Fastfrankie Amateur
| Subject: Crank Sensor/Torque Specs Tue Oct 30, 2007 12:52 pm | |
| What is the torque spec on the harmonic balancer bolt? Any tips or areas showing how to remove/replace the sensor? I should be ok but would like to see some pictures. I have the puller and bolts...but I definitely need the torque spec for sure! on the crank bolt | |
Sag Enthusiast
Name : Martin Age : 42 Location : St- calixte Qc Joined : 2007-10-26 Post Count : 166 Merit : 0
| Subject: Re: Crank Sensor/Torque Specs Tue Oct 30, 2007 1:40 pm | |
| I dunnow but there is a trick when you reinstal a damper,in general,put in in hot wather for 5-10min it expand and is a lot easier to reinstall good luck | |
| Subject: Re: Crank Sensor/Torque Specs Tue Oct 30, 2007 5:07 pm | |
| i believe it is a TTY bolt and you are suposed to get a new one from the dealer. as far as pics? there was a nice write up on clubgp but i cant seem to find it now. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
TType_Riviera Fanatic
| Subject: Re: Crank Sensor/Torque Specs Wed Oct 31, 2007 8:50 pm | |
| http://store.summitracing.com/partdetail.asp?part=ARP%2D120%2D2501&autoview=sku
ARP makes a replacement bolt... | |
| Subject: Re: Crank Sensor/Torque Specs | |
