 95 Riv sprays rust from washer
Rivit
Graymodeler
7 posters
Graymodeler
95 Riv sprays rust from washer Empty
PostSubject: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptyFri Apr 03, 2009 10:11 am
I noticed a rusty spray over the greenhouse of my wife's Riviera and started to ask her who she was following - bad move! Actually if you get rusty spray from the windshield washer, remove the bottle and check the lower outlet. There is a STEEL colar inside for reinforcement that begins to rust. Work this out with a screw driver, clean and flush the system and the problem goes away. Who designed that thing? rabbit Greg
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptyFri Apr 03, 2009 10:39 am
good find!
Rivit
Rivit
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptySat Mar 08, 2014 1:30 am
Removed my wash reservoir tank and this is what I found: afraid
95 Riv sprays rust from washer IMG_013495 Riv sprays rust from washer IMG_013695 Riv sprays rust from washer IMG_013595 Riv sprays rust from washer IMG_013795 Riv sprays rust from washer IMG_0138
Total rust obstruction, Yuck. Hadn't ever used the spray and wipers. Kept the tank full and only discovered it plugged when dismounting reservoir for engine bay detailing.Scraped out, wire brushed out, flushed out. With the tank full of wash fluid, you do not notice this rust issue. Yikes, awful design. I left what was left of the pipe for fear of breaking the plastic fitting if I tried to pry it out. Will be keeping an eye on this.
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptySat Mar 08, 2014 1:38 am
Shit.....
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptySat Mar 08, 2014 6:03 am
Yeahah!!! Doing this week to mine haha Lookin forward to that plugged artery
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptySat Mar 08, 2014 12:58 pm
Using the spay feature on a regular basis is good for the system. I've never noticed any problem with mine. It gets used at least once a month.
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptySat Mar 08, 2014 1:52 pm
I use mine all the time but I do know that little metal ring needs to come out for a new one as the whole reservoir is stained orange at this point.
Rivit
Rivit
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptySat Mar 08, 2014 9:27 pm
AA and Evan are right!  rock  Use it or loose it. Here's a "as clean as it got" pic. Wire brush cleaning shows metal sleeve insert. Further note, there's a second tank containing the actual pump, inside/below the front passenger wheel well. I cleaned it via a jury rigged wet vac attachment and then swabbed it out with a flex wire gun bore rod, without having to remove the wheel and plastic wheel well. Lower tank and connection hose didn't seem affected by the sleeve decay. whew. Sprays normal (up over the roof top) now.  yay
95 Riv sprays rust from washer IMG_20140307_161250_379
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptySat Mar 08, 2014 9:57 pm
[/img][/url]
Now ain't that the truth  rolleyes
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptyMon Mar 10, 2014 10:55 am
llamalor2112 wrote:
[/img][/url]
Yeah it's like they only ever intended the washers to be used at highway speed. Never around town.
I always liked the "on the wiper arm" design that GM was using for many years. Never had a problem with them except occasionally ice buildup would pop the hose off. Then you'd get the 'straight away' spray out over the hood from one of your washers. But the coverage was always good.
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptyFri Apr 04, 2014 5:30 pm
Alright, a bit delayed on my end here but finally got around to this today aaaaaaand no blockage, well...maybe a little rust clumpage, BUT get this. The little metal sleeve I was prepared to clean up is was so rusted and deteriorated that...well, there's actually no metal ring in there at all  shocked So I figure I should find a replacement ring...now for the hard part in trying to find a parts number or suitable replacement. sigh...
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptyFri Apr 04, 2014 6:22 pm
Can you just live without it?
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptyFri Apr 04, 2014 6:53 pm
I'm wondering but I gotta figure the reason its there to begin with is to help seal the fluid exit and keep the clamp from crunching the plastic wall
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptySat Apr 05, 2014 9:18 pm
I wonder if you could find a piece of thick rigid plastic pipe that could do the job instead of the metal ring.
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptySun Apr 06, 2014 3:51 am
^most likely what I'll be lookin for. Res isn't goin back on the car yet anyhow. Could NOT get it to clean up from the rusty orange color it has adopted. Gonna give it another wack tomorrow.... coming close to bleaching the dang thing.
95 Riv sprays rust from washer IMAG0700_zps52e255b3
And here's how little is left of that ring..
95 Riv sprays rust from washer IMAG0705_zps8242c5b1
Rivit
Rivit
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptySun Apr 06, 2014 10:40 am
Evan, I think you can just get rid of what's left, clean up the tank and reinstall. A glued replacement 3/4" outside diameter plastic sleeve could be substituted but in my opinion not necessary.  After finding mine as clogged as it was (photo 1) I cleaned as best I could and reinstalled (photo 2). A couple of weeks later I re-inspected and didn't like what was happening (photo 3) so yanked that darn metal sleeve out like a a bad tooth (picture 4) and reinstalled without any substitute support sleeve.
95 Riv sprays rust from washer IMG_0138afraid 95 Riv sprays rust from washer IMG_20140307_161250_37995 Riv sprays rust from washer IMG_001395 Riv sprays rust from washer IMG_0016-195 Riv sprays rust from washer IMG_0021-195 Riv sprays rust from washer IMG_0020
I suspect everyone's sleeve is rusting or has totally rusted out without resultant collapse at the hose fitting. OH, and I did the kitty litter cleaning thing along with a bunch of Ajax, shake rattle and roll with great results. yay
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptySun Apr 06, 2014 10:13 pm
I wonder if people just using straight water (or a mix) versus washer fluid see this rust out more/faster?
In other words, I wonder if the sleeve was designed to not rust when submerged in washer fluid? I find it hard to believe they would have used a plain steel ring if was planned to be exposed 100% of its life to a liquid that will rust it out  dunno
I don't put water in washer reservoirs.
Rivit
Rivit
PostSubject: Re: 95 Riv sprays rust from washer   95 Riv sprays rust from washer EmptyMon Apr 07, 2014 12:00 am
[quote="al_roethlisberger"]
... I wonder if the sleeve was designed to not rust when submerged in washer fluid?  I find it hard to believe they would have used a plain steel ring if was planned to be exposed 100% of its life to a liquid that will rust it out   dunno
Al, I wondered the same thing so conducted a kitchen experiment with my now removed metal sleeve:
95 Riv sprays rust from washer IMG_0029-2
Two weeks later:
95 Riv sprays rust from washer IMG_0003-1
95 Riv sprays rust from washer IMG_0010-1
95 Riv sprays rust from washer IMG_00131
95 Riv sprays rust from washer IMG_00151
I have no idea if the pink washer fluid corrodes at the same rate as the cheaper blue stuff, or even at all? I'd figure they all rust and most metal support sleeves have likely already rusted virtually away, un-noticed and with no harm done aside from a dirty reservoir tank. Use it or lose it as stated and if it don't work, here's a possible cause and simple fix. Get rid of it!
» Washer Pump location?
» FAQ: Rust Areas & Concerns
» Freezing Washer Fluid Concerns
» Windshield Washer System
» Rear subframe rust
Riv Performance ::   General Tech :: Engine Bay-
