| Write-Up: Replacing rear rotors and pads. (lots of pics) | |
+36stan charlieRobinson Kcclarkjr flyineagle96 Natesriv bigdave Jason DEMonte1997 robotennis61 98riv BMD Sweepspear BrianEsser maggot ibmoses xxsupergman25xx Eldo Ryan from Ohio albertj Rickw 1995 Riv JimmyRiviera '96reese deekster_caddy turtleman GeneMpls T Riley jrocha Buapo AA jimmyriv jax95riv allfalldown racinfan NO 4 EVR Mr.Riviera 40 posters |
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18438 Merit : 248
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics) Sat Jun 15, 2013 10:52 pm | |
| tool = cube thing _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
LT1Squirrel Enthusiast
Name : EB Joined : 2010-05-14 Post Count : 122 Merit : 2
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics) Sun Jun 16, 2013 12:27 am | |
| yeah, figured that out quick haha, thankfully my brother had one at his shop | |
BMD Aficionado
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics) Sat Jul 26, 2014 1:34 pm | |
| Hey Guys, I've looked here and online and can't find anything that shows you how to remove the integrated parking brake cable from the caliper when its time to replace them. Does anyone have any pics or can someone describe in detail how to separate the e-brake from the rear calipers? | |
BMD Aficionado
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics) Sun Jul 27, 2014 7:15 pm | |
| No one has replaced the rear calipers on their Riv? | |
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics) Tue Jul 29, 2014 4:56 pm | |
| - BMD wrote:
- No one has replaced the rear calipers on their Riv?
I've had them off this and other Buicks several times. It's a PITA to get the parking brake cable disconnected, but there is no magic to it. A good set of needle nose vice grips will help. You need to compress the spring and pull the cable out. The cable brackets unbolt and you also will want to unbolt the cable guide on the control arm. 13 and 14mm sockets to get everything off (I think) | |
BMD Aficionado
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics) Tue Jul 29, 2014 11:43 pm | |
| Thanks Derek, I'll take a look at them. I plan to do 'em before the fall. If I need some help at that time, hopefully you'll be around to offer some direction. | |
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics) Wed Jul 30, 2014 1:57 pm | |
| - BMD wrote:
- Thanks Derek, I'll take a look at them. I plan to do 'em before the fall. If I need some help at that time, hopefully you'll be around to offer some direction.
I can tell you that they aren't easy. But they aren't THAT hard either. I may or may not be able to admit that I fought with one for over an hour putting them back together one day. Usually it's a 5 minute job. Good luck. | |
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8530 Merit : 181
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics) Wed Jul 30, 2014 8:36 pm | |
| - deekster_caddy wrote:
I can tell you that they aren't easy. But they aren't THAT hard either. I may or may not be able to admit that I fought with one for over an hour putting them back together one day. Usually it's a 5 minute job. Good luck. Yep... if you remember to release the parking brake and if the adjuster's not wound too tight then you can get the cable back on with vise grips and a smile. If not, it will take a while. Albertj | |
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics) Mon Nov 17, 2014 8:02 pm | |
|  Did my rear pads & rotors yesterday. Even though rusty, my original rear calipers are still working at 282855 miles. It's a pretty easy job that doesn't need to happen that often, but I did run into one snag. Here are a few tips:  The way it's supposed to work, turning the piston clockwise compresses it into the caliper, providing space for fresh pads & rotor. For a long time this worked pretty well. I would even use a small air ratchet to speed things up. But a few years ago I noticed using the air ratchet didn't compress the piston, but using a manual, hand ratchet worked - very confusing, WTF??! So Yesterday I was having trouble with the hand ratchet, too. Turning it, the piston wouldn't move into the caliper. I tried a little clamping pressure while turning the ratchet, and presto, it went right in. It seems the air ratchet didn't require a lot of pressing force, so that would explain it. If you're ever turning without results, try using a quick-grip style clamp over the ratchet head.  At least once per year I like to lube the rear trailing arms with grease. Mine are rusty, and the grease boots are a little cracked, but keeping them lubed up has extended their life. Still very tight when I give them a good tug. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
KnottyEagle Fanatic
Name : Daymon Age : 25 Location : Battle Creek, Michigan Joined : 2014-08-29 Post Count : 284 Merit : 2
 | Subject: temp Mon Nov 17, 2014 8:17 pm | |
| What kind of grease do you use, AA? | |
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics) Mon Nov 17, 2014 8:26 pm | |
| AGS Sil-glyde Brake Lubricant  _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics) Wed Nov 19, 2014 11:51 am | |
| I like to put the bracked and caliper back in place without the rotor so there is something to push on without having the caliper all loose. Good idea about using the clamp! | |
 | Subject: Re: Write-Up: Replacing rear rotors and pads. (lots of pics)  | |
