 ZZP Radiator!!!
96RIVMANN
lionfish
'96reese
1996RIV CALI
BillBoost37
Ridin-Rivi
urbsnspices
20 posters
Go to page : 1, 2, 3  Next
ZZP Radiator!!! Empty
PostSubject: ZZP Radiator!!!   ZZP Radiator!!! EmptyThu Apr 17, 2008 7:17 pm
http://www.zzperformance.com/grand_prix/products1.php?id=222&catid=109
97/98 GTPs used the same tranny right? They don't have any dimensions on that radiator so I have no idea if it would be the same fit. Now, the real question comes. Is that worth spending 200 bones on? They claim lower tranny temps, can anyone vouch?
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyThu Apr 17, 2008 7:45 pm
best bet would be to check clubgp for those who have installed it.
ZZP Radiator!!! Dsc_0110
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyThu Apr 17, 2008 8:02 pm
I tried registering there, but it didn't work, my account was never approved. I searched the threads and couldn't seem to find anything. If anyone could maybe post a thread asking about them for me, it would be greatly appreciated.
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyThu Apr 17, 2008 11:01 pm
the same thing happened to me at regalgs.org i tried joining 8 times...... never approved maybe im too baller? rolleyes
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyFri Apr 18, 2008 2:32 am
even the "stock" replacement radiator is quite a bit thicker than what came in the car new. I didnt notice a difference in temps but I still have the stock temp gauge and its not that accurate.
Merit : 251
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyFri Apr 18, 2008 9:06 am
I would just go stock. It performs just fine, imo.
urbsnspices
urbsnspices
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyFri Apr 18, 2008 12:35 pm
Hey FWIW, go to rockauto.com and look up a replacement Rad for a 97 Regal GS. They have multiple options, including an oversized aluminum one that matches the thickness of the ZZP one. 1 3/8th for $178. Betcha it is the same one.
Personally i would go stock. If you are interested in lower tranny temps, this would be a great opportunity to install a separate tranny cooler. I did see lower trans temps and more stable trans temps with an external cooler. Also I have to assume that the stock rad is working more efficiently with out the scalding hot trans fluid running through it....
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyFri Apr 18, 2008 4:35 pm
I looked on rockauto, the cheapest for the regal was 140 something, and I searched parts for a 97 riv and the cheapest was 208???
urbsnspices
urbsnspices
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyFri Apr 18, 2008 4:51 pm
Yeah that is what I saw. The 178 regal version was for the thicker one. Based on the dimensions it looks to be the same size as the one ZZP sells. Not sure why the riv one is so expensive but atleast you wont have to fab up any custom mounting system.
BTW, nice super low mile rivi...
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyFri Apr 18, 2008 4:54 pm
Maybe i'll just spring the 178.. Thanks, it was swapped in right before I bought the car. Unfortunately the radiator is original...
Ridin-Rivi
Ridin-Rivi
PostSubject: Radiator!!!   ZZP Radiator!!! EmptyThu May 01, 2008 10:54 am
My Radiator is leaking. Any recommendations or possible fixes that can be done? It shouldn't be to hard to remove or replace the radiator is it?
Merit : 251
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyThu May 01, 2008 11:27 am
I wouldn't recommend fixing an old radiator. Buy a new one. Doesn't look too bad to replace, but I've never done it on a Riviera.
BillBoost37
Merit : 26
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyThu May 01, 2008 12:37 pm
One Riv owner recently told me it wasn't bad... just don't forget to rehook the trans lines.
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyThu May 01, 2008 3:34 pm
ive done it and once you get those fans out of the way you got plenty of room to work. Rehooking the TOP transmission line was a bitch. Id swear for the first 30 minutes that it wasnt the right radiator. Of course the bottom one went in on the first try.
Ridin-Rivi
Ridin-Rivi
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyFri May 02, 2008 11:13 am
Any idea on the cost?
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptySat May 03, 2008 6:09 am
my replacement was like $212 new. Might wanna replaced the main coolant hoses too if you haven't.
Ridin-Rivi
Ridin-Rivi
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyMon May 19, 2008 4:25 pm
UPDATE... So I decided to look at my radiator today before I bought a new one to make sure that was the problem. I noticed that each side of the radiator is plastic. If your looking at the front of the car there is a hairline crack about 2 inches long on the right side. I squeezed the hose and saw fluid escaping from it. I might just try and use some type of high temp glue or epoxy. Any recommendations?
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyMon May 19, 2008 4:27 pm
Good luck........ no joke but duct tape literally fixes anything..... BUT i would definately clean it good put some sort of adhesive and than duct tape over that a few times
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyMon May 19, 2008 4:36 pm
Tried that, it lasted 2 weeks. I wouldn't do it.
Merit : 251
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyMon May 19, 2008 4:42 pm
You know, there's a reason there's no core charge or remanufactured radiators for sale...
Ridin-Rivi
Ridin-Rivi
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyMon May 19, 2008 5:17 pm
Yeah, I read that glue doesn't work to well. I am either debating get one from ebay.com or radiator.com.
ebay.com = $125 shipped
radiator.com = $175 picked up...
Ridin-Rivi
Ridin-Rivi
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyMon May 19, 2008 5:24 pm
Also. What is the best way to flush your system before you install a new radiator. Is this a fairly easy and straight forward job.
Merit : 251
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyMon May 19, 2008 5:35 pm
I would drain it all out, install the new radiator, fill it up with water, then drive to have your flush done. Or, you could just skip the flush and add the new mix.
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyMon May 19, 2008 8:17 pm
NAPA sells a kit to repair the plastic radiator where it is cracked. But you will have to remove it to fix it right.
Bert
PostSubject: Re: ZZP Radiator!!!   ZZP Radiator!!! EmptyMon May 19, 2008 10:12 pm
i would replace it, not repair it. i've never seen a radiator repair last very long. it is a temporary fix and nothing more.
on that note, i had to repair a friends toyota land cruiser when we were down in the keys last summer. we used it to tow the boat, and 1/2 way through our stay down there the side developed a crack. the local napa in marathon key (next closest one was in like miami lol) obviously didnt have a '91 land cruiser radiator in stock, and to have one shipped before we left would have cost over $900!! (for just the part+shipping) so i used every fix-it they had and monitored it closely the rest of the trip. we towed the boat all the way back up to Ga without a problem. next week the leak broke again so i replaced it for her.
best thing to do would be like AA said. drop in the new one, then flush it. there is really no way to flush it with the old one not working. you could buy the "flush" at the store, but i always just run it through with hose water until it comes out clear. it may take 2-3 times of complete fill, run engine, drain all, repeat. i also usually remove the tank and clean it by hand.
ZZP Radiator!!!
» A/C Radiator
» freaking radiator
» Radiator to H2o pump
» Radiator questions
» My mom found oil in my car's radiator.
