 Should I replace my OEM thermostat?
curious riv
captshiner
EASHER
rivboy
lyonsperformance
manofmany
96riv
robertwolf86
NO 4 EVR
24 posters
Should I replace my OEM thermostat? - Page 3 Empty
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptySun Jan 01, 2012 4:09 pm
I installed a Stant 180* from napa (not sure which model #) when i first got my car 100,000miles ago. Still seems to be operating fine still.
Im not sure you would see any difference between any of them, especially since you didnt see much difference when yours was working vs stuck open.
However, from the pictures i would venture to guess some can flow better than other when open, though i dont know if even the worst one can underflow the WP and system at 15psi.
Should I replace my OEM thermostat? - Page 3 Dsc_0110
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptySun Jan 01, 2012 7:58 pm
Good point. Maybe I'm looking into it too much. I may just get another Stant (I think that's what I have now), or I might try a few and compare results.
One thing that's odd: some of the units (including RobertShaw) that I listed from Summit show they work for GM 3.8L/231cid V-6, but NOT after 1986. Anyone know what changed after '86 that would exclude later years? I found a clue at the turbobuicks board:
"Good news, sort of. Yes, the Robert Shaw/ Mr Gasket 330-160 thermostat can be cut down to fit the 86/87 motor. Bad news. It may not work very well.
I spent this afternoon playing around, and ground down the lip on a old RS 330-180 stat to 1 3/4", to fit inside the manifold. It fits really well. (And is still very solid)
Here is the problem: The body diameter (part that moves) of the stat is 1 9/16". The ID of the inner step of the manifold bore is 1 11/16". The wall thickness of the manifold casting where the stat seats is 1/4". The stroke of the stat is 3/8"
So since there is only 1/16 clearance between the stat body (part that moves) and the housing bore, not a lot of flow will happen until the stat is almost fully open. 1/4" of 3/8" stroke upon the initial opening, is restricted by the casting thickness, so that leaves 1/8" of unrestricted flow when the stat is fully open, kinda defeats the purpose."
Link: http://www.turbobuicks.com/forums/buick-v6-turbo-tech/5383-robert-shaw-thermostat.html
So at this point, I am starting to wonder: A) if the RobertShaw would even fit, and B) would it operate correctly? Does anyone have experience using one in a modern 3800 V-6?
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyMon Jan 02, 2012 10:36 pm
Where did you get the part number for the RobertShaw? They make thermostats for many applications. I'm sure they make one specifically for our 3800.
What happened in '86/'87? The end of the RWD 3.8 V6. The guys on turbobuicks.com are probably discussing the RWD 3.8. Not the Series I 3800, which was available in FWD form in the same era. (My mom's '86 Century 'vert had a 3800 with SPFI, pretty potent for a FWD car in it's day)
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyMon Jan 02, 2012 11:11 pm
I found the RobertShaw part number at Summit Racing, which is specifically for 3800 V-6, but not listed for any after 1986. Using that number to Google search, I found the thread at TurboBuick.com, where they talk about modifying the lip to fit the GN motor.
It got pretty cold today (23ºF), so I decided to get one from AutoZone again. Their best unit was the Motorad Fail-Safe for $12.00, which is better than the Amazon price listed above. I think, based on how my current one is stuck open, I may have purchased the same one last time. Guy at the counter said they only sell 3 brands: Duralast, Motorad, and Valuecraft. He recommend against Valuecraft.
Planning to install tomorrow evening. I will verify if the old unit is a Fail-Safe or not.
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptySun Jan 08, 2012 1:29 am
Turns out the older t-stat unit was a Motorad, but not the Fail-Safe type. Surprisingly, the unit had not failed. Instead I found the rubber o-ring seal had broken away in two spots, allowing coolant to flow around the t-stat. The points of failure correspond to locations of assembly/weld points, where the valve support attaches to the flat disc:
Should I replace my OEM thermostat? - Page 3 Tstatout
Should I replace my OEM thermostat? - Page 3 Seal
Technically, the price of the repair was only $2.99 for the failed seal - I installed the new Fail-Safe t-stat since already I bought it. Will keep the other as back-up.
