| Write-Up: OEM Front Brakes Pad & Rotor Maintenance | |
+16sniperdude Snowdog Rickw Abaddon Jack the R maggot deekster_caddy playa Mr.Riviera riv_problems96 albertj TType_Riviera qprint 98riv AA cragmor 20 posters |
sniperdude Fanatic
Name : Mike Location : Chicago Joined : 2012-06-04 Post Count : 250 Merit : 18
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Wed Mar 06, 2013 12:39 pm | |
| Hey all. I'm doing my front brakes this weekend. I got the front rotors too.
The only part I am not 100% on is these clips for the brake pads. I understand that they help to hold the pads in.
Does anyone have a pic of these on our cars? | |
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Wed Mar 06, 2013 12:50 pm | |
| They keep tension on the pads, reduce noise & vibration. You can install the pads without the hardware, but the pads will rattle around, and may click switching forward to reverse. pad/rotor wear could also be affected.
What's the issue? They should just install between the pad edges and the caliper, and there's another one contacting the middle outside edge of the pad. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
sniperdude Fanatic
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Wed Mar 06, 2013 1:02 pm | |
| I haven't taken anything apart yet, I was just wondering how they looked on the caliper is all. I suppose I will know after I take apart the old hardware. | |
Name : Matthew Age : 36 Location : Florida Joined : 2007-01-17 Post Count : 4394 Merit : 101
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Wed Mar 06, 2013 8:05 pm | |
| - sniperdude wrote:
- I haven't taken anything apart yet, I was just wondering how they looked on the caliper is all. I suppose I will know after I take apart the old hardware.
Like Aaron said there is nothing difficult about replacing them. They normally stay stuck on the caliper brackets so just R&R with new ones. With the 95's i think there are only clips on the outside of the pads, none on the center. but its been forever since ive seen a 95/96 caliper so dont quote me _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
sniperdude Fanatic
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Tue Mar 19, 2013 3:38 pm | |
| Lol, yeah I def need to replace these:  | |
sniperdude Fanatic
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Tue Mar 19, 2013 3:39 pm | |
| My caliper slides were seized up pretty bad... is there a place to buy replacements? | |
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Tue Mar 19, 2013 3:42 pm | |
| man,you gotta hate that noice a? | |
sniperdude Fanatic
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Tue Mar 19, 2013 3:45 pm | |
| It was actually dead quiet when stopping believe it or not. The pads had a lot of material left. The rotors are sad, though. | |
sniperdude Fanatic
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Tue Mar 19, 2013 4:03 pm | |
| - sniperdude wrote:
- My caliper slides were seized up pretty bad... is there a place to buy replacements?
Here I go answering my own questions again, but for anyone else with a '95 - the front caliper sliders from Dorman are #HW5053. The rears are Dorman #HW5056. | |
sniperdude Fanatic
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Wed Mar 20, 2013 4:09 pm | |
| As far as the caliper loading, the larger pad is a no-brainer as far as the clips, it pops right in. The other pad was not really clipped in, per se. It had two metal clips on the back, but these were inserted into the caliper piston. Is this the correct way the smaller (inner) pad should be installed?  Was sitting right in that piston hole with the clips inserted there. | |
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Wed Mar 20, 2013 4:20 pm | |
| Yes the factory pads should have a metal clip on them that holds them to the piston on the 95's and 96's. Its kind of a press fit if i recall correctly, been a really long time since ive seen the stock brakes on a 95/96 riv.  _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
sniperdude Fanatic
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Wed Mar 20, 2013 4:29 pm | |
| Yeah, the previously installed one has one of the clips bent to fit into the bore, the new ones' clips are just as big as the old one so I'm assuming I'll have to replicate that bend. | |
sniperdude Fanatic
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Fri Mar 29, 2013 3:30 pm | |
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Fri Mar 29, 2013 4:21 pm | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8520 Merit : 181
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Fri Mar 29, 2013 5:11 pm | |
| It would not be a waste of time to polish those guide pins as long as you don't polish off the plating. | |
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Fri Mar 29, 2013 5:26 pm | |
| Nice work, Mike. Well-documented! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
sniperdude Fanatic
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Fri Mar 29, 2013 7:07 pm | |
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Fri Mar 29, 2013 8:11 pm | |
| Nice! sux to have to get rid of them to make room for the F-body brake mod tho?! | |
sniperdude Fanatic
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Sat Mar 30, 2013 9:22 am | |
charlieRobinson Expert
Name : Charlie Age : 37 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3922 Merit : 30
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Sat May 18, 2013 12:27 pm | |
| About to survey and attempt rotors and pads today. I've read threads and studied. Here's to hoping it works out for me! | |
joshuadalegrimes Addict
Name : josh Age : 42 Location : harrodsburg, ky Joined : 2012-09-02 Post Count : 501 Merit : 13
 | Subject: write up: brake rotor and pad replacement Sun May 19, 2013 5:39 pm | |
| TOOLS NEEDED 7/16 socket 5/8 socket brake compressor tool or c clamp (opt) wire wheel, masking tape, and caliper paint STEP1 jack car and remove wheel to be worked on STEP 2 remove brake line using 7/16 socket ( not necessary if only doing pads) STEP 3 remove the 2 caliper mounting bolts ( only need to do 1 if only doing pads) using 5/8 socket STEP 4 compress piston using tool or c clamp STEP 5 remove 2 caliper bracket bolts using 5/8 socket STEP 6 remove rotor by pulling off STEP 7 clean hub, caliper, and mount bracket with wire wheel and tape off all bolt holes STEP 8 paint caliper and mounting bracket STEP 9 reassembly is reverse of removal STEP 10 bleed brakes and enjoy pics below step 1  step 2   step 3  step 4   step 5  step 6  step 7   step 8  step 9/10  | |
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Sun May 19, 2013 5:42 pm | |
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Sun May 19, 2013 6:05 pm | |
| Thanks for the pics. I merged your thread with our existing brake write-up thread.
Just wondering - Did you clean the caliper before painting, or just paint over the old rust and grime? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Sun May 19, 2013 6:10 pm | |
| i hit it with a wire wheel then wiped it down with wax and tar remover
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance Sun May 19, 2013 6:23 pm | |
| hhmm,the Riv is all metric.jus sayin | |
 | Subject: Re: Write-Up: OEM Front Brakes Pad & Rotor Maintenance  | |
