ehowell11 Special
Name : Eric Age : 35 Location : upland Joined : 2009-01-31 Post Count : 4 Merit : 0
| Subject: performance for my rivi Mon Feb 09, 2009 4:36 pm | |
| i have a 1997 rivi and im looking to put some more horsepower under the hood. anyone with some suggestions??? | |
| Subject: Re: performance for my rivi Mon Feb 09, 2009 4:52 pm | |
99prixgt Member
Name : Erik Age : 37 Location : NJ Joined : 2009-01-27 Post Count : 90 Merit : 2
| Subject: Re: performance for my rivi Mon Feb 09, 2009 9:34 pm | |
| intake, pcm, plog or headers, 180* t-stat, colder spark like autolite 104's just some ideas to start with. | |
| Subject: Re: performance for my rivi Mon Feb 09, 2009 10:00 pm | |
| - ehowell11 wrote:
- im looking for any kind of performance for my 97. looking for some cheaper mods.
You could start with some rockers, a MPS pulley setup with a 3.5" pulley. If you want to put a cam in it (lots of labor) it's an even better place to start, and skip the rockers. The cam itself is not the expensive part... You could throw a PCM on it, they go for $99 from Intense racing. Rockers can be had used for reasonable prices on clubgp and the like, but you should use new springs IMO if/when you put rockers in it. A better idea is to come up with a performance goal or plan. Then you can figure out what parts you will need and start with the ones that will help you most. I will warn you like I warn all noobs - don't start by dropping the pulley size or you will have KR problems and can quite possible do some damage. A lot of people have been lucky, and quite a few have not and end up with a chunk coming out of a piston. | |
| Subject: Re: performance for my rivi Mon Feb 09, 2009 10:06 pm | |
What's your budget? "Cheaper" can have a lot of different meanings. | |
TonySmooth89 Aficionado
| Subject: Re: performance for my rivi Tue Feb 10, 2009 9:57 am | |
| For a cheap and easy handling mod , look up Strut tower brace write up. For about 35 bucks and some labor ( took me like an hour , some years require more work than others) it delivers a nice improvement in handling and ride. | |
| Subject: Re: performance for my rivi | |
