| problem # 2 front main seal blew (see pg2) | |
+10BillBoost37 '96reese turtleman manofmany ibmoses ewolfe0050 TonySmooth89 deekster_caddy Chicken Mr.Riviera 14 posters |
ewolfe0050 Aficionado
| Subject: Re: problem # 2 front main seal blew (see pg2) Fri Jul 25, 2008 8:36 pm | |
| I have a stock ballancer in excellent shape. PM me. | |
| Subject: Re: problem # 2 front main seal blew (see pg2) Fri Jul 25, 2008 10:04 pm | |
| anyone know if that balancer bolt is reverse thread? EDIT: never mind, they are normal thread.
and are the TTY bolts dealer only? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: problem # 2 front main seal blew (see pg2) Sat Jul 26, 2008 6:44 am | |
| Glad you found the problem!
(BTW I've seen a lot of cars driving around with broken flexplates, they'll hold together for a long time broken)
I don't know of anyone who replaced the bolts... I'm sure it's recommended though, you should probably get them. | |
ibmoses Aficionado
| Subject: Re: problem # 2 front main seal blew (see pg2) Sat Jul 26, 2008 9:49 am | |
| - Mr.Riviera wrote:
- it is the balancer! shattered all the way around the rubber/plastic. now i just hope i didnt do any internal damage.
thank you for all your help! I had that happen once on a NA3800 Series I. No internal damage on that engine. Bert | |
| Subject: Re: problem # 2 front main seal blew (see pg2) Wed Jul 30, 2008 5:51 pm | |
| ok i'm about ready for a new engine. the main seal just went and i lost every drop of oil in about 30 seconds. how much trouble is it to replace a main seal? assuming that is what blew. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: problem # 2 front main seal blew (see pg2) Wed Jul 30, 2008 9:13 pm | |
| TTT help! i have a final exam tomorrow, and have to be out of my apartment by 10am thurs, and need to drive 200 miles home until the 8th when i can move into my new house. why did it have to blow now??? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
manofmany Addict
| Subject: Re: problem # 2 front main seal blew (see pg2) Wed Jul 30, 2008 9:15 pm | |
| These are notorious on Mitsubishi Eclipses. They get old and hardened and seperate.
Not sure where the front main seal comes into play.... Should be an easy fix. | |
| Subject: Re: problem # 2 front main seal blew (see pg2) Wed Jul 30, 2008 9:24 pm | |
| crank pullies are also common on the 2JZ-GE motor, as in the supra. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: problem # 2 front main seal blew (see pg2) Wed Jul 30, 2008 9:34 pm | |
| Could have been caused by the blown balancer? Sorry to hear it. Ed Morad usually has complete low milage motors | |
| Subject: Re: problem # 2 front main seal blew (see pg2) Wed Jul 30, 2008 9:47 pm | |
| It's not terribly surprising if it's the front main seal you're talking about. With the balancer off, putting a new one in should be pretty easy. | |
'96reese Fanatic
| Subject: Re: problem # 2 front main seal blew (see pg2) Thu Jul 31, 2008 3:43 am | |
| i agree with turtle, those are very easy to do. once you have the harmonic balancer off you should be able to see it . remove the old seal and tap in the new one. if you have a seal puller(you can get one from any part store or sears for about $15) that should do the trick. i used a thick block of wood, hammer, and sum grease to tab it back in. now mind you i have never done this with the timing cover on. removing the timing cover mkaes it very easy, plus you get a new timing cover gasket and front main seal too! | |
BillBoost37 Junkie
| Subject: Re: problem # 2 front main seal blew (see pg2) Thu Jul 31, 2008 7:43 am | |
| Getting the old one out is the harder part. Take your time..don't get overly frustrated and you'll be able to do it. | |
| Subject: Re: problem # 2 front main seal blew (see pg2) Thu Jul 31, 2008 6:55 pm | |
| its all good now. got a new front seal in and drove it home. so far so good. seal cost me $18 at the dealer, and when i took off the balancer (brand new, not even a week old) the metal shaft cracked when i used the starter to break loose the bolt. i warrantied the balancer and got a new one. i spent about an hour actually working on the car, in the parking lot, with hand tool, in the rain. but it wasnt as difficult as i thought it was going to be. i figured w/my luck i would have to pull the timing chain cover, but i didnt. i will say the new seals are a bitch to press in. i hope this is my last fix for a while so i can start spending the money on modding again. Matthew _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
Chicken Aficionado
| Subject: Re: problem # 2 front main seal blew (see pg2) Thu Jul 31, 2008 6:59 pm | |
| - Mr.Riviera wrote:
- i spent about an hour actually working on the car, in the parking lot, with hand tool, in the rain.
