| FAQ: Degreasing Engine & Cleaning Under The Hood | |
+15charlieRobinson 96_Juggernaut Sir Psycho Sexy matt270avian nasty95 AA SuperRiv07 Jason jimmyriv rivwilly107 deekster_caddy 99Rivman oldsman105 ibmoses Chicken 19 posters |
 | Subject: Re: FAQ: Degreasing Engine & Cleaning Under The Hood Sat Feb 15, 2014 2:15 pm | |
| No.Not advisable to wash a hot engine in cold weather.Spray Gunk Engine cleaner all over the cold engine,avoiding sensitive electronics.With a long bristle brush get into all visible areas that need a good scrubbing.Rinse. | |
charlieRobinson Expert
Name : Charlie Age : 37 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3922 Merit : 30
 | Subject: Re: FAQ: Degreasing Engine & Cleaning Under The Hood Sat Feb 15, 2014 2:26 pm | |
| I want to clean the salt out of the bay. Should I just wait until it gets warmer? | |
 | Subject: Re: FAQ: Degreasing Engine & Cleaning Under The Hood Sat Feb 15, 2014 4:23 pm | |
| Well,yeah.Chemicals dont to too good in the cold.They thicken & grease is less likely to give up it's post,in a perfect world anyway. It's safe to spray the worst of it off with water when the engine's cold.Save your Gunk money for later. Dont worry too much about a dirty engine in the winter anyway,save the job for spring. | |
IFallsRon Fanatic
Name : R.L. Joined : 2012-11-23 Post Count : 268 Merit : 2
 | Subject: Re: FAQ: Degreasing Engine & Cleaning Under The Hood Sat Feb 15, 2014 5:41 pm | |
| I've always figured you'd be asking for problems spraying the engine compartment in the winter unless you had a specific need and a heated garage. If something is annoying you, dump a milk jug of warm water on the area and try to avoid any electrical or rubber that could freeze. I'm in an area with prolonged cold and regular dips below zero. I don't go to the car wash unless it's 20 or warmer. | |
Name : Derek Age : 50 Location : Reading, MA Joined : 2007-01-31 Post Count : 7717 Merit : 109
 | Subject: Re: FAQ: Degreasing Engine & Cleaning Under The Hood Sun Feb 16, 2014 9:33 am | |
| I did spray the engine bay a few times in winter. I wouldn't recommend it. I had weird cluster issues and 'strange things' happening for a few days after the cleaning. Just wait for warmer weather IMO. | |
 | Subject: Re: FAQ: Degreasing Engine & Cleaning Under The Hood Sun Feb 16, 2014 9:55 am | |
| Just me, but I've never sprayed down the engine in my car. I prefer to clean areas locally with a rag, cleaner and water from a spray bottle if needed. I've found WD40 works well as a cleaner/degreaser that leaves very little dirt residue. For stubborn stains I use a concentrated orange cleaner and rinse with a small amount of water, then dry with a towel. When you replace a component in the engine bay, take time to clean the area since you have access. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
abaucom Enthusiast
Name : Al Baucom Location : Ottawa Ontario Joined : 2010-03-28 Post Count : 225 Merit : 22
 | Subject: Re: FAQ: Degreasing Engine & Cleaning Under The Hood Sun Feb 16, 2014 1:10 pm | |
| Suggest you wait until spring and all road salts are washed from streets. Otherwise you are still going to get road salt in your clean engine bay from wet roads. Remember rust starts slower in cold weather, speeds up in warmer weather.
Since moving to Canada learned once daily temps hit about 40 F, time to remove snow tires as rubber compound wears faster in heat, power spray underbody once spring rains clean street of salt dust, then consider a rust treatment application (I have used Krown for many years with great sucess - do a web search on best products). Then I send my cars to an auto detailer to clean all the little nooks.
Living in a snow climate can be hard on our autos. That is why I garage store my Riv from late Nov. to early April until spring rains wash away street salt dust. I drive my 2011 Camaro winters but following the above spring cleaning ritual underbody body is still rust free. My 1998 Riviera, never driven on wet salted streets, underbody still looks factory new. I rust treat the Riv every two years as my underground parking garage during winters can get damp and salt dust builds up until they power wash the parking garage in May.
Just my insight from Canada. | |
95riviboy93 Rookie
Name : Eric Location : chicago il joliet il Joined : 2016-01-18 Post Count : 16 Merit : 0
 | Subject: Re: FAQ: Degreasing Engine & Cleaning Under The Hood Tue Sep 20, 2016 12:31 pm | |
| What kind of brush or rags do you guys use for scrubbing ? | |
IFallsRon Fanatic
 | Subject: Re: FAQ: Degreasing Engine & Cleaning Under The Hood Thu Sep 22, 2016 7:53 am | |
| - 95riviboy93 wrote:
- What kind of brush or rags do you guys use for scrubbing ?
Go to a dollar store and pick a selection with different head angles and bristle configurations. You might want a toilet brush, too, as it has a long handle. Tooth brushes are handy, too. | |
 | Subject: Re: FAQ: Degreasing Engine & Cleaning Under The Hood  | |