Merit : 104
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyWed Jan 11, 2012 12:56 am
Aaron, where did you get the new stat-seal? I bought a couple from NAPA, and they were total garbage... They weighed about half as much as the old GM seal, and the edges looked like they had kids trying to cut circles out of rubber with scissors! So I just picked up a new stat from the dealer for $8 or $10, and the seal comes with it.
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyWed Jan 11, 2012 10:07 am
I'm not 100% sure, but I believe this is the OEM seal from GM. In my past t-stat swaps, I've never seen the need to change the seal until now. The new one is a Fel-Pro, sold through AutoZone as Duralast. Seems to fit just right.
Merit : 104
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyThu Jan 12, 2012 1:23 am
That may well be - I don't have AutoZone out here... and this IS the first time I've been disappointed by Napa.
I was surprised that I needed a new seal! In search of my 2MPG loss I decided (especially for winter) to put a new 195 stat in place of my drilled 180. (Turns out that neither injector-cleaner nor a hotter, undrilled stat made a difference on my round-trip to Clear Lake at Christmas.)
However, when I was swapping out the 180 stat, I found that the rubber seal had 'dimples' in it from, of all things, aluminum corrosion - corrosion that was only where the seal was pressed between the manifold and and outlet... scratch
In the last year, between stat, and hose, and radiator replacements, I've surely replaced all the coolant, but I guess I need to give it some of that extra Prestone additive mixture...
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyFri Feb 10, 2012 6:02 pm
Would the SLP thermostat on 3800performance.com fit the Riviera? It's not on the listing, but I wanted to make sure it was interchangeable before making the purchase. Thanks
http://www.3800performance.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=SLP-TSTATS&Category_Code=CSFS&Product_Count=1
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyFri Feb 10, 2012 6:06 pm
Yes, should fit, no problem. It's probably one of the ones listed above, so there is a mark-up on it.
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyFri Feb 10, 2012 7:05 pm
Alright thanks. I try to stick true to brand, so my thermostat will match my SLP headers. Haha I know its silly, but to each their own I guess.
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptySat Feb 11, 2012 12:14 am
Yes, it is silly, but it's your money. SLP sources their t-stats from Motorad. You can pay $15 + shipping, our get the same thing at Autozone for $5-10 less. FYI, AutoZone calls them Duralast - same product.
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptySat Feb 11, 2012 2:12 am
Oh I misunderstood you.. well if its the same part then yeah ill definitely go to autozone instead.
Merit : 31
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyWed May 22, 2013 1:10 pm
I was idling at like 210ish with my 180 tstat a few days ago in traffic. Really thinking about trying a 160 tstat out just to see how it helps in the hot hot heat we are going to have this summer.
Probably need a tune to get the fans to turn on sooner too, huh.
OK, just read some. Never mind. I dont need a 160, I need a tune.
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyWed May 22, 2013 1:17 pm
Even with a 180 T-stat, you're still going to reach over 200*. Yes, if you want to reap the full "benefits" of a 180 stat, you need to have to fans kick on sooner...
Merit : 31
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyWed May 22, 2013 1:18 pm
Scott, as soon as I get my exhaust done, I will be paying you a visit!
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyWed May 22, 2013 2:29 pm
That's what I'm afraid of nervous
scat
Merit : 31
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyWed May 22, 2013 2:32 pm
hi
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyWed May 22, 2013 2:56 pm
My Eprom chip is tuned by Sinister to turn the fans on at 180 deg.I dont know about the series 2? you can install a sensor like this one to come on at any temp without the hassle of tuning your pcm.super easy to install and wont interfere with anything I think.1 fan runs for the AC,while the other fan runs the rad according to the FSM. Jegs also sells a single fan sensor too that you can program to run at 180deg
http://www.jegs.com/i/JEGS-Performance-Products/555/52126/10002/-1?parentProductId=1557724
Merit : 31
PostSubject: Re: Should I replace my OEM thermostat?   Should I replace my OEM thermostat? - Page 3 EmptyWed May 22, 2013 2:59 pm
Thanks, Robo, but I plan on just setting the fan variable in the PCM once it's tune time. ISNT THAT RIGHT, SCOTT, MA MAN!? happy
» no heat?
» Write-Up: Thermostat Installation
» Thermostat Stuck Open *
» ZZP Radiator!!!
» Write-Up: Replacing Supercharger Belt Tensioner
