| FAQ: Dexcool / Coolant / Antifreeze Types | |
+36Ironclad-454 Ship BKRIV Eldo Chicken Jack the R manofmany Rickw maggot albertj deekster_caddy ibmoses 98RIV7777 98riv Buapo T Riley steve1173 robotennis61 97Ultra xxsupergman25xx BillBoost37 TType_Riviera palermocorey90 turtleman rivieraman Jason 97rivman 1998 Riv arttu80 NO 4 EVR racinfan Brad95Riv 96riv AA Mr.Riviera ¤DoughBoy¤ 40 posters |
¤DoughBoy¤ Enthusiast
Name : D.J. Age : 36 Location : Gary Indiana Joined : 2007-02-10 Post Count : 219 Merit : 0
 | Subject: FAQ: Dexcool / Coolant / Antifreeze Types Mon Jun 25, 2007 4:26 pm | |
| Whats The Best Recommendation.........Or is there only one brand to use? | |
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Mon Jun 25, 2007 4:43 pm | |
| i use gm dex-cool with a bottle of water wetter addative and a 180* t-stat. works well for me in the FL heat. dont get the cheap off name stuff and you will be fine. i think i used prestone brand. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Mon Jun 25, 2007 6:15 pm | |
| Thanks for your reply..........
But I was reading the manual and it said to use a special type that doe'snt burn allumium........and it got me thinking........i did'nt want to get the wrong brand........ | |
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Mon Jun 25, 2007 6:17 pm | |
| How much does Dex-cool cost anyone? | |
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Mon Jun 25, 2007 6:41 pm | |
| It's the pink stuff, there are a few different brands of Dex-Cool. It's pretty cheap right now, can get at any gas station or auto parts store. If you haven't changed the coolant in a while, consider a flush. Sears does it for about $60 (coolant included). _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Mon Jun 25, 2007 6:49 pm | |
| a non diluted btl of dex runs about $9 at autozone. figre using 2 of them and a bucket to catch the old stuff plus the mess and trouble...$60 aint bad! _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
96riv Fanatic
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Mon Jun 25, 2007 9:35 pm | |
| 8 oz RMI 25 plus water in the summer or non freeze states. When I blew a head gasket into my intake I drove for 25 miles and had no bearing damage or any internal problems. You can also add the RMI to antifreeze.
http://arizonagn.net/how_to.htm | |
Brad95Riv Member
Name : Brad Age : 43 Location : Wisconsin Joined : 2007-01-18 Post Count : 97 Merit : 0
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Tue Jun 26, 2007 7:52 am | |
| From the factory, I don't think Dexcool came into play until '96. Are you doing a total flush, or just adding some? | |
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Tue Jul 17, 2007 4:42 am | |
| Just adding some.........I think I'm going to get a flush this weekend tho! | |
racinfan Addict
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Tue Jul 17, 2007 11:24 pm | |
| Dexcool started in '95. If you're just adding some coolant temporarily throw water in there. | |
NO 4 EVR Addict
Name : Troy Age : 37 Location : Sylvania, OH (Toledo) Joined : 2007-01-26 Post Count : 645 Merit : 1
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Wed Jul 18, 2007 6:04 am | |
| Isnt there a big argument on which type of coolant is better, dex cool or the green stuff? I think you can use the green stuff if you flush out all the dex. But IIRC if you mix the two coolants than $h!† gets messed up. | |
arttu80 Member
Age : 43 Location : Finland Joined : 2007-08-02 Post Count : 80 Merit : 8
 | Subject: GM Dexcool Fri Aug 10, 2007 2:49 pm | |
| Hello there you fine people! I'm going to drive bout 500miles tomorrow but our 97 Riv is in desperate need of additional coolant.... Can you please tell me, can I add pure water to this Dexcool without breaking anything?!? I live in Finland and in small town, so its impossible to aquire Dexcool anyway.  | |
Name : Dave Age : 62 Location : In The AZ Oven Joined : 2007-01-17 Post Count : 4502 Merit : 44
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 2:56 pm | |
| You should be safe adding water, but it should not be tap water, use distilled water from the store. How much are you thinking you'll need to add? Did you overheat? | |
97rivman Fanatic
Name : alex Age : 37 Location : Crete,IL Joined : 2007-06-09 Post Count : 484 Merit : 2
| as a last resort, yeah, May I suggest bringing a couple extra bottles of "DISTILLED" water along with you. | |
arttu80 Member
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 3:03 pm | |
| Oh wow, some quick reply!
Well I can add distilled water, but is it mandatory? We drink water which is from faucet, so its clean enough I guess? God damn I kick myself I didnt order Dexcool! | |
| Water works fine as long as it doesn't freeze. Distilled is preferred because it doesn't have metallic particles that can corrode passageways. For a short time, you could get away with clean tap water, imo.
At the race track nearby, in order to race, you must drain all of your coolant and replace with 100% H2O. Good luck on your journey for Dexcool! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
arttu80 Member
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 3:10 pm | |
| Oh yea did I mention I'm not driving 500miles for a Dexcool I'm driving to Drag Race event and to swim in ocean...But thanks guys for a help!!! | |
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 3:18 pm | |
At the race track nearby, in order to race, you must drain all of your coolant and replace with 100% H2O. Good luck on your journey for Dexcool! Is that being required for Street Legal events too? What a PITA if it is. For true race cars though, water-only makes complete sense and is very commonly done. | |
97rivman Fanatic
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 3:22 pm | |
| The tap water where I live will rust a hole through Stainless.......Thats why I reccomend distilled. | |
arttu80 Member
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 3:31 pm | |
| Will rust stainless, hah! Is there better alternatives to Dexcool or should I stick with it when it's time to change coolant? | |
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 3:35 pm | |
| i have 140k Dexcool miles with original radiator, hoses, water pump, and engine. Still running nice and cool!
Dave, the track I'm referring to is a closed road course in northern Ohio, not a drag strip. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^
97rivman Fanatic
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 3:41 pm | |
| - arttu80 wrote:
- Will rust stainless, hah!
Is there better alternatives to Dexcool or should I stick with it when it's time to change coolant? no, seriously, the water around here is that bad!!!! A gallon of water looks like a manilla folder. When we first open the hose valve outside after winter, it just pours out rust. we have reverse osmosis for drinking water. | |
arttu80 Member
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 3:42 pm | |
| Mine have 230k kilometers which is quite close to 145k miles, so Im concerned cause of -20 F freezing we have here sometimes in winter...
http://kuvablogi.com/nayta/iso/img566109.jpg | |
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 4:28 pm | |
| You will want to be sure your coolant mix is appropriate before you see freezing temps again. How cold does it get this time of year? | |
arttu80 Member
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types Fri Aug 10, 2007 4:41 pm | |
| Actually its hot right now, cause its 75F at daytime so coolant isnt so important right now but I mean its December someday and then it must be up to task you know! | |
 | Subject: Re: FAQ: Dexcool / Coolant / Antifreeze Types  | |
