| FAQ: Sunroof/Moonroof Problems & Adjustment | |
ewolfe0050 Aficionado
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Sep 09, 2008 10:43 am | |
| Wow. That stuff is foreign to me. Jimmyriv, when you get it figured out could you explain it to me in laymans terms? | |
99Rivman Aficionado
Name : Randall Location : North Carolina Joined : 2007-01-16 Post Count : 2009 Merit : 88
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Sep 09, 2008 4:47 pm | |
| There are instructions for synchronizing the roof in the '99 Service Manual. I have some trouble with SA #152 but I haven't looked into it yet. I think the pictures the Mark post are close, just not sure. | |
'96reese Fanatic
Name : Reese Age : 38 Location : StL Joined : 2007-09-20 Post Count : 259 Merit : 4
 | Subject: sun roof problems Tue Sep 23, 2008 11:15 pm | |
| okay so the sun roof works partially. i can hear the motor running, but nothing happens when you try to let the roof go all the way back. it will work fine when you tilt it up, but when you tilt it back down it does not pop up flush with the rest of the roof so it leaks.
like i said before i'm sure the motor works, because i can hear it running whenever i press the button. where are the cables/tracks located so i can check those out? how do i remove the headliner so i can acess the cables/tracks? i need help so i can stop leaks. | |
rivman96 Enthusiast
Name : Cameron Age : 31 Location : Asheville, NC Joined : 2008-09-15 Post Count : 100 Merit : 1
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Sep 24, 2008 9:36 am | |
| I have a similar problem, only I can toy with the button to get it in a position so the roof doesnt leak. | |
rivboy Amateur
Name : Marc Age : 29 Location : Leech Lake, Minnesota Joined : 2008-07-22 Post Count : 41 Merit : 0
 | Subject: sun roof problem/question....... Sun Oct 12, 2008 4:17 pm | |
| 1996 rivi.... some people i talked to said the sun roof only tilts up and others have told me thats a lie it should go all the way back. from looking at it i belive it should go back too. but when i mess with the switch it will only tilt the back of it up... whats the problem?? does it rlly only tilt up or is their wire problems possibly or a problem with the motor and tracks or what? any help appreciated. | |
98RIV7777 Fanatic
Name : Anthony Age : 33 Location : Niagara Falls, NY Joined : 2008-06-01 Post Count : 274 Merit : 1
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Sun Oct 12, 2008 5:44 pm | |
| When you push the button forward it will close the moonroof when its open, and when its closed and you push the button forward it will pop the back of the moonroof up. So if I were you I would push the button back and while you are doing this put your hand out your window and push pressure down on the back of the moonroof glass from outside the car to help assist it to pop down and go back. I had a few friends that had this problem and its was only because the gasket around the glass was sticking to the body of the car. If this makes the glass go back you need to greese up the gasket around the glass and the frame with some silicone greese. Let me know if this is your problem and helps you out. Good Luck | |
Ironclad-454 Enthusiast
Name : Nate Age : 37 Location : North Dakota Joined : 2008-11-22 Post Count : 161 Merit : 9
 | Subject: Sunroof problem Wed Jun 10, 2009 7:14 pm | |
| So the other day I went to open the sun roof and it started to go back but about 3/4 of the way back it stops and then starts to close then before it closes it starts open again, it began to repeat the process until I pushed the close button, now it won't open at all. This happened once before, I looked at the fuse panel and figured since it was an OEM option it would more than likely be on the accessory fuse, when I pulled the fuse it was fine. After re-installing the fuse the sunroof began to work like normal, until a few days ago. This problem seems to accompany the cruise being difficult to get turned on. Any suggestions? | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8039 Merit : 167
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Jun 10, 2009 10:56 pm | |
| sounds like a bum switch. Or a limit switch that has become cranky.
What do you other guys think - I think get a replacement switch from junkyard and swap 'em.
