| windshield washer fluid bottle | |
+6Eldo BKRIV Ryan from Ohio vendetta 99Rivman KillaKeninaRiv 10 posters |
KillaKeninaRiv Addict
Name : Kenneth Age : 40 Location : Roseville, MI Joined : 2008-05-17 Post Count : 709 Merit : 6
 | Subject: windshield washer fluid bottle Sun Sep 07, 2008 11:48 pm | |
| anyone know if there is another windshield washer bottle instaed of the small one on the passener side fender? | |
99Rivman Aficionado
Name : Randall Location : North Carolina Joined : 2007-01-16 Post Count : 2009 Merit : 88
 | Subject: Re: windshield washer fluid bottle Mon Sep 08, 2008 5:15 am | |
| Yes, there is another one that attaches to that one, it is in the fender. It attaches where the large hose is on the front of the tank. | |
 | Subject: Re: windshield washer fluid bottle Mon Sep 08, 2008 10:08 am | |
| would i have to remove the entire fender to access it? the fluid pump went out. the wipers work, but the fluid doesnt spray so im going to change the pumps out but i cant find where it is | |
99Rivman Aficionado
 | Subject: Re: windshield washer fluid bottle Mon Sep 08, 2008 4:13 pm | |
| No, the fender does not have to come off, but the inner wheel well does. Several push type pins, from the back to the front, at the inner and outer edge, and underneath the front some. Then remove the plastic inner wheel well. There are two 10MM bolts holding the tank in. Be careful here, the tabs that are a molded part of the tank break very easily. The pump is on that tank at the very back. I have changed the tank a few times but have never changed the washer pump itself so I'm not sure if you can do it with it in the car or not, or how exactly how it is removed from the tank. If it can not be changed with the tank still in the car you have to remove the large rubber hose that connects the two tanks, the wiring harness, and the small hose that feeds the fluid to the cowl area.
HTH | |
 | Subject: Re: windshield washer fluid bottle Tue Sep 09, 2008 12:01 am | |
| sounds like i wont be getting my uncle to do that part. ill try it myself instead | |
vendetta Enthusiast
Name : Nick Age : 113 Location : Shakopee, MN Joined : 2008-09-26 Post Count : 219 Merit : 0
 | Subject: Re: windshield washer fluid bottle Sun Oct 05, 2008 9:50 pm | |
| BS, why didnt they design it better...
im going to try doing this in the next week or so.... | |
Ryan from Ohio Fanatic
Name : Ryan Location : Toledo, Ohio Joined : 2008-11-16 Post Count : 307 Merit : 7
 | Subject: Re: windshield washer fluid bottle Mon Apr 06, 2009 5:33 pm | |
BKRIV Enthusiast
 | Subject: Re: windshield washer fluid bottle Fri Jan 14, 2011 6:28 pm | |
| Came across an old post where Ryan from Ohio was going to change a windshield squirter pump...I am looking for a write-up...anyone out there done this that can offer any suggestions, not looking forward to pulling off fender liners and dealing with plastic clips...I'm going out now (UGH it's 22 degrees) to check the fuses and keep my fingers crossed thats all it is. | |
Name : Mark Age : 58 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3104 Merit : 104
 | Subject: Re: windshield washer fluid bottle Fri Jan 14, 2011 7:11 pm | |
| It may just be frozen... it doesn't get engine heat out there (the dummies!)
Don't mess with it until you can garage the car for a while. | |
sburch23 Addict
 | Subject: Re: windshield washer fluid bottle Fri Jan 14, 2011 8:26 pm | |
| Last winter my sprayer quit as well. Turned out it was just a hose that had come loose at the very bottom. | |
BMD Aficionado
 | Subject: Re: windshield washer fluid bottle Fri Oct 28, 2011 12:21 pm | |
| Getting an intermittent spray from my washer fluid. Meaning, it works normally when it does work or not at all. Will check to see if any hoses have gotten loose. Otherwise is it the pump itself or something else? | |
 | Subject: Re: windshield washer fluid bottle Fri Oct 28, 2011 1:34 pm | |
| What's the temperature outside, and what type of washer fluid are you using? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
BMD Aficionado
 | Subject: Re: windshield washer fluid bottle Fri Oct 28, 2011 8:17 pm | |
| Temps today were about 10C above zero and the fluid is generic brand that I have always used that is rated for -45C. | |
BMD Aficionado
 | Subject: Re: windshield washer fluid bottle Fri Nov 11, 2011 7:16 pm | |
| OK, I replaced the windshield fluid pump but intermittent problem persists. Just wondering, how do the spray nozzles comes off? I removed the screws but they still won't come off, whats the trick? | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8518 Merit : 181
 | Subject: Re: windshield washer fluid bottle Fri Nov 11, 2011 7:19 pm | |
| - BMD wrote:
- OK, I replaced the windshield fluid pump but intermittent problem persists. Just wondering, how do the spray nozzles comes off? I removed the screws but they still won't come off, whats the trick?
You sure this is not an electrical problem? Going from Working to Nothing might be intermittent switch? | |
BMD Aficionado
 | Subject: Re: windshield washer fluid bottle Fri Nov 11, 2011 9:28 pm | |
| That would be my next step, just wanna see if the nozzles need some cleaning out. Any ideas how to remove them. | |
 | Subject: Re: windshield washer fluid bottle  | |
