| Freezing Washer Fluid Concerns | |
+5playa Mr.Riviera Eldo AA beninohio 9 posters |
beninohio Rookie
Name : Ben Johnson Joined : 2009-11-04 Post Count : 16 Merit : 0
 | Subject: Freezing Washer Fluid Concerns Tue Jan 12, 2010 11:28 pm | |
| Oh yeah, and my windshield sprayer which was working started working yesterday morning then quit, meaning...I can hear the pump but no spray. I'm not familiar with how it works, or if it could have frozen or something? Very well could be unrelated to the SEL, but not sure.
Thanks, Ben | |
 | Subject: Re: Freezing Washer Fluid Concerns Tue Jan 12, 2010 11:53 pm | |
| This is just frozen fluid in the lines. Mine's the same way, and won't change until we go above freezing tomorrow or the next day. It is almost certainly not related to your SES light.
Once the fluid is thawed, try adding some winter washer fluid with antifreeze. Next time it shouldn't freeze up on you. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
Name : Mark Age : 58 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3104 Merit : 104
 | Subject: Re: Freezing Washer Fluid Concerns Wed Jan 13, 2010 12:16 am | |
| Aaron is right. Remember, the fluid is very cleverly pumped from the frigid nether-regions of the wheel well, not the temperate climate beneath the bonnet... | |
beninohio Rookie
 | Subject: Re: Freezing Washer Fluid Concerns Wed Jan 13, 2010 8:27 am | |
| Okay, thanks. I'll wait for it to warm up and hopefully it will be good. I literally just added some new fluid, but forget if it has antifreeze...and it didn't have time to get through the lines I'm sure. | |
Name : Matthew Age : 36 Location : Florida Joined : 2007-01-17 Post Count : 4394 Merit : 101
 | Subject: Re: Freezing Washer Fluid Concerns Wed Jan 13, 2010 11:12 am | |
| Yours is most likely just frozen, but for anyone with the same problem in non cold areas...also make sure the line from the motor to the sprayer isnt cracked. mine were a little dry rotted and finally cracked one day. i was just pumping washer fluid all over the motor and belts A little electrical tape and she works w/out a problem now. my break was right past the resov before i goes to the firewall. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
playa Fanatic
Name : Mark Age : 45 Location : Newberg, OR Joined : 2009-03-17 Post Count : 392 Merit : 11
 | Subject: Re: Freezing Washer Fluid Concerns Wed Jan 13, 2010 2:17 pm | |
| You know, when I've dealt with this issue on the Riviera, there's a "T" section in the line that leads out to the sprayers. Anyway, it's fitted on there and over time, I guess pressure was such that it loosened up and I washed my motor. I just gorilla glued in place and the problem was fixed.
That said, if you don't see fluid all over the motor, there could also be the possiblility that mold have accumulated in the lines and the best way to cure that is to take an air hose, siconnect the lines and blow them out. Living in the northwest, we're familiar with mold and mildew and i've see that be the case on more than one occasion | |
 | Subject: Re: Freezing Washer Fluid Concerns Wed Jan 13, 2010 2:51 pm | |
| Try it now. Bet it works. Mine did! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
beninohio Rookie
 | Subject: Re: Freezing Washer Fluid Concerns Thu Jan 14, 2010 10:02 pm | |
| Yep, above 32 and working today! Gonna put in some better fluid. | |
 | Subject: Re: Freezing Washer Fluid Concerns Thu Jan 14, 2010 11:27 pm | |
| - beninohio wrote:
- Yep, above 32 and working today! Gonna put in some better fluid.
You can always dump that rotgut pint of Popov vodka over the fridge in there for antifreeze...  | |
GMFreak8 Addict
Name : Kyle Age : 34 Location : Malone, New York Joined : 2009-03-15 Post Count : 638 Merit : 15
 | Subject: Re: Freezing Washer Fluid Concerns Fri Jan 15, 2010 7:03 pm | |
| - Eldo wrote:
You can always dump that rotgut pint of Popov vodka over the fridge in there for antifreeze...  I wonder if Vanilla Schnapps would work... I haven't touched the bottle of that crap in my fridge since "the incident"... | |
 | Subject: Re: Freezing Washer Fluid Concerns Wed Mar 24, 2010 10:44 pm | |
| While checking out pix of the '05 PA exhaust, I thought of something else - Have any of you 'northern folk' looked at adapting the heated washer-fluid system to your cars? | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8518 Merit : 181
 | Subject: Re: Freezing Washer Fluid Concerns Wed Mar 24, 2010 10:47 pm | |
| - Eldo wrote:
- While checking out pix of the '05 PA exhaust, I thought of something else - Have any of you 'northern folk' looked at adapting the heated washer-fluid system to your cars?
have not looked at heated washer fluid system and have *never* had the washer jets freeze up. I suspect their location on the cowl does not hurt. Albertj | |
 | Subject: Re: Freezing Washer Fluid Concerns Wed Mar 24, 2010 11:33 pm | |
| - albertj wrote:
I have not looked at heated washer fluid system and have *never* had the washer jets freeze up. I suspect their location on the cowl does not hurt.
Albertj The heater is not for frozen jets, but rather for the ice on your windshield... I admit that it sounds like a recipe for a cracked windshield, but evidently they control the temperature precisely. On the other hand, "ne-ver-mind"... http://jalopnik.com/5043596/gm-recalls-950000-vehicles-for-heated-washer-fluid-problems | |
 | Subject: Re: Freezing Washer Fluid Concerns Wed Mar 24, 2010 11:40 pm | |
On the other hand, "ne-ver-mind"... http://jalopnik.com/5043596/gm-recalls-950000-vehicles-for-heated-washer-fluid-problems In the fall I switch to a -20 antifreeze windshield fluid mix. Alternatively you can put in one or another of the washer fluid additives that claims melting ice. Albertj | |
Sweepspear Fanatic
Name : Dale Age : 61 Location : Minneapolis, MN Joined : 2008-11-04 Post Count : 386 Merit : 11
 | Subject: Re: Freezing Washer Fluid Concerns Thu Mar 25, 2010 9:53 am | |
| I use straight washer fluid year 'round. I've never had it freeze on me. Not in the lines or nozzles.
Many years ago I worked at one of those quick lube places. They bought washer fluid concentrate in 55 gal drums. I used it straight, undiluted, and wow did that cut through the ice! | |
 | Subject: Re: Freezing Washer Fluid Concerns Thu Mar 25, 2010 10:14 am | |
| I only use the subzero stuff in the winter. Usually there is an ingredient such as ethanol or methanol in the winter stuff that I don't like spraying all over the paint and rubber parts of the car year round. So I only use it 2-3 months out of the year. Once it starts warming up, I use the Rain-X stuff for the rest of the year, which is good to 32ºF - but it freezes (it has) easily in winter. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
Name : Dave Age : 62 Location : In The AZ Oven Joined : 2007-01-17 Post Count : 4502 Merit : 44
 | Subject: Re: Freezing Washer Fluid Concerns Thu Mar 25, 2010 4:17 pm | |
| I suspect you'd be much better off running washer fluid in winter that will protect from freezing down to what you normally expect for low temps. Fluids freezing in a pump... not usually a good thing. | |
GMFreak8 Addict
 | Subject: Re: Freezing Washer Fluid Concerns Sat Apr 03, 2010 10:44 am | |
| I can attest to fluid freezing in the washer system not being a good idea. My father had the regular mix in his Suburban and it got down to about -10 one night and that did the trick. Froze solid and cracked the tank, and the lines. | |
 | Subject: Re: Freezing Washer Fluid Concerns  | |
