| FAQ: Automatic Leveling Control (ALC) Concerns | |
+6799Rivman 1967 - 1997 Riviera gunmetalRED c0reyl dboydakid Lisa P charlieRobinson gmann3001 BigRay1125 Mattwa Coltrain billy1290 AKC GreenMonster J. Chris Davis Derek sqrivi Mike9874 Karma epic612 Robb soulbladexll Snowdog Abaddon BrianEsser ciro307 98inSFl Z-type DEMonte1997 Eldo Allstyle Sweepspear LARRY70GS GMFreak8 Dj Brady ewolfe0050 1995 Riv Ryan from Ohio Rickw No-Lift gliderguy albertj robotennis61 '96reese Jack the R T Riley ibmoses TonySmooth89 ¤DoughBoy¤ 96RIVMANN BillBoost37 1badriv jhodges robertwolf86 TType_Riviera AA 97rivman 1998 Riv dreww clazzicradiorepair bayarearivi 98riv deekster_caddy oldsman105 Mr.Riviera jax95riv NO 4 EVR 71 posters |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri May 28, 2010 8:54 pm | |
| - soulbladexll wrote:
- Didnt know that the shocks are susposed to be at a certain foot pounds i just tightened them up... could this be causing a problem???
It could have caused a problem if they were sloppy loose. Most likely a clunking noise before they eventually fell out. But otherwise probably not too bad. The clunking would have been pretty apparant. | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri May 28, 2010 11:33 pm | |
| springs do lose a few lbs over time,but what causes the springs to deharmonize with the car are the surrounding components like the shocks and bushings. spring rates measured new and at 5 to 15 years old show negligible loss in rate. a spring will lose a 1/2 to an inch over its life.more if the car is driven hard.race car.
once a spring sets, it pretty much stays that way. having sed that,the superior springs potential will never be realized until all suspension components are brought up to the same quality. same goes for a superior shock. or a superior bushing.the upgrade is evident but will never be a TOTAL package until the suspension as a whole is complete. upgrading the riv is a challenge because ,there is no support for her. ya have to make it yourself!! | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri May 28, 2010 11:57 pm | |
| Well, as I've said before, if this car is supposed to be level and also clear the average driveway, the rear springs are too tall/strong (even w/o the Level Ride,) and the fronts are too short/weak... | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Sat May 29, 2010 12:20 am | |
| - Eldo wrote:
- Well, as I've said before, if this car is supposed to be level and also clear the average driveway, the rear springs are too tall/strong (even w/o the Level Ride,) and the fronts are too short/weak...
Variable Rate springs for the fronts would be great if they were progressive enough. Albertj | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Sat May 29, 2010 12:27 am | |
Albertj I agree - but I've never used variable-rate springs except on the rear, like CargoCoils... | |
soulbladexll Amateur
Name : Jon Age : 33 Location : Toledo/oh Joined : 2010-05-20 Post Count : 30 Merit : 0
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon May 31, 2010 11:00 pm | |
| I want to replace the lines but am sort of unaware as to how... The lines i got dont have the lips on them and easily slip out of the clip to the compressor. do they make lines with the lips? or is there a trick. | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon May 31, 2010 11:15 pm | |
I have to agree with you. When I first went to look at this car used, I didn't pick up on the fact that the rear shocks were blown and the relay had been pulled to the compressor, because the ride height in the rear looked fine and the car rode OK. I think this has happened to a lot of people on here that have bought used Riv's only to find the shocks, then the compressor, then the lines are bad. But I still stand firm on the positive effects replacing the front shocks and springs and all other parts, made a huge difference in ride and increased the height. I was just noticing today how when I came to a quick stop, the nose didn't dive. That and other handling characteristics remind me how bad they were before I changed them out. I think I rode on the stuff that came with the car for almost a year, so I had enough time to evaluate the way it rode and handled. | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon May 31, 2010 11:22 pm | |
Well, I did say "and the fronts are too short/weak..." So | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon May 31, 2010 11:28 pm | |
| I know you agree, I wasn't trying to start anything. | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Tue Jun 01, 2010 1:13 am | |
| - Eldo wrote:
Albertj I agree - but I've never used variable-rate springs except on the rear, like CargoCoils... Hmmm... not sure what variable-rate springs buys me on the rear becuase of the Air-Ride. Variables on the fronts would help if only to keep the suspension somewhat more balanced when the rear stiffens up at times the air ride senses heavier load in the car (and puffs up the rear shocks). On balance it's not that big a deal, just thinking it'd be nice to have. Albertj | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Tue Jun 01, 2010 1:53 am | |
| - albertj wrote:
Hmmm... not sure what variable-rate springs buys me on the rear because of the Air-Ride. Albertj True, I was speaking of previous cars... | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri Jun 04, 2010 9:11 pm | |
| I want to replace the lines but am sort of unaware as to how... The lines i got with the shocks dont have the lips on them and easily slip out of the clip to the compressor. do they make lines with the lips? or is there a trick. | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri Jun 04, 2010 9:22 pm | |
- I want to replace the lines but am sort of unaware as to how... The lines i got with the shocks dont have the lips on them and easily slip out of the clip to the compressor. do they make lines with the lips? or is there a trick.
