 Noises when turning right
2 posters
Mikel
Noises when turning right Empty
PostSubject: Noises when turning right   Noises when turning right EmptyWed Feb 06, 2013 12:37 pm
Hello,
My 97 Riviera makes two distinct noises when turning right:
- When the steering wheel is being turned to the right while making a turn, I hear a sort of rubbing noise. This stops once the steering wheel stops turning. Nothing obvious rubbing anywhere.
- When applying power while making a right turn (and only right), I hear a sort of humming noise. This goes away when I lift my foot off the accelerator.
Interestingly, my previous Riviera behaved in exactly the same way. Any suggestions?
Thanks,
Mikel
PostSubject: Re: Noises when turning right   Noises when turning right EmptyWed Feb 06, 2013 1:43 pm
Could be the left front hub/wheel bearing starting to fail. How many miles on your car? Have the front hubs ever been replaced?
To check: lift front end of car and rock front wheels up & down (12-6 o'clock) if the left wheel has more play, or feels loose, replace the hub.
Buy Timken or AC/Delco quality parts for longest life. Price: around $130 per hub. I would not replace both sides unless they both feel loose. The other side will follow suit, but could be thousands of miles before that time.
Mikel
PostSubject: Re: Noises when turning right   Noises when turning right EmptyWed Feb 06, 2013 1:54 pm
Hello,
115K on the car, with original hubs, as far as I know. I will check them for play.
Thank you.
» new noises ?
» MORE NOISES!
» squeeky noises
» 96 Pop in steering when turning the wheel
» Torque Steer and other various noises!