EatDirtFartDust Fanatic
Name : The Josh Age : 37 Location : Somewhere between Sullivan and Saint Peters Missouri. Joined : 2009-03-27 Post Count : 284 Merit : 2
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Wed Jun 10, 2009 11:17 pm | |
| That's where I'd start. Especially since that would be the least costly repair. | |
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Sat Jun 13, 2009 12:23 am | |
| I pulled the switch down and saw some damaged wires, that might be the culprit, we'll see. | |
#1BearsFan Enthusiast
Name : Bill Location : North Carolina Joined : 2008-07-28 Post Count : 231 Merit : 4
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Sat Jun 13, 2009 4:03 pm | |
| Too freakin hot to work on the car here today.... | |
99Rivman Aficionado
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Sat Jun 13, 2009 4:23 pm | |
| - #1BearsFan wrote:
- Too freakin hot to work on the car here today....
... but I don't have a choice, everything I need to get done is outside! | |
ibmoses Aficionado
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Sun Jun 14, 2009 10:11 pm | |
| So far so good, Sunroof is now working. Thanks guys. | |
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Sun Jun 14, 2009 10:14 pm | |
| while you are at it, might want to do a quick visual on the cruise wiring - I'd pull the panel under the steering column and just look at things, trying to guess whether any of the wiring had ever been disturbed.
After all you did say the cruise was intermittent.
That failing - time for a wiring diagram.
VJD2 Fanatic
Name : Vinny Location : Connecticut Joined : 2010-02-21 Post Count : 310 Merit : 5
 | Subject: Sun Roof issue Tue Mar 30, 2010 2:05 am | |
| So my sun roof feels like randomly pulling itself up after driving awhile or if I go over 80mph. Something is not holding it down and when I press the sun roof button it makes a horrid grinding noise and will not seat sun roof all the way down. I'm afraid this will cause major leaks and already creates an annoying wind noise obviously because its not sealed.
Is this a motor problem, gear problem or something else? Sounds like the gear is shot but it opens no problem and pops the roof open. Just an issues when closing and pulling down the glass to seal it.
Seems to be never ending.. | |
Name : robotennis Age : 59 Location : las vegas Joined : 2007-12-17 Post Count : 5562 Merit : 143
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 30, 2010 2:09 am | |
| you have to clean all the mating surfaces including the rubber seal. pia, but you have to clean the cables with wd40,then grease with whatever the manufacture recomends for grease. that should help.if you live in Ct then the winter might have made its way into the roof..... | |
Name : Rick Location : Lancaster, MA Joined : 2008-09-13 Post Count : 6278 Merit : 117
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 30, 2010 2:11 am | |
| I wouldn't be opening it too much until i figured out what was wrong. I've not had that problem, but maybe someone else on here has and can help you. | |
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 30, 2010 2:13 am | |
| - robotennis61 wrote:
- you have to clean all the mating surfaces including the rubber seal. pia, but you have to clean the cables with wd40,then grease with whatever the manufacture recomends for grease. that should help.if you live in Ct then the winter might have made its way into the roof.....
Do you recommend removing the headliner to fix this problem.? Do you have experience with a prior Sunroof problem, if so I'd like to know for future possible repairs. | |
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 30, 2010 2:22 am | |
| I've not had any problems with the riv. but my acura had the same issue,NY weather, and all i did was best i could,clean the cables,by hand,then grease the tracs. that did it. I'm guessing the riv isn't that much harder. the hard part is starting the work. | |
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 30, 2010 2:29 am | |
| Did you have to remove the Headliner to do any preventive maintenance.????? | |
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 30, 2010 2:33 am | |
| no. at first i thought i might have to. but i wanted to just try doing the job without removal. it worked. | |
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 30, 2010 3:06 am | |
| You mentioned cleaning and lubing cables. I've never seen any cables on our sunroof. That was why I asked about removing the headliner to gain access to the mechanism./ | |
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 30, 2010 3:14 am | |
| no cables? showes you how observative i am. according to the manual,after you remove the "pinchweld lace" it seems preety straight forward as to how to proceed. note ,that you have to remove the assist handles,sunshades,and disconect the whole shebang. pia. | |
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment Tue Mar 30, 2010 3:18 am | |
- pia.
What does pia mean? | |
 | Subject: Re: FAQ: Sunroof/Moonroof Problems & Adjustment  | |
