Anyone know the specs needed for ARP header bolts, to replace the OEM bolts? And what about the studs on the front side? I'm trying to recall how many used, and why... One stud holds the dipstick tube bracket?? One stud holds the eng lift bracket?? Sound right? I removed the lift bracket, and I suppose the dipstick tube doesn't NEED to be bolted on... unless the bracket can be bent a bit to attach with a bolt instead of a stud.
I'm trying to source ARP ss bolts in a 6 qty. Intense now offers 12 or 6, but you pay a 20% premium per bolt to buy 6. ZZP doesn't offer them, but would if they knew the specs.
