 alignement specs for performance driving
johnd89
alignement specs for performance driving Empty
PostSubject: alignement specs for performance driving   alignement specs for performance driving EmptySat Nov 03, 2007 9:32 pm
Hi,
I know I cannot adjust the caster on the rear on my '95, but what would be the values for a performance oriented drive (given that I have stock a suspension). The spec for the front caster is +5.5 deg, + or - .1 I was thinking that springs this old should have some sag allready, so this may be allready taken care of?
Any advice is welcome!
» FAQ: Wheel & Tire, Lug, Bolt Pattern, Offset, Center Bore Info
» what is stock cam specs for 95 riv
» torque specs
» 4-wheel alignment specs?
» Crank Sensor/Torque Specs
