| Horrible screeching / squealing noise - help! | |
+51995 Riv Chicken AA ibmoses Buapo 9 posters |
Buapo Addict
Name : Ben Age : 39 Location : Eastlake, OH Joined : 2007-07-17 Post Count : 691 Merit : 2
| Subject: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 12:38 am | |
| Hey guys.
Don't know what to say about this problem exactly. It has me worried.
I heard a very strange scraping noise which I identified as snow built up in my wheel wells. Soon after, I notice that anything more than very light throttle causes an very LOUD screeching or squealing noise. Sounds like it's a belt, but also sounds like it could be coming from the supercharger, I have no idea.
I shut the car down, started it back up, and got the squealing at start, then it goes away. Any gas makes the screech. Shut it down, start it back up, and it has the screech again. I give it a decent amount of gas, and my LIGHTS start to go dim, sounds AWFUL.
Could this be the alternator going bad or something? I thought I heard some strange belt noise before, but now I'm not really sure of anything.
I dunno, if you guys could just give me a starting point.
Oh! The sound is almost like when you start the car, and then you don't think it's started and you try and start it again, making that horrible screeching.
Well, that's all the info I can provide. Thanks for any help. | |
ibmoses Aficionado
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 7:19 am | |
| Sounds like it might be a idler/tensioner pulley about to grenade. But if the lights are dimming that points to the alternator as a possible culprit. If you can let it run long enough to get good and warmed up,after you shut it down feel of all the pulleys to see if one of them is very hot. Bert | |
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 9:34 am | |
| I agree. How many miles on the car? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Chicken Aficionado
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 11:41 am | |
Buapo Addict
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 12:22 pm | |
| Lord.
So anyway, the car has 66k on it.
I drove it to my mechanic and we took a look under the hood - sure enough, there's NO tensioner pulley. It's gone, and the bearing is just sitting there.
Yeah, so you guys were right. Should be a cheap fix. | |
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 1:34 pm | |
| That's the earliest I've heard of one failing. Usually they last to 85k at least. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
1995 Riv Enthusiast
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 1:44 pm | |
| Maybe the belt was was too tight, do you think? | |
Buapo Addict
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 5:09 pm | |
| I can't believe you guys nailed it.
Regarding comments from AA and 1995 Riv:
1. I replaced the tensioner pulley with the ZZP aftermarket one. It might not have been all that great, considering it only lasted about 10k miles. 2. The belt might have been too tight, making too much stress on the bearing causing it to eventually fail.. I can't remember if I got the smaller belt for the 3.4" pulley, I may have. And foolishly I also went with the 3.5" tensioner pulley - this would definately cause the belt to be too tight.
So I don't know for sure, but these are both good guesses. Heh, you guys are like detectives with this stuff!
I think this is also why I was losing power to my accessories. The belt was losing tension on the alternator causing it to not spin much, if at all. At least that's my guess.
I'm just really glad that the pulley didn't jam in the other pulleys and something REALLY bad to happen.
So the repair was only $50, and it now has the stock-sized tensioner pulley on there. Guess we'll see how it does! Thanks guys. | |
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 5:53 pm | |
| Hold up for a second... which tensioner pulley failed? The SC side or the accessory belt side? I assume you replaced the tensioner pulley for the SC belt, so that shouldn't affect the alternator or anything else.
Assuming you replaced the tensioner pulley, I'll buy into that ZZP tensioner pulley being bad product, but I don't think the added belt tension caused it. The pulley was crap - it failed. I got mine from INTENSE, which is OEM GM 3.5" tensioner pulley, and it's been on the car well over 100k miles, maybe 150k even.
I've had other pulleys frag, but that GM 3.5" tensioner pulley is good stuff! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 5:56 pm | |
| Aaron, Is the GM OEM 3.5" plastic or steel ? | |
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 6:01 pm | |
| Steel, just like the stock one. it's just bigger in dia. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 6:07 pm | |
| Shoot, I just ordered a new 3.5" tensioner pulley and i don't think i asked for steel. I guess I'll just put this one on the shelf and order one from Intense the next time i make an order from them. i don't need it right away, just trying to get all my stuff together for when I install the GenV and 3.4" MPS. | |
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 6:25 pm | |
| You could also try GM parts direct. I think it's a $20 item.
A plastic tensioner pulley is pretty odd, imo. All of the smooth pulleys are usually steel because they contact the flat side of the belt. The idlers are sometimes plastic because they need to be grooved, but I've never heard of a smooth plastic tensioner pulley. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 6:33 pm | |
| I was ordering some other stuff from Wbody store and noticed the oversized sc tensioner pulley.for 23.00. They have an option for steel or plastic and I made the order without checking off the steel option. My mistake. I didn't notice my error until I got shipping confirmation from them. I at least got free shipping and a complete 3.4" MPS for $65.00. | |
Buapo Addict
| Subject: Re: Horrible screeching / squealing noise - help! Thu Jan 15, 2009 9:07 pm | |
| Well, now I feel like an idiot.
