 Transmission Oil - Fluid Temperature
4 posters
Transmission Oil - Fluid Temperature Empty
PostSubject: Transmission Oil - Fluid Temperature   Transmission Oil - Fluid Temperature EmptyMon Mar 22, 2010 11:20 am
I wanted to report my trans fluid temps yesterday on a 240 mile round trip:
Peak 172ºF @ 70ºF (day) avg ambient temp, TCC lock-up at 55-70 mph for 2.5 hours
Peak 160ºF @ 60ºF (night) avg ambient temp, TCC lock-up at 55-70 mph for 2.5 hours
Temps were measured with ~180º coolant temps, no external trans cooler.
Just posting for future reference, should anyone want to know.
PostSubject: Re: Transmission Oil - Fluid Temperature   Transmission Oil - Fluid Temperature EmptyMon Mar 22, 2010 11:52 am
I just did a tranny filter change 2 days ago in the 95. Started running that newer Quaker State Semi synthetic ATF part #11083. I was really impressed with the way it shifts now, idk if its the new style oil so much as it just needing to be serviced but what came out was actually very clean. So for now I will credit the new ATF lol. At least I'll sleep bettr for paying the extra $ that way.
Northeast
PostSubject: Re: Transmission Oil - Fluid Temperature   Transmission Oil - Fluid Temperature EmptyTue Oct 26, 2010 1:46 pm
What is the normal temp range for the 4T60-e (stock Riv)?
What is the max temp for the same tranny?
Merit : 104
PostSubject: Re: Transmission Oil - Fluid Temperature   Transmission Oil - Fluid Temperature EmptyTue Oct 26, 2010 7:24 pm
With a stock 195-degree thermostat and no external cooler, that's pretty much going to be the minimum temperature you see after driving for a while in mild weather... I suppose that a 'normal' max would be about 215 to 220 degrees. Any sustained use above that temperature and your fluid is going to burn out before your 30,000-mile change (and a normal change only gets about half the fluid out anyway.)
These are only guidelines of course. I would guess that the biggest variables to the 'rules' are the location of the temp-sensor in each tranny, and the different types of fluids & the possible synthetic blends...
» Transmission fluid and filter
» Write Up: Transmission Fluid & Filter Change
» Transmission Fluid Survey...
» Inverted Fluid Balanced: Automatic Transmission vs Engine Oil
» Temperature Gauge
