 supercharger whine
Tank
florence_x
97 park ave
simba
Ash
gordy318
duster_do_little
curious riv
BillBoost37
Supercharged
texasfan010
26 posters
Go to page : 1, 2, 3, 4  Next
texasfan010
texasfan010
supercharger whine Empty
PostSubject: supercharger whine   supercharger whine EmptyWed Jul 23, 2008 10:22 pm
Hey im sorry for my numerous posts lately, but after i repair my car i want to drastically increase the volume of the whine of the supercharger. i want people to hear it coming from a ways away. i have just a stock car with a gutted airbox. Got any ideas? thanks
PostSubject: Re: supercharger whine   supercharger whine EmptyWed Jul 23, 2008 10:24 pm
An FWI of 4" will make some noise... A ported supercharger will make it louder still. A GenV supercharger sounds just awesome! But it's a bit more work...
PostSubject: Re: supercharger whine   supercharger whine EmptyWed Jul 23, 2008 11:05 pm
what about a smaller pulley on the supercharger?
http://www.Chitownracing.com
PostSubject: Re: supercharger whine   supercharger whine EmptyWed Jul 23, 2008 11:23 pm
I would not recommend dropping pulley sizes with just a gutted airbox for mods. A purely stock setup can still have existing KR, a smaller pulley will make it worse.
No way to know w/o scanning for KR. Like Derek said, your best route would be to open up the intake with a 4" FWI and cone K&N in the FW. Also remove the big plastic shield over the engine. Pull the weatherstrip off the back of the engine bay. It'll let hot air out of the bay, and maybe a bit more whine.
texasfan010
texasfan010
PostSubject: Re: supercharger whine   supercharger whine EmptyWed Jul 23, 2008 11:31 pm
wat is the weather strip and how do you remove it?
PostSubject: Re: supercharger whine   supercharger whine EmptyThu Jul 24, 2008 9:51 am
It is a length of rubber seal that runs across the top/back side of the engine bay, sealing against the underside of the closed hood. It will just lift right off the steel ridge it sits on. Removal should help allow hot eng compartment air to pass out the back of the hood when you're moving. I'd keep it though, don't toss it out.
PostSubject: Re: supercharger whine   supercharger whine EmptyThu Jul 24, 2008 10:06 am
FWI, plain and simple.
Supercharged
Supercharged
PostSubject: Re: supercharger whine   supercharger whine EmptyThu Jul 24, 2008 10:25 am
https://www.youtube.com/watch?v=OzTyLbJ7WHY
you cant clearly hear the effects of a FWI
PostSubject: Re: supercharger whine   supercharger whine EmptyThu Jul 24, 2008 11:09 am
You can in person.
PostSubject: Re: supercharger whine   supercharger whine EmptyThu Jul 24, 2008 12:42 pm
so a fwi does that much ? mine sounds like that and I dont have one?
PostSubject: Re: supercharger whine   supercharger whine EmptyThu Jul 24, 2008 12:44 pm
Keep in mind that sound is also very relative to location/perspective
PostSubject: Re: supercharger whine   supercharger whine EmptyThu Jul 24, 2008 12:56 pm
The sound won't really change, just the sound level, specifically on hard acceleration, but at idle also, esp with your window open, as the FWI is right by your door. A smaller pulley, when you can safely run one, will add some volume too since the SC will be running at higher rpm's.
PostSubject: Re: supercharger whine   supercharger whine EmptyThu Jul 24, 2008 12:57 pm
If you REALLY want it loud, leave off the filter.... (J/K)
PostSubject: Re: supercharger whine   supercharger whine EmptyThu Jul 24, 2008 1:18 pm
FWI seems about 50% louder than gutted box, and maybe double the sound level of stock. Remember that the GTP is not as well insulated, so the noise is a bit softer in a Riv with windows up, but roll them down... from outside it's just as loud:
texasfan010
texasfan010
PostSubject: Re: supercharger whine   supercharger whine EmptyFri Jul 25, 2008 1:07 am
is there any way to make a FWI out of the stock hose?
PostSubject: Re: supercharger whine   supercharger whine EmptyFri Jul 25, 2008 1:11 am
the stock intake is a FWI wink
I reckon you could use the stock hose as part of it but it's simply not long enough to make it through the fender well. You would need to add hard tubing to it no matter what and really the whole point is to make the intake better than the stock so why do it? You know what I mean jellybean?
PostSubject: Re: supercharger whine   supercharger whine EmptyFri Jul 25, 2008 8:38 am
Yep, https://rivperformance.editboard.com/series-ii-engine-transmission-f4/write-up-modified-air-box-cai-t1289.htm
turtleman wrote:
The stock intake is a FWI.
I would say it's half FWI and half CAI, reason being that CAIs use an air box, while FWIs do not.
Merit : -16
PostSubject: S/C whine question   supercharger whine EmptyWed Jul 30, 2008 2:05 am
Perhaps this is a dumb question but what really makes the whine that the superchargers do make oh so much? Is there any particular reason why one time driving the car it sounds particularly boosty (As in the S/C whines with the slightest provocation of the gas pedal a bit much) and other times much quieter?
PostSubject: Re: supercharger whine   supercharger whine EmptyWed Jul 30, 2008 8:20 am
a combination of the air opening and RPM. The air opening is controlled by the vacuum boost bypass valve, which opens according to how much you are stepping on the gas.
Or are you more interested in the physics of how each rotor opening generates a little whoomping sound as it passes the opening that when combined with 5000 RPM makes such sweet music? smile
PostSubject: Re: supercharger whine   supercharger whine EmptyWed Jul 30, 2008 9:47 am
Have you ever heard an air raid/tornado warning siren? Blowers and sirens share a lot of the same things, but while superchargers are designed to push air into the engine, sirens are designed to push air out of a horn, as sound. Blowers and sirens are different, but the same type of thing is happening in both. If you could listen to a blower from the manifold side, it would be pretty f'n loud.
Like Derek said, the bypass is controlled by vacuum, which is indicative of engine load. If engine load increases while in OD with the TCC locked, as in going up a hill, you can have significant boost at very low (1500) RPM.
BillBoost37
Merit : 25
PostSubject: Re: supercharger whine   supercharger whine EmptyWed Jul 30, 2008 10:17 am
Weather and air density also have a bearing on the amount of sound.
PostSubject: Re: supercharger whine   supercharger whine EmptyWed Jul 30, 2008 10:27 am
agree engine temp plays a part too. cold start-up and 200* coolant sounds like 2 different engines, and the whine pitch and rpm changes too.
it also depends on where you drive and what the sound can reverberate off of. i love driving next to a wall on the driver side, let the car get into 3rd gear and romp on the peddle making the s/c scream but letting off right before the downshift twisted
supercharger whine Dsc_0110
PostSubject: Re: supercharger whine   supercharger whine EmptyWed Jul 30, 2008 11:20 am
In high school auto when we were doing superchargers, we hooked an m90 up to the alternator tester to spin it. It was actually part of the lab. The sound that came out of it was much louder than the whine. It was a very low sound actually, kind of like a propeller aircraft engine at low rpm. But ya if you have the blower off the manifold, that sound is entirely different.
PostSubject: Re: supercharger whine   supercharger whine EmptyWed Jul 30, 2008 12:04 pm
didn't you weld shut you silencers on your ported superairphucker? did it make a differance?
Merit : -16
PostSubject: S/C whine   supercharger whine EmptyWed Nov 12, 2008 3:53 am
I've noticed from other 3800 videos that mine sounds odd. Please compare mine:
