 P0730 Incorrect Gear Ratio
2 posters
BillBoost37
Merit : 26
P0730 Incorrect Gear Ratio Empty
PostSubject: P0730 Incorrect Gear Ratio   P0730 Incorrect Gear Ratio EmptyTue Jun 03, 2008 7:25 am
Well..it's been running really well lately... it was time for the next learning expereince.
Got the 0730 code twice yesterday and three times this morning during my 20 mile commute. FSM says to check the Input Shaft Sensor and VSS sensor, input shaft is buried inside with no real way to check it. Guess I'll go after the VSS and hope for the best.
Pan drop happening tonight.
Anyone else ever get this code?
PostSubject: Re: P0730 Incorrect Gear Ratio   P0730 Incorrect Gear Ratio EmptyTue Jun 03, 2008 12:18 pm
If you did not actually change anything (transmission), most likely the VSS or ISS is crapping out.
» 97-99 supercharged gear ratio's
» A/F Ratio Gauge....NEED HELP
» Air Fuel Ratio
» white smoke / Need stock compression ratio
» ZZP 1.9:1 Ratio Modified Rockers