if the old lines are not broke, leave them alone - they don't exactly wear out. Albertj | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri Jun 04, 2010 10:12 pm | |
Albertj What if I already hacked them for my gabriels (screw on fitting) and want to go to monroes now... | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri Jun 04, 2010 10:22 pm | |
Albertj What if I already hacked them for my gabriels (screw on fitting) and want to go to monroes now... Now this is making more sense. Consider getting a line kit from a GM dealer (they will fit) or using compression fittings to splice the lines. It may take some doing to get the compression fittings, I would try a NAPA or CarQuest dealer, or a local parts jobber that sells to local mechanics (the hint - they will have a relatively large behind-counter stock of parts and more rather than fewer delivery vehicles). Albertj | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri Jun 04, 2010 10:26 pm | |
| If you read through this thread, I remember seeing the Monroe P/N that others have used for the line kit that will allow you to toss all the old and replace with new for less than $10.00 | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Fri Jun 04, 2010 10:39 pm | |
| - Rickw wrote:
- If you read through this thread, I remember seeing the Monroe P/N that others have used for the line kit that will allow you to toss all the old and replace with new for less than $10.00
just looked didnt find anynthing cntrl f'd the whole thread for the word lines | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Sat Jun 05, 2010 9:42 pm | |
just looked didnt find anynthing cntrl f'd the whole thread for the word lines Try the word "Monroe." Albertj | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Sat Jun 05, 2010 9:59 pm | |
| http://www.shockwarehouse.com/site/product.cfm?id=19941
Try this for the proper Monroe Kit.
I did as Albert suggested and found it on page 2 for you. | |
Robb Amateur
Name : Robb Age : 47 Location : Batavia, NY Joined : 2010-07-12 Post Count : 26 Merit : 0
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon Jul 26, 2010 8:10 pm | |
| I skimmed over this thread and didn't see anything about the hoses coming off the compressor. There are 2 or 3 rubber hoses that come from the compressor to a resivior then go to the shocks. I have replaced the hoses on my 95 and a guys 97 and that fixed the problem. Mine are old and I thought shot, but worked fine after I plugged it back in (I guess the pumping noise was annoying the PO) and replaced the hoses.
Then I thought, I wonder if I can get the car to sit higher? So I took the rod going to switch and bent it. now the car sits higher in the back and no more scraping on bumps. Didn't see this, so I thought it may be worth a mention. | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon Jul 26, 2010 8:18 pm | |
| - Robb wrote:
- Then I thought, I wonder if I can get the car to sit higher? So I took the rod going to switch and bent it. now the car sits higher in the back and no more scraping on bumps. Didn't see this, so I thought it may be worth a mention.
Robb, The rod is adjustable to raise or lower the height of the car. You don not need to BEND the rod to make the adjustment. Just so you know. If it is where you want it, leave it there. Next time, if there is a next time, look for the one screw to loosen the rod end and move it where you need it then tighten. | |
Robb Amateur
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon Jul 26, 2010 10:59 pm | |
| I think there was a screw on the 97 I worked on, but not on my 95 actually. I didn't even thing about that until now. | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Mon Jul 26, 2010 11:13 pm | |
| I'm pretty sure that Rick is right... My '81 Cad had the adjustable arm on the ELC unit. | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns Tue Jul 27, 2010 2:44 am | |
| Every GM I have owned or worked on has an adjustable rod to the control switch. And i believe all the Riv's share the same system when it comes to ELC. Might be some small control differences but as far as controlling the compressor by having a switch attached to the control arm that is adjustable, they are the same. Think about it, it has to be adjustable. And not by bending a rod. | |
epic612 Amateur
Name : Collin "C Note" Abram Age : 36 Location : Minneapolis, MN Joined : 2010-10-08 Post Count : 20 Merit : 0
| Subject: Is it the compressor? Thu Oct 28, 2010 3:51 pm | |
| On my 96, the back end is SUPER bouncy. When I press down and make it bounce up and down, I don't hear anything abnormal, so I'm guessing there's no problems with the bags themselves. But I do hear a constant noise, sounds like a buzzing/humming coming from the middle-back of the car. Checked with both the car running, and engine off with key in on position. Took a second for it to start, but the sound came on and kept going.
My guess is it's a bad compressor. Am I right? Anyone else deal with this particular issue before? And if it is the compressor, how much will the compressor cost?
Also, how hard is it to replace the compressor. I got on alldata at school and it seems like it might be easy, but I'd like to hear from anyone who's had to do it themselves. Thanks! | |
| Subject: Re: FAQ: Automatic Leveling Control (ALC) Concerns | |
