 Write-up: Fuel Filter removal / installation
Ash
8 posters
Write-up: Fuel Filter removal / installation Empty
PostSubject: Write-up: Fuel Filter removal / installation   Write-up: Fuel Filter removal / installation EmptyMon Sep 01, 2008 12:28 pm
Tools Required:
20mm open end wrench
16mm open end wrench or vise grips
Materials needed:
Fuel Filter - AC Delco P/N GF578, Purolator P/N F54714, other brand
Fire Extinguisher is recommended
PB Blaster, if needed.
Spare Rags
Car Ramps or Jack and jack stands
Difficulty:
Time Required:
15 - 40 minutes
Instructions:
(1) Jack up the rear of the car and support it with jack stands at the recommended jack locations, or use car ramps. For safety issues, apply the emergency brake and chock the front tires.
(2) The car should be cold when attempting to do anything with the fuel system. A fire extinguisher should be on hand in case of fire.
(3) Locate the Fuel Filter. This is found under the car, on the drivers side in front of the rear tire.
Write-up: Fuel Filter removal / installation Ffsw0
(4) Check the “female” connection between the fuel filter and the steel fuel line. If the fitting on the steel fuel line is rusted and shows signs of corrosion, apply PB Blaster and let it sit for 20 minutes or so.
(5) Depressurize the fuel system. The easiest way to do this is to unscrew the fuel cap. Once it is removed, go ahead and replace it.
(6) Disconnect the “male” end of the filter. The male end, or neck, of the fuel filter is connected to the hard plastic line running from the fuel tank. It is held in place by a plastic lock that’s attached to the fuel filter neck. Squeeze the lock with your fingers, disengaging the tabs from the plastic connection on the fuel line.
(7) Once the plastic lock is compressed, slightly twist both ends of the connection to break the seal. The plastic fuel line should slip right off with no issues. Have a rag handy. When the line is free a small amount of fuel will escape from the line. Don’t panic....this will stop.
(8) Disconnect the “female” end of the filter. Using a 16mm wrench, place the wrench on the fitting of the steel fuel line. The fitting is soft, so vise grips may be needed instead of the 16mm wrench to prevent the fitting from rounding off at the flats.
(9) Place the 20mm wrench on the female connection on the Fuel Filter. Holding the 16mm wrench or vise grips on the fuel line fitting, use the 20mm wrench to loosen the connection on the fuel filter. Once the connection is loose, spin the filter off by hand. Again, have a rag handy as a small amount of fuel will escape from the steel line, and whatever fuel was retained in the filter.
(10) To install the new fuel filter, reverse the process. After the filter is installed, start the engine and check for leaks.
Write-up: Fuel Filter removal / installation Img1330tk0
PostSubject: Re: Write-up: Fuel Filter removal / installation   Write-up: Fuel Filter removal / installation EmptyMon Sep 01, 2008 12:53 pm
i have to do this next weekend i don't think its ever been done and the car has 75k miles!
PostSubject: Re: Write-up: Fuel Filter removal / installation   Write-up: Fuel Filter removal / installation EmptyMon Sep 01, 2008 1:13 pm
nice right up I just did mine a month ago
http://www.Chitownracing.com
Ash
Ash
PostSubject: Re: Write-up: Fuel Filter removal / installation   Write-up: Fuel Filter removal / installation EmptyTue Sep 02, 2008 11:30 am
Nice write-up. But in step #8 you might want to mention or specify line wrenches (aka flare wrench) as a means of removing the steel line from the filter.
You remind me that I need to change mine sometime. It most likely is stock (67k mi.)
Cheers
PostSubject: Re: Write-up: Fuel Filter removal / installation   Write-up: Fuel Filter removal / installation EmptyTue Sep 02, 2008 1:25 pm
Line wrenches might be nice, but I didn't need them for mine.
PostSubject: Re: Write-up: Fuel Filter removal / installation   Write-up: Fuel Filter removal / installation EmptyTue Sep 02, 2008 10:14 pm
Thats a good tip about squeezing the lock on the plastic line with your fingers.
I may be the only human on the planet who did not realize that could be released that way...
I thought you had to use pliers, its a wonder I have not ruined one of the locks..
Bert tavis
NO 4 EVR
NO 4 EVR
PostSubject: Re: Write-up: Fuel Filter removal / installation   Write-up: Fuel Filter removal / installation EmptyWed Sep 03, 2008 12:59 am
Even tho I did my filter about 10K ago I think I'm doing mine again. I'll be using the higher flowing model from the ZZP site. It's cheaper than stock too so that's a plus.
http://www.zzperformance.com/grand_prix/products1.php?id=579&catid=113
PostSubject: Re: Write-up: Fuel Filter removal / installation   Write-up: Fuel Filter removal / installation EmptyWed Sep 03, 2008 3:56 am
Excellent write-up! I'll be doing this, and referring back to the write-up so I don't... screw-up.
PostSubject: Re: Write-up: Fuel Filter removal / installation   Write-up: Fuel Filter removal / installation EmptyWed Sep 03, 2008 10:40 am
i think i will go with zzp filter also, soon even though i did mine like 10000 miles ago
PostSubject: Re: Write-up: Fuel Filter removal / installation   Write-up: Fuel Filter removal / installation EmptyWed Sep 03, 2008 11:08 am
Just thought I'd add a comment regarding the ZZP filter. ZZP told me directly not to waste the extra money in a car that is not highly modded, and said go with the AC Delco filter if it's cheaper. I'd think if you're not running 13's at least, you don't need more flow than stock filter.
PostSubject: Re: Write-up: Fuel Filter removal / installation   Write-up: Fuel Filter removal / installation EmptyWed Sep 03, 2008 11:20 am
well maybe i want more flow, and i plan on modding more
» Write-Up: Transaxle Removal & Installation
» Write-Up: 3800 Series II SC Engine Removal & Installation
» Write-Up: Fuel Filter Replacement
» Write-Up: Thermostat Installation
» Write-Up: M90 Blower Installation
