 FAQ: Where to install the IAT (Intake Air Temperature) sensor...
BillBoost37
14 posters
FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 Empty
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptyThu Jun 20, 2013 9:58 pm
It's a bayonet mount. Twist it.
Either I'm a wussy or this thing is jb welded in. There's black goop around the seal point. I will twist harder and see what happens.
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptyFri Jun 21, 2013 2:30 am
I tried all manner of things to get the dang thing out when I was ditching the stock box. Ended up having to just more or less cut it out of its mount. Was crazy stuck in there
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptyFri Jun 21, 2013 8:45 am
That's what I'm afraid of... I really dont want to have to cut it out.
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptyFri Jun 21, 2013 9:28 am
Here's what the airbox looks like after the IAT sensor is removed. You can see the two slots that engage the bayonet tabs:
FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 Airbox
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptyFri Jun 21, 2013 9:31 am
Thanks, AA. Looks similar on mine except for the plastic weld around the seal. I am prepping for my 4" intake so I wanna make sure I can get the sensor out clean first.
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptyFri Jun 21, 2013 10:01 am
If you damage it, I think I have my original listed in the for sale section. If you're going to the trouble of sourcing cooler air, I would suggest not using the OEM sensor, which is much slower to react than an OMEGA Mil-spec type ($15).
https://rivperformance.editboard.com/t8404-write-up-omega-intake-air-temperature-sensor-iat
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptyFri Jun 21, 2013 11:12 am
I always left my IAT dangling down in my FWI hole.. LOL happy
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptyFri Jun 21, 2013 11:15 am
That works! No heat sink!
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptyFri Jun 21, 2013 11:22 am
My shit was super Sloppy. But it worked VERY well lol
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptySun Jul 14, 2013 10:30 am
Why do we try to get our IAT sensor as close to the filter as possible and Intense gets it right up by the throttle body?
They are smarter than we are, right?
FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 Fwi_bottom_small_nt
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptySun Jul 14, 2013 10:54 am
If you put it near the filter, it gets the coldest temperature possible your car is getting. If you put it near the throttle body, you get the ACTUAL temperature that's going into your engine. It probably isn't more than a couple of degree difference, but it is probably better to put it there.
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptySun Jul 14, 2013 11:01 am
I dont think I've seen anyone here make a FWI and put the IAT sensor by the TB. Just curious..
On the stock setup, the IAT is closer to the filter than the TB. So, what gives? GM engineering > intense engineering. Right?
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptySun Jul 14, 2013 11:03 am
It's hard to say. Why don't you test the 2 locations and report back? Let us know of anything you find.
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptySun Jul 14, 2013 11:07 am
I plan on sticking to my original design and keeping the IAT in the engine bay but as close to the filter as possible. As close to the OEM setup as possible. Sorry, Intense, but I dont like that TB IAT idea.
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptySun Jul 14, 2013 11:22 am
I like to keep my IAT in the fenderwell with myfilter so I know what temperatures the filter is actually pulling in. All you can really do is try to pull in the coldest air possible, so thats the temp I like to be able to see!
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptySun Jul 14, 2013 11:29 am
I stuck mine in the filter itself. When I had it outside my mileage dropped by about 1 or 2 MPG.
96_Juggernaut
96_Juggernaut
Name : Todd Balestrini
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptySun Jul 14, 2013 11:51 am
I would imagine that the IAT being closer to the throttle body would be better because the air temp could change several degrees between what the filter pulls in and what the engine actually receives. So I would think the IAT on the throttle body is a more realistic number.
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptySun Jul 14, 2013 12:56 pm
I have nothing to back this up, but, I have to believe the air temp in the filter is different than the the air temp entering the TB. Even if your sensor is telling the computer 80 degree air is coming in, but the engine is REALLY eating 86 degree air, then the engine isn't receiving accurate information.
I think that might be the worst place to put the IAT. So much residual heat will be soaked up in the housing your IAT sensor is mounted in that it might be telling the computer an even higher temperature than the air really is. It might be telling your computer you are getting 90 degree air when the engine is really pulling in 80.
96_Juggernaut
96_Juggernaut
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptySun Jul 14, 2013 1:02 pm
This is true... I might end up doing the Intense kit but without the extra $70 is cost to but the IAT near the throttle body. I'll probably use a slightly longer 3.5" metal collar and drill a hole in that to sneak the IAT in between the filter and the tubing.
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptySun Jul 14, 2013 6:27 pm
96_Juggernaut
96_Juggernaut
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptyMon Jul 15, 2013 10:27 pm
Are you suggesting the INTENSE FWI is a poor design? Sounds pretty lazy to put the IAT on the TB only so the OEM wiring will reach it. Why not include an extended wiring kit?
I haven't heard anything yet from INTENSE, but on the surface, this appears to be a simple marketing decision. Why not include the IAT extension? Because they can sell it for an extra $20: LINK
From the description:
"This 24 in plug-in harness extension allows you to relocate your Intake Air Temperature Sensor from the factory F-duct to a custom location of your choice. It is ideal for use with fenderwell intakes, cold air intakes, aftermarket air boxes, or timing modification devices that use the IAT signal for adjustment. 300 degree nylon convoluted tubing protects the wire from heat and weather and keeps your vehicle looking neat and clean. The engine end is heat-shrink wrapped for extra heat protection."
Look at what ZZP offers with their FWI kit (note position of IAT bung): LINK
Mandrell bent steel intake tube, silicone couplers, aluminum shroud, and and IAT extension. Price: $190
FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 Cold%20Air%20Intake%20fenderwell
INTENSE is positioning their product much lower at $100. Entirely different approach - bare minimum product with the cheaper flexible tubing, and not as many pieces - it's just not up to the level of ZZP's product. It's a classic case of "you get what you pay for", and there's nothing wrong with that. I think some people expect to get a lot for $100. But considering CAI intake kits for every other car in the universe start at $150 and go up past $300, I wouldn't expect much more from the INTENSE kit.
I also found this interesting. It appears INTENSE supports putting the IAT sensor near the TB: LINK
Do these ZZP Kits work on our cars? I'm ready to order one if there is a remote chance I can make it work.
PostSubject: Re: FAQ: Where to install the IAT (Intake Air Temperature) sensor...   FAQ: Where to install the IAT (Intake Air Temperature) sensor... - Page 3 EmptyMon Jul 15, 2013 11:21 pm
I know some of you on here are big metal workers. What would it cost to just have someone fab up a nice stainless pipe? It doesn't even have to go into the fenderwell, it can just have a blockoff plate like I have.
» Write-Up: Omega Intake Air Temperature Sensor (IAT)
» Cold Air Intake (CAI) vs Fender Well Intake (FWI)
» Coolant temperature sensor/sender
» Overheating? (bad coolant temperature sensor)
Riv Performance ::   General Tech :: Engine Bay-
