| FAQ: Sunroof/Moonroof Problems & Adjustment | |
+23gadabout c0reyl Rickw robotennis61 VJD2 #1BearsFan EatDirtFartDust Ironclad-454 98RIV7777 rivboy rivman96 '96reese 99Rivman Chicken ewolfe0050 jimmyriv Mr.Riviera steve1173 Kustom Kreationz albertj AA deekster_caddy ibmoses 27 posters |
ibmoses Aficionado
![ibmoses](https://2img.net/u/3215/30/10/37/avatars/394-10.gif)
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Feb 19, 2008 10:33 pm | |
| Sometimes when the "happy wife" tries to open the sunroof on her 99Riv it wont open until I tap it with my hand at the center/rear of the panel. It looks like it is sticking somehow. I figure the rubber has swollen just a smudge over the years.
:dunno:I am going to lube it up with some spark plug boot grease unless youse guys can offer a better solution...
Thanks for any tips or advice. Bert | |
![Go down](https://2img.net/i/empty.gif) | |
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Feb 20, 2008 6:48 am | |
| At some point I found a weatherstrip rejuvinator/softener that I used. Unfortunately, I lost the bottle and can't find it on the store shelf anymore. I don't know what it was called, but the Riv definitely needs something. The Sunroof and all that door/window weatherstrip should be maintained. | |
![AA](https://2img.net/u/3215/30/10/37/avatars/1-6.jpg)
Name : Aaron Age : 47 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18448 Merit : 252
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Feb 20, 2008 10:04 am | |
| Silicone spray lube. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ ![frown](/users/3215/30/10/37/smiles/icon_sad.gif) | |
ibmoses Aficionado
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Feb 20, 2008 10:35 am | |
- Silicone spray lube.
I hosed it down with the Silicone spray and it still sticks(sometimes), not every time. Perhaps it needs adjusted but I have looked at it pretty hard and dont have a clue ![afraid](https://2img.net/i/fa/i/smiles/affraid.gif) how to go about doing that. Bert | |
![albertj](https://2img.net/u/3215/30/10/37/avatars/149-76.gif)
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8676 Merit : 181
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Feb 20, 2008 2:44 pm | |
| What worked for me: 1) Carefully clean the edge of the OPENING (not necessarily the gasket) and then lube the opening with the silicone tune-up grease. You may find wax or compund buildup there, or paint if it was repainted while you were not looking... 2) wipe off the gasket with a window cleaner such as Windex, then immediately lube the gasket. 3) open the sunroof then lubricate the tracks the window assembly slides on (fess up boys & girls, how many of you have done that lately?!?) I did not try this but you might (at your own risk) if you are really feeling energetic, get a manual to show how to pull the headliner so you can lube the motor, too. If it does not leak and shuts flush, I would not adjust it further. Albertj | |
ibmoses Aficionado
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Thu Feb 21, 2008 10:11 am | |
| I had already cleaned both the gasket and the roof area that it contacts and sprayed it with the silicone. I also wiped the tracks/sliders with a rag and sprayed with silicone. Still sticking, I can just barely bump it with my hand and it will pop down when it sticks... I am going to try the silicone grease, if that dont work I guess I will just tell the wife to pop it down with her hand when she wants to open it. Thanks for the replies and tips.
Bert | |
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Sat Feb 23, 2008 11:19 pm | |
| I'm stumped. Do you know if it was ever wrecked/pulled?
ibmoses Aficionado
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Sun Feb 24, 2008 9:02 am | |
| - albertj wrote:
- I'm stumped. Do you know if it was ever wrecked/pulled?
Albertj No signs of wreckage anywhere. I greased her up with the spark plug boot grease yesterday, well see if it continues to stick. Thanks for the tips. Bert | |
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Mon Mar 03, 2008 9:47 am | |
ibmoses Aficionado
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Mon Mar 03, 2008 10:21 am | |
| - albertj wrote:
- still sticking?
Albertj I think its good now. Thanks for the replies. I also told her to raise it to vent before opening it... Thanks again. Bert | |
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 04, 2008 9:28 pm | |
| Hmm - that may answer the question.
If your sunroof is factory, it tilts OK... but when it opens it slides *under* the metal roof. If your sunroof slides over the metal roof, it is an aftermarket unit. Which may be the problem here.
ibmoses Aficionado
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 04, 2008 9:36 pm | |
| - albertj wrote:
- Hmm - that may answer the question.
Albertj I just wanted her to open to vent before opening the sunroof to try and keep it from sticking. its definitely a factory sunroof. Sorry for the confusion. Thanks Bert | |
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Mar 05, 2008 5:06 pm | |
| No worries. Glad it's working out.
