 FAQ: Cruise Control Problems
ironclyde
billfrank85
bmcd9179
werdstrave
jbeganny
akh
Neal H.
cragmor
22 posters
billfrank85
FAQ: Cruise Control Problems - Page 4 Empty
PostSubject: Re: FAQ: Cruise Control Problems   FAQ: Cruise Control Problems - Page 4 EmptySat Sep 27, 2014 7:42 pm
Letting the EGR valve cool off. I can shake it up and down and hear something moving inside, sort of how when you shake a working PCV valve. Sounds like something is sliding ever so slightly. Is this normal?
sloshua
sloshua
PostSubject: Re: FAQ: Cruise Control Problems   FAQ: Cruise Control Problems - Page 4 EmptySun Sep 28, 2014 1:24 am
for u bill http://easyautodiagnostics.com/gm/4.3L-5.0L-5.7L/egr-valve-tests-1
ironclyde
ironclyde
PostSubject: Re: FAQ: Cruise Control Problems   FAQ: Cruise Control Problems - Page 4 EmptySun Sep 28, 2014 3:33 am
I've never done a "shake test" on an EGR. I think the pintle moves on an EGR valve pretty freely. It might make a slight thumping noise on the base of the EGR valve, if you shake it like a PCV.
billfrank85
PostSubject: Re: FAQ: Cruise Control Problems   FAQ: Cruise Control Problems - Page 4 EmptySun Sep 28, 2014 5:38 pm
Cleaned EGR very well and replaced gasket...still no change.
PostSubject: Re: FAQ: Cruise Control Problems   FAQ: Cruise Control Problems - Page 4 EmptySun Sep 28, 2014 7:11 pm
This Actron will read almost everything you need for diagnosing your Riv and works with all OBD2 vehicles as well. If you plan on keeping your Riv for awhile, it's about the best investment you can make and you won't find a NEW one cheaper
billfrank85
PostSubject: Re: FAQ: Cruise Control Problems   FAQ: Cruise Control Problems - Page 4 EmptySun Sep 28, 2014 7:24 pm
I don't see a link or anything.
PostSubject: Re: FAQ: Cruise Control Problems   FAQ: Cruise Control Problems - Page 4 EmptySun Sep 28, 2014 7:39 pm
Oh wow, sorry
http://m.ebay.com/itm/191350331854?nav=SEARCH
buickhunter
buickhunter
PostSubject: CRUISE CONTROL QUESTION FOR 96-88 Rivieras.   FAQ: Cruise Control Problems - Page 4 EmptySat Oct 18, 2014 11:17 pm
Did anyone else have this symptom, and did you find the cause...
Cruise Control engages above 25 MPH and will remain engages for 3-5 minutes, but will disengage thereafter. It will then re-engage after 5-10 minutes, whether the car is running on the road or parked with the engine of.
This happens to me regardless of road bumps. It does not seem to be a brake switch, ignition switch, transmission selector switch, or Cruise switches since I can jiggle each of these and not cause a disengagement. I suspect this is a bad Cruise Control Module as it seems that a part within the module gets hot during engagement and fails, and needs to cool off before it will work again. Thoughts? Thanks - Hal
buickhunter
buickhunter
PostSubject: Re: FAQ: Cruise Control Problems   FAQ: Cruise Control Problems - Page 4 EmptyMon Oct 20, 2014 12:14 am
Problem solved. It was a bad cruise control module.
» Intermittent Cruise Control
» how to toubleshoot cruise control
» Control Arm Bolt 25604378 Lower Control Arm
» Welcome,and need help. No overdrive or cruise
» Shakedown cruise #2
