NP. I was thinking you might have a parts guy you use regularly who might lend you a spent compressor as a favor. It's all iffy, but might be easier and cheaper than the delete kit. You may get a whacky sound from the replacement, but it may also eliminate the current bug. Just a thought. Good Luck.
Name : Aaron Age : 47 Location : C-bus, Ohio Joined : 2007-01-13Post Count : 18452 Merit : 252
Hmmm, it's a theory, but I don't recall ever hearing of belt rotation as an issue before. Still, if it's an easier path and you buy it, it may be worth the effort. Have you researched this theory? If it's not too humbling and you have a pic 'n pull around, they may still lend you what is essentially a piece of scrap to them, to secure a future customer. Any way it goes, it's one of those annoying issues you will either throw money or time at to resolve.
Before I snooze: Belts apparently do need to go back in the same rotation, usually marked with a directional arrow. Can't say that is your issue, but possible. Apparently older belts can disintegrate if backwards. Yours are newer. That said, I also read something about a cam sensor that can sound very much like a belt issue. This was a Ford product issue, so I just toss that out for thought and to add to the hysteria I think you know what to do.
I don't think it's misalignment. I think it's slippage. Hopefully, the water test will tell!
Another interesting video from Dayco. There's a part around 2:20 about "Tension decay, from belt relaxation or actual stretch."
I think I have a larger smooth pulley in the garage. Maybe swapping it on will increase tension, and make the noise go away. Will do some tests tomorrow.
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Thu Aug 02, 2012 1:38 pm
Yesterday I found a slightly larger than stock tensioner pulley and installed on the accessory belt drive. This tightened the tension, and should have fixed the squeal if the belt were slipping. Unfortunately, the sound didn't go away - it got significantly louder and more constant (from chirp to squeal). I could still do the water test, but the result of the idler swap test eliminates the SC belt side, and is telling me to focus back on the AC compressor.
The more I think about it, the more this makes sense, based on this quote from Eldo in the AC compressor write-up thread:
[quote'"Eldo"]What you are describing is a classic idler bearing problem. When the pump is stationary and the pulley/hub is freewheeling, you're hearing the worn-out bearing in the hub. When you engage the clutch, the hub and compressor shaft turn as one, so the idler bearing is no longer turning and no longer making noise.[/quote]
The thing I don't understand is, the noise doesn't change very much when I turn the AC on/off - it's a slight change. Considering there's an idler bearing and a shaft bearing, I don't get it. All I know is, there is noise coming from the AC compressor, and it doesn't appear to be the belt.
There's a local parts yard with a used AC Delco compressor for $75. Think I'm headed there soon.
Name : Larry Age : 68 Location : Oakland Gardens, NY Joined : 2007-01-23Post Count : 2193 Merit : 150
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Thu Aug 02, 2012 1:49 pm
Aaron, We have a number of NIASE mechanics at the hotel. I'll have them look at it and give their opinion. Hope to see you later. I've got your ride in the GN all lined up
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Thu Aug 02, 2012 1:52 pm
Larry, I really appreciate it. Talk with you later.
denim Junkie
Name : Sean Location : Albany, NY Joined : 2011-08-27Post Count : 925 Merit : 33
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Thu Aug 02, 2012 2:32 pm
If you're not yet confident enough of the source of the problem to take down your AC system, consider the temp swap-out I mentioned with the used compressor..
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Thu Aug 02, 2012 2:56 pm
I'm considering it for sure. Need to find out how much room there is to work with.
The curious side of me wants to see how easy it is to pull off the clutch assembly from the used compressor as practice. If it goes well, I could swap it over to my existing compressor on the car and hope for the best.
denim Junkie
Subject: temp Wed Aug 08, 2012 2:11 pm
AA, Did you solve the mystery squeal?
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Wed Aug 08, 2012 2:31 pm
Almost there, tackling this in my spare time. I removed the compressor clutch from a used compressor found at a local yard. Pressing in a new idler bearing tonight. Then will assemble the fresh clutch assembly to the my original compressor (on the car) and hope for the best.
If that doesn't work, it means the internal AC bearing is the problem. In that case, I'll be reassembling the clutch back to the used compressor and replacing the entire unit.
It turns out pulling the clutch/pulley assembly off the compressor is a piece of cake job. Took me about 20 mins with a couple of puller tools.
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sun Aug 19, 2012 1:22 am
Okay, issue solved. Chirp is gone. Problem: user error (me). Solution: under my nose the whole time. Just as the Gates and Dayco videos above both say, it's either slip or misalignment. I ruled out slip, but didn't rule out misalignment.
----> The AC compressor became slightly loose, causing the AC idler pulley to misalign with the belt, creating the chirp. How it loosened I'm not sure. There are 3 nuts securing the compressor to the bracket, and all 3 were spooling off the studs. The compressor was one of the last things I installed when dropping the engine back in, so I'll just accept that they weren't tightened down good enough. Live and learn.
My mistake: assuming the misaligned pulley had to be due to idler bearing. I overlooked the fact that the entire compressor assembly might be misaligned. This was difficult to notice with the accessory belt on, under tension. The nuts didn't appear loose, because the tension pulled the compressor tight up against them. It wasn't until I removed the belt and tried wiggling the AC idler pulley that I noticed the entire compressor bobbling on the bracket. Ugh. At least this didn't cost a lot to fix.
Will reassemble the used AC compressor and try returning it to the yard. Since I did remove the AC clutch and idler pulley, I took some pics and will post a write-up soon.
denim Junkie
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Sun Aug 19, 2012 7:59 am
Great news! Sounds easy to have overlooked. You were always on the right track, so eventually you found the little bastard Eureka
Mattwa Enthusiast
Name : Matt Age : 32 Location : Cleveland, Ohio Joined : 2012-07-02Post Count : 173 Merit : 8
Subject: Belt squeak Mon Jan 28, 2013 1:08 pm
I'm getting a belt squeak from my 97. It's not too loud normally, but it always seems there at cold idle, worse then it's really cold or wet. I just changed both belts, they are new, as well as every single idler pulley. I think it's coming from my P/S pump, you can see the pulley wobble slightly, and it honestly never really sounded that great since I owned the car. Advice/tips?
Thanks Matt
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Mon Jan 28, 2013 1:32 pm
Try the water spray bottle diagnosis: spray water on belt. This will identify which belt. If chirp goes away, it's a pulley alignment issue (wobbly pulley). If noise gets louder, it's the belt slipping (bad belt or pulley not spinning).
charlieRobinson Expert
Name : Charlie Age : 39 Location : Knoxville, TN Joined : 2011-05-17Post Count : 3924 Merit : 31
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Mon Jan 28, 2013 2:03 pm
Where's the thread/image comparing the ribs on the zzp and intense pulleys? I know I've seen it before!
Mattwa Enthusiast
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Mon Jan 28, 2013 2:53 pm
Well here is what just happened. I start the riv today and sprayed water on the belts at idle. Not at chirp or squeak. but then while driving to work it started to constantly squeak with rpm and throttle. Gah. I'm here at work now and while sitting idle if I bring up the RPM's, it really starts to squeak. at idle there is nothing.
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Mon Jan 28, 2013 3:51 pm
Mattwa Enthusiast
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Mon Jan 28, 2013 5:36 pm
No major leaks, no. the coolant elbows are new as well.
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Mon Jan 28, 2013 9:38 pm
Get a piece of hose you can hold to your ear and use it like a stethoscope. Find the source. Could be the alternator, A/C pump, idler pulley, any of the above...
Mattwa Enthusiast
Subject: Re: FAQ: Chirp Chirp Chirp - Belt Squeal, Pulley & Tensioner Squeak Tue Jan 29, 2013 1:46 am
I just drove home from work, and it was constantly slipping the whole way home. I admit it was misting outside and very humid, but it was bad. Not as bad at idle, but at like 1500RPM, even without any load it's like a really fast CHIRP CHIRP CHIRP...etc. Going from sound, it is definitely the accessory belt, and definitely from the P/S and water pump area. After I shut the engine off, I did feel wetness under the return coolant "elbow", but I'm not certain it was coolant as alot of things were wet because of the weather, however, there did seem to be a wide "line" of wetness on the firewall in-line with that belt, so I don't know.