HAHHAHAA!!! I can't stop laughing!!!! Sorry!!!!! | |
captshiner Junkie
Name : Andrew Age : 37 Location : Cincinnati, OH Joined : 2008-07-23 Post Count : 756 Merit : -1
| Subject: Re: problem # 2 front main seal blew (see pg2) Mon Aug 04, 2008 4:57 pm | |
| When I used to go to quick lube places they always said there was an oil leak but I never saw it. I asked them where it was coming from and they said it was from the rear main seal. My question is how hard is it to get to? And is it as easy to replace as the front main seal? The leak must be really small because I've never seen oil spots from under my car, or any dripping what so ever. | |
| Subject: Re: problem # 2 front main seal blew (see pg2) Mon Aug 04, 2008 5:18 pm | |
| Oil can also leak from the pan, valve cover gaskets, or the engine could be burning a little when you drive. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: problem # 2 front main seal blew (see pg2) Mon Aug 04, 2008 5:22 pm | |
| You will have to remove the trans from the engine to get to the rear main seal. If it doesn't leave spots, I'd leave it alone. Valve cover gaskets are inexpensive and easy to do, oil pan gaskets require a little more work. (I believe you have to remove the timing cover) | |
captshiner Junkie
| Subject: Re: problem # 2 front main seal blew (see pg2) Mon Aug 04, 2008 5:28 pm | |
| "If it doesn't leave spots, I'd leave it alone." My attitude, exactly. I don't go to those quick lube places anymore, they're run by a bunch of retarded high school kids who want me to pay $60 for an air filter that's not even reusuable. I used to go to them because I had a friend that was the manager and he would go the extra mile for me. I hate it when these kids assume you're an idiot and rip off unsuspecting people. | |
96RIVMANN Fanatic
Name : Paul Location : MN Joined : 2007-10-22 Post Count : 253 Merit : 11
| Subject: Re: problem # 2 front main seal blew (see pg2) Mon Aug 04, 2008 10:15 pm | |
| Oil pan and valve cover gaskets on the 3.8 is a breeze. Just make sure that when you do the oil pan gasket to put a bead of new silicone/rtv around the new gasket if you don't it will leak. I found out the hard way. | |
dreww Junkie
| Subject: Re: problem # 2 front main seal blew (see pg2) Tue Aug 05, 2008 5:00 am | |
| - 96RIVMANN wrote:
- Oil pan and valve cover gaskets on the 3.8 is a breeze. Just make sure that when you do the oil pan gasket to put a bead of new silicone/rtv around the new gasket if you don't it will leak. I found out the hard way.
X2. oil pan gasket is pretty easy. | |
BillBoost37 Junkie
| Subject: Re: problem # 2 front main seal blew (see pg2) Tue Aug 05, 2008 6:57 am | |
| The pan is about 20 easy to get at bolts, and being careful not to break the oil level sensor.
Valve covers are also easy, but the rear can be a pain if it's your first time.
The oil is most likely not coming from the rear main seal as most cars would have it. It's probably seeping from the rear engine cover. This is a bolted cover between the block and the flywheel. Engine or trans has to come out to tighten the bolts or change the gasket. | |
| Subject: Re: problem # 2 front main seal blew (see pg2) | |
