| Subject: Re: Oil leak...from where??? Tue Jul 15, 2014 8:32 am | |
| - IFallsRon wrote:
- I'm sure that my leak is under the plastic that covers the driver side of the pan.
That's the rear main seal up inside that plastic. It's either that, or a $12 paper gasket that's back there. Either way it requires the trans to be removed. Mine has been leaking for probably 8 years now from that spot. It's not nearly bad enough to need repair, but it definitely gets all wet between oil changes. | |