By the way for all of you reading this - remember to clean your sunroof drains this spring. Open the roof (slide back) and find the drains at the front corners of the opening. Don't use a coathanger - a few pipecleaners twised together at the ends (like the twist below the hook on a wire coat hanger) are what you want. So yo udon't bust a tube. If there is anything in there it's usually soft crud that will come loose with a little push - pull action on that pipe cleaner gizmo. For pipe clearners try WalMart, smoke-shop/newsstands, of craft stores like Michael's.
Kustom Kreationz Amateur
![Kustom Kreationz](https://2img.net/u/3215/30/10/37/avatars/436-9.jpg)
Name : Buck Location : Swainsboro, GA Joined : 2008-03-12 Post Count : 25 Merit : 0
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Sun Mar 23, 2008 6:39 pm | |
| - albertj wrote:
- No worries. Glad it's working out.
Albertj Smokeshop FTW!! ![thumbsup](/users/3215/30/10/37/smiles/thumbs.gif) | |
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Mon Mar 24, 2008 12:15 am | |
| Smoke-shops, yeah, like the ones at gas station converience stores. They sell cigars and what-not. And you can get a pack of plain old pipe cleaners there, cheap. Or news-stands, cigar/pipe shops, and such.
steve1173 Amateur
Name : stephen rabinowitz Location : punta gorda, fl Joined : 2008-05-25 Post Count : 40 Merit : 0
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Sunroof Adjustment Mon May 26, 2008 10:02 am | |
| Just got my 98, the sunroof on the outside is higher on the passenger side. Is there a way I can adjust it to lower it slightly to even it out or do I have to take it in to someone for that. It does not fit flush on the passenger side it sits higher parallel with the passenger door. The front, rear & drivers side is flush. | |
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Thu May 29, 2008 9:30 pm | |
| 1) sounds like collosion twist of the frame
2) is it leaking water? does it operate?
steve1173 Amateur
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Fri May 30, 2008 3:07 am | |
| Not collission twist. I've had it on new cars where I got the dealer to adjust under warranty. If you look at it from the outside the passenger right side is slightly higher then the roof while the left side of the driver is flush. | |
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Fri May 30, 2008 11:43 am | |
| Then judging by the silence of list members on this topic (they are not shy folks!) perhaps what you need is a service manual - check Ebay.
![Mr.Riviera](https://2img.net/u/3215/30/10/37/avatars/8-6.jpg)
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Fri May 30, 2008 1:39 pm | |
| i know there are ways to move it forward and back, but i dont think there is any angle adjustment. have you asked the dealer how much and what they can do? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily ![FAQ: Sunroof/Moonroof Problems & Adjustment Dsc_0110](https://i.servimg.com/u/f68/11/09/01/06/dsc_0110.jpg) | |
jimmyriv Junkie
![jimmyriv](https://2img.net/u/3215/30/10/37/avatars/81-89.jpg)
Name : James Age : 80 Location : Muskegon, Michigan Joined : 2007-03-16 Post Count : 781 Merit : 8
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Sunroof limit switches Tue Sep 09, 2008 9:17 am | |
| Does anyone have any experience with sunroof limit switches. (Location, adjustment)? Mine just started acting up. When opening the back up it makes a loud ratcheting noise at the full up position instead of just stopping. When closing it from that position, it just continues to fully opening instead of stopping at the normal closed position. ![scratch](https://2img.net/i/fa/i/smiles/icon_scratch.png) | |
ewolfe0050 Aficionado
![ewolfe0050](https://2img.net/u/3215/30/10/37/avatars/211-6.jpg)
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Sep 09, 2008 9:36 am | |
| Mine just started doing it too. Somebody help! | |
Chicken Aficionado
![Chicken](https://2img.net/u/3215/30/10/37/avatars/535-43.jpg)
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Sep 09, 2008 9:52 am | |
| Sounds like the limit switch in the actuator....
I'm not sure if they're accessible or adjustable..... | |
Chicken Aficionado
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Sep 09, 2008 9:59 am | |
| I found these on the internets....
For a '95 Cadillac STS Astro Roof...I'm guessing its the same the Riv's Astro Roof....
Wiring Diagram: https://s7.photobucket.com/albums/y299/WBucket/?action=view¤t=Roof1.jpg
Parts Location: https://s7.photobucket.com/albums/y299/WBucket/?action=view¤t=Roof3.jpg
Troubleshooting Chart 1: https://s7.photobucket.com/albums/y299/WBucket/?action=view¤t=AstroRoofDead1.jpg
Chart 2: https://s7.photobucket.com/albums/y299/WBucket/?action=view¤t=AstroRoofDead2.jpg | |
jimmyriv Junkie
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Sep 09, 2008 10:14 am | |
| - Chicken wrote:
- I found these on the internets....
Chart 2: https://s7.photobucket.com/albums/y299/WBucket/?action=view¤t=AstroRoofDead2.jpg Thanks so much,my brother! ![happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png) | |
![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment ![FAQ: Sunroof/Moonroof Problems & Adjustment Empty](https://2img.net/i/empty.gif) | |
