I have a Park Avenue that I will be replacing the Powertrain Control Module. Thanks. | |
![Eldo](https://2img.net/u/3215/30/10/37/avatars/842-2.jpg)
Name : Mark Age : 59 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3170 Merit : 104
![3800 gm crank angle relearn Empty](https://2img.net/i/empty.gif) | Subject: Re: 3800 gm crank angle relearn Fri Jun 07, 2024 8:08 am | |
| - Two Rivs, no waiting wrote:
- Any advice on the "crank angle relearn" procedure?
This question is not specific to my Riv, as I have a Park Avenue that I will be replacing the Powertrain Control Module. Thanks. I have the FSM procedure, but it requires the GM Tech II scanner/programmer... Do you have anything similar? | |
![3800 gm crank angle relearn Empty](https://2img.net/i/empty.gif) | Subject: Re: 3800 gm crank angle relearn Sun Jun 09, 2024 12:38 pm | |
| I have the OTC monitor 4000 scanner, which is a year older than the car. I can not find anything in the manual for this scanner that lists the procedure. Some place I read about a series of specific directions to reset the ECM while driving. I can't find where I put this info. | |
![albertj](https://2img.net/u/3215/30/10/37/avatars/149-76.gif)
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8676 Merit : 181
![3800 gm crank angle relearn Empty](https://2img.net/i/empty.gif) | Subject: Re: 3800 gm crank angle relearn Sun Jun 09, 2024 3:37 pm | |
- I have the OTC monitor 4000 scanner, which is a year older than the car.
I can not find anything in the manual for this scanner that lists the procedure. Some place I read about a series of specific directions to reset the ECM while driving. I can't find where I put this info. Directions to do the relearn without a Tech II are in the service manual. If you can get your hands on a Tech II the following should help https://www.gmforum.com/howto/1998SM/computer%20relearn%20procedures.pdf There is also this for a relearn without scanner - I think this next post is (in general) the scannerless procedure in the manual, BUT you really need to refer to the PA manual: https://www.totalcardiagnostics.com/support/Knowledgebase/Article/View/99/0/crank-relearn-instructions-with-and-without-an-obd-scannerreader | |
![3800 gm crank angle relearn Empty](https://2img.net/i/empty.gif) | Subject: Re: 3800 gm crank angle relearn ![3800 gm crank angle relearn Empty](https://2img.net/i/empty.gif) | |
