JT Newman Amateur
Name : Jari Age : 42 Location : Tampere, Finland Joined : 2009-10-05 Post Count : 38 Merit : 0
| Subject: 4-wheel alignment specs? Sun Oct 18, 2009 10:56 am | |
| What are toe-in/out, camber etc. specs for -96 Riviera?
Passenger side rear wheel has worn out very bad from inside and handling on snow is awful. Repair shop doesn't have specs for Riviera, so I'd appreciate any help.
Thanks in advance! | |
99Rivman Aficionado
| Subject: Re: 4-wheel alignment specs? Sun Oct 18, 2009 11:13 am | |
| This is what the '95 Service Manual has: HTH | |
JT Newman Amateur
| Subject: Re: 4-wheel alignment specs? Tue Oct 20, 2009 1:10 pm | |
| Thank you very much! Handling is now better, although mechanic wasn't able to adjust rear axle fully to specs. | |
| Subject: Re: 4-wheel alignment specs? Tue Oct 20, 2009 2:03 pm | |
| Sounds like a trailing arm got bent somewhere along the way... | |
| Subject: Re: 4-wheel alignment specs? | |
