| Where to begin... | |
+17ibmoses dreww 97rivsc Ironclad-454 98SuperRiv 1998 Riv 98riv 98RiviSC ThorsMitersaw Jason racinfan AA oldsman105 urbsnspices nothincame2mind NO 4 EVR T Riley 21 posters |
ThorsMitersaw Special
| Subject: Re: Where to begin... Mon Apr 16, 2007 1:33 pm | |
| Hey thanks man. I will be sure to read through that FAQ.
I found an intake that LOOKS like it would work... http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=ADME%3AB%3AAAQ%3AUS%3A1&viewitem=&item=230109104277&rd=1 | |
| Subject: Re: Where to begin... Mon Apr 16, 2007 1:51 pm | |
| It looks like it would FIT, anyway. The one thing I don't much care for is how that filter isn't isolated from the engine bay. Even the stock air box is designed to pull in air from the outside because it's cooler. While I do think that K&N cone should flow well, I also think it will flow a lot of hot air, which isn't good. One thing you could do is build an insulated box around the filter to keep the air cooler. Then it might work. More on intakes: https://rivperformance.editboard.com/Supercharged-3800-Tech-c2/Series-II-FAQ-f19/What-are-CAI-FWI-t29.htm_________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
NO 4 EVR Addict
| Subject: Re: Where to begin... Mon Apr 16, 2007 2:47 pm | |
| Yes, short ram hot air intakes don't work well in L67s. | |
urbsnspices Fanatic
| Subject: Re: Where to begin... Mon Apr 16, 2007 3:09 pm | |
| - NO 4 EVR wrote:
- Yes, short ram hot air intakes don't work well in L67s.
I disagree. With a mostly stock engine an open cone is better then a stock airbox. Not the best option by far. | |
NO 4 EVR Addict
| Subject: Re: Where to begin... Mon Apr 16, 2007 3:56 pm | |
| Ok lol. I won't disagree but the massive amount of hot air being pulled in can't be much better than a little bit of slightly warm air.
Any one have intake temps on a short ram as apposed to a gutted box for FWI?
I know my intake temps are usually 5 to 10 degrees more than ambient temp (this was when it was like 30 out) | |
98RiviSC Member
Name : Ryan Age : 37 Location : New Lebanon, Ohio Joined : 2008-12-07 Post Count : 55 Merit : 0
| Subject: Mods for Riv Sun Dec 07, 2008 8:55 pm | |
| Alright i have been reading and was wondering what mod to do first. I think im gonna start with 180 degree thermostat and AutoLite 104 plugs. Is it better to have headers next ? Or 3"downpipe and High Flow Cat ? Also was wondering if anyone recommeded a good exhaust system ??? Thanks ! | |
98riv Moderator
| Subject: Re: Where to begin... Sun Dec 07, 2008 9:02 pm | |
| https://rivperformance.editboard.com/series-ii-engine-transmission-f4/modding-how-do-i-make-the-car-faster-t23.htm+ Note: I would move the scanner up on this list. That way you can make sure that your car is running properly before you increase your power. The scanner will be able to help you make sure that everything is running properly and it will help you know how much know you are getting. - Quote :
1. Premium fuel 2. Cooler spark plugs 3. Cooler thermostat 4. Gutted air box 5. Cold Air Intake (CAI or FWI) 6. Modular Pulley System (3.6" or possible 3.5") 7. Scan device 8. 3.5" or possible 3.4" SC pulley 9. 3" Down pipe 10. Possible 3.4" SC pulley 11. Rockers or cam 12. PCM or tuner 13. 3.4" or possible 3.3" SC pulley 14. PEMs or headers 15. Possible 3.3" or 3.2" SC pulley 16. Exhaust and mufflers 17. Ported blower 18. Bigger throttle body 19. Intercooler 20. Possible 3.1" or smaller SC pulley
_________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
98RiviSC Member
| Subject: Re: Where to begin... Sun Dec 07, 2008 9:10 pm | |
| So they do make a Cold air intake for these cars ? I couldnt find one so i just went with the filter. How do i get one , or do i have to custom make one ? | |
98RiviSC Member
| Subject: Re: Where to begin... Sun Dec 07, 2008 9:11 pm | |
| Is it a true cold air is it the ones that you find on ebay that sit in your engine bay and suck up hot air ? | |
98RiviSC Member
| Subject: Re: Where to begin... Sun Dec 07, 2008 9:13 pm | |
| If i put smaller pulleys on engine, will i need to upgrade any internals ? I want to do it, but dont want to develop rod knock ? Thanks a lot ! | |
98riv Moderator
| Subject: Re: Where to begin... Sun Dec 07, 2008 9:38 pm | |
| - 98RiviSC wrote:
- So they do make a Cold air intake for these cars ? I couldnt find one so i just went with the filter. How do i get one , or do i have to custom make one ?
