| Grumble when turning right at low speeds | |
DEMonte1997 Aficionado
Name : Rick Age : 44 Location : CT Joined : 2009-03-03 Post Count : 1429 Merit : 37
 | Subject: Grumble when turning right at low speeds Tue May 12, 2009 11:29 am | |
| I'm trying to figure out what is causing this. I don't think it's the rack. If I'm turning right at about 15-20mph I'll hear a growl or grumble from the left side of the car. It's not a hum or whir that you'd associate with a bad wheel bearing but I haven't ruled that out. I've put new tires on and the sound remains. It also doesn't seem to grumble as much when the tires have higher air pressure in them.
So my two thoughts are:
-wheel bearing -strut mount
Just curious what everyone else thinks. | |
Name : Derek Age : 50 Location : Reading, MA Joined : 2007-01-31 Post Count : 7717 Merit : 109
 | Subject: Re: Grumble when turning right at low speeds Tue May 12, 2009 11:41 am | |
| CV joint - see if it changes if turning under forward load vs turning under no load vs turning under decel load... | |
98riv Moderator
 | Subject: Re: Grumble when turning right at low speeds Tue May 12, 2009 12:28 pm | |
| I don't mean to hijack your thread Rick, but I just noticed something similar on my car a few weeks ago and was also wondering what it could be. On mine, it seems to make a louder noise when you are accelerating through the corner. Also the tighter the corner, the louder the noise. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
BMD Aficionado
 | Subject: Re: Grumble when turning right at low speeds Tue May 12, 2009 7:11 pm | |
| I would heed Dereks advice, he seems to be quite knowledgeable. But if it's not the CV joint. I would look at the struts and or mounts next. Mine didn't have a growl or grumble but more like a door creak when I turned. It stopped when I changed the mount and struts. | |
98riv Moderator
 | Subject: Re: Grumble when turning right at low speeds Tue May 12, 2009 7:19 pm | |
| I checked it today and it seems to only do it when I make tight right hand turns while accelerating. Would that be a cv joint or something else? _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
Name : Rick Location : Lancaster, MA Joined : 2008-09-13 Post Count : 6281 Merit : 117
 | Subject: Re: Grumble when turning right at low speeds Tue May 12, 2009 9:55 pm | |
| Solution: Only make left hand turns........J/K,
You could have a front end shop diagnose it for free if they think they will get the job. Hard to impossible to diag. noises on the internet. | |
 | Subject: Re: Grumble when turning right at low speeds Tue May 12, 2009 10:35 pm | |
| - 98riv wrote:
- I checked it today and it seems to only do it when I make tight right hand turns while accelerating. Would that be a cv joint or something else?
Either CV joint or wheel bearing. Hard to tell without hearing it firsthand. You should check the wheel bearing for play - jack the car so the wheel is off the ground, then grab the top and bottom of the tire and pull in/out back and forth and you'll notice if the end play is very bad. With a new wheel bearing, I can get the wheel to move in and out a tiny amount, but with a bad wheel bearing, you would get a hefty movement and maybe even a clunk when you do it. Any chance you can make a video of it? Have somebody outside the car and do it next to them in a parking lot? | |
 | Subject: Re: Grumble when turning right at low speeds Wed May 13, 2009 10:30 pm | |
| I might try and get a vid of mine. It seems to do it regardless of decel, accel or anything. Only when making a turn past the halfway point (i guess you would classify it as a tight turn) at around 15 mph. | |
 | Subject: Re: Grumble when turning right at low speeds Thu May 14, 2009 6:34 am | |
| Rick, I'm thinking bearing for you. Is your trac/ABS light on? | |
 | Subject: Re: Grumble when turning right at low speeds Thu May 14, 2009 9:56 am | |
| It is. I got a used one from Ed and plugged that one into both hubs up front but the light stayed on which made me think there is an issue with both hubs or something with the traction system itself. I just pulled the bulb from the dash because it's useless, IMO. lol I'm going to put the used hub on that side and see if it helps. | |
 | Subject: Re: Grumble when turning right at low speeds  | |