The tensioner pulley that went toast was the accessory side for sure. I actually didn't know we had two tensioner pullies. The 3.5" tensioner for the supercharger was definately steel, and I guess it's still fine. The stock accessory tensioner is the one went bad. But this raises the question - if the stock one went bad, how did a STEEL PULLEY go missing? Can it seperate from the bearing or what? Anyway who knows what happened. Any guesses? | |
| Subject: Re: Horrible screeching / squealing noise - help! Fri Jan 16, 2009 9:13 am | |
| - Buapo wrote:
- But this raises the question - if the stock one went bad, how did a STEEL PULLEY go missing? Can it seperate from the bearing or what? Anyway who knows what happened. Any guesses?
The pulley fell out without hitting anything? The belt can't be 'overtensioned' because of the spring loaded tensioner. It's spring loaded to maintain the same tension at all times. The whole pulley thing has been discussed thousands of times for the 3800s. This shouldn't be a big surprise. The big surprise is the cheapo bearing in the ZZP pulley, that surprises me. I don't remember where the threads are with the part numbers, but just get the aftermarket Dayco pullies. They are steel and have good bearings. | |
| Subject: Re: Horrible screeching / squealing noise - help! Fri Jan 16, 2009 9:43 am | |
| Did the ZZP pulley fail? Is it a fact they use cheap bearings.? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Horrible screeching / squealing noise - help! Fri Jan 16, 2009 9:51 am | |
- Did the ZZP pulley fail? Is it a fact they use cheap bearings.?
Sorry, my impression from the OP was that the ZZP pulley failed after 10K. If that's not the case please correct me. | |
Buapo Addict
| Subject: Re: Horrible screeching / squealing noise - help! Fri Jan 16, 2009 2:16 pm | |
| Okay everyone: ATTENTION! At first I thought it was the ZZP 3.5" tensioner pulley that failed. I WAS WRONG. It was actually the STOCK ACCESSORY tensioner pulley, not the supercharger tensioner pulley. My previous post for those who overlooked it: - Quote :
- The stock accessory tensioner is the one went bad.
I don't want ZZP to get any flack about a bad product (again), because they don't deserve it this time. It was a lack of knowledge on my part - I didn't realize we had TWO tensioner pullies (which makes sense because we have two belts... I just didn't think of it). So to recap - it was my stock accessory pulley that went bad, not the ZZP supercharger tensioner pulley. The ZZP 3.5" steel tensioner is still attached to its appropriate location, and working just as well as it did when I first put it on 10k miles ago. No problems in sight. Still have no idea how I lost a stock steel pulley. But the bearing was definately locked up, so who knows how that happened. And YES, there is no trace of the pulley. I have no idea where it went, but I guess it didn't damage anything on its way out because everything else seems to be just fine. | |
#1BearsFan Enthusiast
Name : Bill Location : North Carolina Joined : 2008-07-28 Post Count : 231 Merit : 4
| Subject: Re: Horrible screeching / squealing noise - help! Fri Jan 16, 2009 2:23 pm | |
| I love a happy ending....... | |
Chicken Aficionado
| Subject: Re: Horrible screeching / squealing noise - help! Fri Jan 16, 2009 3:03 pm | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8622 Merit : 180
| Subject: Re: Horrible screeching / squealing noise - help! Fri Jan 16, 2009 4:06 pm | |
| OK Chicken - is the pic of the cat before or after the screeching?
| Subject: Re: Horrible screeching / squealing noise - help! Fri Jan 16, 2009 5:28 pm | |
| - Buapo wrote:
- Okay everyone: ATTENTION!
At first I thought it was the ZZP 3.5" tensioner pulley that failed. I WAS WRONG. It was actually the STOCK ACCESSORY tensioner pulley, not the supercharger tensioner pulley. That's cool, sorry I misread. I'm glad to hear I was wrong. -Derek | |
| Subject: Re: Horrible screeching / squealing noise - help! Fri Jan 16, 2009 6:54 pm | |
| Chicken, How did you get your pussy to smile like that.
Great photo, but tell us how.......... | |
1995 Riv Enthusiast
| Subject: Re: Horrible screeching / squealing noise - help! Sat Jan 17, 2009 2:06 am | |
| Does this mean the bearing was frozen to the shaft or just the shaft was tore up Ben? | |
| Subject: Re: Horrible screeching / squealing noise - help! | |