You will have to make your own. There are a couple threads that have pictures and information that you can follow if you want to go that route. The ones on Ebay are warm air intakes. You would need to make a box to surround the filter to keep the warm air out of the intake. - 98RiviSC wrote:
- If i put smaller pulleys on engine, will i need to upgrade any internals ? I want to do it, but dont want to develop rod knock ? Thanks a lot !
You shouldn't have to if you keep knock low (zero is the best). Read some of the stickied threads at the top in this link https://rivperformance.editboard.com/series-ii-engine-transmission-f4/. It should help answer some of your questions. I would start out with a MPS (Modular Pulley System) first. I would suggest a 3.5 after you get the supporting mods done. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
98RiviSC Member
| Subject: Re: Where to begin... Sun Dec 07, 2008 10:02 pm | |
| Alright, so if i buy the 180 degree thermostat, the autolite 104 plugs, would i be safe at 3.4 inch pully ? Im looking at the Module Pully System from intense racing right now. Thanks man ! | |
| Subject: Re: Where to begin... Sun Dec 07, 2008 10:04 pm | |
| No, that is not sufficient to start dropping pulley sizes. The ONLY way to determine that is by scanning for KR. | |
98RiviSC Member
| Subject: Re: Where to begin... Sun Dec 07, 2008 10:05 pm | |
| And how do i get a scan device ? | |
| I did all the usual supporting mods that should have allowed me to run a 3.4 pulley, but I have knock retard even running the stock 3.8 pulley. Every engine/car is different, and no one can tell you what is "safe" until you can scan for KR. | |
| Subject: Re: Where to begin... Sun Dec 07, 2008 10:07 pm | |
| I personally use an LS1M scan tool, but they are no longer produced. There are many options available for our OBDII engines, try searching the board for "scanners". | |
98RiviSC Member
| Subject: Re: Where to begin... Sun Dec 07, 2008 10:10 pm | |
| I found them, thanks a lot man, expensive, so maybe i will wait to get one of those tools before i upgrade pulleys. So even if i went with a 3.6 i have a chance of rod knock ? I was just wanting to do something for now and upgrade more later. | |
| Subject: Re: Where to begin... Sun Dec 07, 2008 10:12 pm | |
| What did you find that is expensive? The obsolete DHP and the currently available HP Tuners tool are much more than scanners, they are tuning tools, enabling you to make programming changes. An example of a scan tool only, is an AutoTap, or an Actron. Have a look at those. Not CHEAP, but a lot less than a tuning tool. | |
| Subject: Re: Where to begin... Sun Dec 07, 2008 10:13 pm | |
| We also have a lot of OH members, maybe you're close enough for someone to volunteer to do some scanning for KR for you. | |
98RiviSC Member
| Subject: Re: Where to begin... Sun Dec 07, 2008 10:14 pm | |
| The RK scanner is like 300$ right ? | |
98RiviSC Member
| Subject: Re: Where to begin... Sun Dec 07, 2008 10:15 pm | |
| That would be nice, i would pay them though. How is the scan done ? | |
98riv Moderator
| Subject: Re: Where to begin... Sun Dec 07, 2008 11:23 pm | |
| - 98RiviSC wrote:
- That would be nice, i would pay them though. How is the scan done ?
You plug the scanner into the OBD-II port. There is also a gauge that you can use as a scanner. I forget the name, but you can find it by searching the forum or by looking at the vendors websites. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
98riv Moderator
| Subject: Re: Where to begin... Sun Dec 07, 2008 11:25 pm | |
| Found it, it is called the Aeroforce Intercepter scan gauge. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
98RiviSC Member
| Subject: Re: Where to begin... Mon Dec 08, 2008 4:41 am | |
| Alrighty, now i just need to find someone that will help me by having the scanner. lol...thanks a lot man ! | |
98SuperRiv Member
Name : Bradley Age : 36 Location : Mapleton IL Joined : 2008-12-03 Post Count : 65 Merit : 3
| Subject: Re: Where to begin... Mon Dec 15, 2008 12:25 am | |
| how would i go about gutting my air box? | |
| Subject: Re: Where to begin... | |
