| Fixing an electrical plug | |
 | Subject: Fixing an electrical plug Sat Jun 20, 2009 2:05 pm | |
| Don't pull on wires when trying to remove a plug I thought I would get away with it, and I didn't  Now I need to repair or replace this plug -  This is for the light at the rear most part of the door. I guess the best way is to get another plug and splice it in? Is it a standard type I can pick up at a parts store? | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8547 Merit : 181
 | Subject: Re: Fixing an electrical plug Sun Jun 21, 2009 12:42 am | |
| Dealers have connector kits for those - the metal pins/sockets crimp onto the wires and then slip into the plastic parts. You should be able to get them to fix it for you for short shop time or a case of root beer... check it out.
 | Subject: Re: Fixing an electrical plug Sun Jun 21, 2009 7:31 am | |
| JR, Did you break the plastic part of the plug or socket, or did just the wires pull out? If you broke something I might have a used connector and socket. I'll have to look through my "Stuff" in storage for you. Rick | |
 | Subject: Re: Fixing an electrical plug Sun Jun 21, 2009 7:59 am | |
| I also have a parts car, I'll see if I can find one of those. Can you take pictures of the part you broke? | |
Wolfmaster579 Fanatic
Name : Ryan Age : 35 Location : Lewisberry, PA Joined : 2009-09-01 Post Count : 260 Merit : 2
 | Subject: Re: Fixing an electrical plug Tue Sep 22, 2009 8:12 pm | |
| alright i have one for ya. I have a door jamb switch on my passenger side that has a broken prong on it in the plug. most of the time it doesnt work but the prong can move whilst inside the plug and it causes my interior lights to turn on and off. would pulling the wires and getting new crimps and inserts be a plausible solution. if not do you have any ideas how to fix it. I was hoping to find new switches cause my driver side doesnt work at all anymore, but for the age and rarity of my vehicle, I have had no luck. | |
 | Subject: Re: Fixing an electrical plug Tue Sep 22, 2009 10:23 pm | |
| What?!?!?
rockauto.com has the door jamb switches, both for 'ajar' and lights.
 | Subject: Re: Fixing an electrical plug Tue Sep 22, 2009 10:44 pm | |
| helpful website. I will bookmark that site. The part for my passenger door im talking about is what the door jamb switch connects too. that connector part that goes up into the mess of wires under the dash. and the site doesnt have it. | |
 | Subject: Re: Fixing an electrical plug Tue Sep 22, 2009 10:52 pm | |
| hey what is that relay called that gives you that warning ding if you leave your lights on or your keys in the ignition. mines faulty and id like to get it fixed. | |
 | Subject: Re: Fixing an electrical plug Tue Oct 06, 2009 12:40 pm | |
| BMP for Ryan's questions. | |
 | Subject: Re: Fixing an electrical plug Tue Oct 06, 2009 12:51 pm | |
| Ryan might need to check eBay for a manual set.
The connectors - some are available through the dealers, others you can get weather-pak connectors at an auto parts store and replace both sides.
 | Subject: Re: Fixing an electrical plug Tue Oct 06, 2009 5:30 pm | |
| Well ive tried the dealers. None want to get back with me about the peice i need. I have decided what i need to do. I am going to buy the new jamb switches, which have a small length of wire coming out unlike the current switches, and eliminate the connector all together. I will hard wire the wires coming from the switch and the ones that are in the female connector. They are just $30 a switch and my brake lines are more important right now. Thanks for the input. I appreciate it. | |
 | Subject: Re: Fixing an electrical plug  | |
