palermocorey90 Expert
Name : Corey Age : 32 Location : Rome NY Joined : 2007-10-03 Post Count : 2968 Merit : -24
 | Subject: supercharing a non series 2 Sun Dec 02, 2007 6:27 pm | |
| can you do a supercharger on a non series 2 3800 ? | |
 | Subject: Re: supercharing a non series 2 Sun Dec 02, 2007 8:37 pm | |
| Do you mean adding a blower to an L27 Series I N/A? It would be a lot of work building up the inside for lower compression, and to be tough enough to handle boost. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: supercharing a non series 2 Sun Dec 02, 2007 9:00 pm | |
| no a series 2 out of like a bonnie or somthing that doesnt have a SC | |
 | Subject: Re: supercharing a non series 2 Sun Dec 02, 2007 9:52 pm | |
| Still have to change a lot. The parts in those engines aren't as strong as ours are, and compression is different, PCM, ignition, and fueling systems would need upgraded. Imo, better to install a turbo if going through all the trouble, but ZZP sells a conversion kit to add an M90 to N/A Series II. It takes a short-cut by running a bigger SC pulley (runs lower boost). A Regal GS ran mid 13s on this set-up, and I think its tranny died a couple months later: http://www.zzperformance.com/grand_prix/products1.php?id=382&catid=109_________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
BillBoost37 Junkie
Location : Enfield CT Joined : 2007-11-28 Post Count : 769 Merit : 25
 | Subject: Re: supercharing a non series 2 Mon Dec 03, 2007 6:00 am | |
| Sure, it's possible as mentioned. Practical is another thing. I know of a couple GP buddies that went to the L36 lower ends after blowing their L67's. In the end they said it is extremely tough to tune and overall they didn't trust the bottom ends to hold up w/o running overly large pullies.
I've also been in the situation where I considered it and overall it's not recommended. Pistons and rods are different. | |
 | Subject: Re: supercharing a non series 2  | |
