 Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade
Derek
bullseye-shawn
Sweepspear
lyonsperformance
BoattailBob
manofmany
23 posters
Sweepspear
Sweepspear
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 Empty
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Jan 04, 2010 2:21 pm
I don't think I've ever seen a sway bar link with a plastic sleeve. How could plastic possibly hold up to the pressure exerted on it by the sway bar and control arm ?
I can't say I have ever seen, nor heard of plastic being used before either.
The links I replaced on my '96 had metal sleeves, as did the AC Delco replacements.
(Which have stopped squeaking by the way.)
ride
Learn something new everyday!
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Jan 04, 2010 6:13 pm
Since that post, I have now seen them and they are indeed some type of plastic.
Saw them on a customers Caddy in my buddy's shop. The car had a broken sway bar but the links were still intact - go figure.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Jan 04, 2010 11:01 pm
IIRC the sway bars are hollow.
I think I will need to replace mine next year.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Jan 04, 2010 11:11 pm
albertj wrote:
IIRC the sway bars are hollow. Albertj
Yes, the Cadillac bar that I saw was hollow.
It was a front bar but I do not remember the model of car or the exact year.
I have been told here though that the STS with FE-3 suspension has a solid front bar and a hollow rear.
So, I have installed an Addco rear bar (solid) and plan on installing a front bar (solid) from an 98-2004 STS used.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyThu Jan 14, 2010 4:56 pm
What I got with the rear bar were the GM rubber mount bushings and a set of End Links. I forget the P/N but they were OEM GM parts with the same number as the STS rear bushing numbers.
Then I bought a set of Energy Suspension Links from the local parts store because they had 3/8" diameter bolts instead of the supplied 5/16".
Could have made my own or modified the 5/16" ones, but it was just easier to get the 3/8" ES's.
The Summit ACO-2018 is actually listed for the Pontiac and Oldsmobile and has an Estimated Ship Date of Feb. 12, 2010.
So everybody is back ordered. But like i said before the rear one took a month to get here as well and that was a loong time ago.
So i don't think there production issues are new.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyFri Jun 25, 2010 2:06 pm
If you aren't going to do anything with the OEM bar, would mind cutting it in half?
Will do
Another thing, did you all use the end links that the bar came with or what did you use? I bought a set of Moogs because I wasn't planning on even getting this bar actually but as I compare them, the Moogs have a larger bolt and better fitting/sturdier hardware. In comparison, the links supplied with my Addco kit are very loosy goosy on the bolt and the washers are dinkier.
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 CIMG1648
see?
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 CIMG1649
I think I'm going to do something to this effect. Moog hardware with the poly link bushings. I need to either cut the Moog spacer shorter to be abou the length of the Addco supplied version or buy some from the hardware store since the poly bushings themselves and the washers are a little wider.
Btw, I wouldn't go with energy's end link bushings because they don't fit against any of these bars very nicely. The poly's supplied by Addco fit basically just like stock which is great.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyFri Jun 25, 2010 2:30 pm
Those look like the HD design offered by MOOG, #K8989 correct? They offer a standard and an HD, but only offer HD for the front oddly enough. I wasn't sure whether to go with the K8989's or K5255's and K6690's in rear (Standard design). How do you like yours?
My cost is $24CAN to do the front in HD so I think I will bite the proverbial bullet. $24 is nothing anyways.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptySun Jun 27, 2010 4:51 pm
Ok so this is what I plan to link the bar with.
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 Image0096
Moog nuts & washers
grade 8 bolts (otherwise identical to the Moog's grade 5 bolts)
Addco poly bushings
zinc plated spacers from Ace
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 Image0098
If for some unforeseen reason, this doesn't work out when I do the install, I can fall back on the Moogs, which is why I didn't cut those ones, but I think this will be ideal.
Btw, I weighed the Addco front bar against the FE2 front bar and the Addco is about double the weight. I got 19.5lbs for the Addco and 9.5lbs for the FE2. This is not the most accurate scale but that gives an idea of the girth of that tank of a bar.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptySun Jun 27, 2010 5:47 pm
looks pretty beefy.One thing i will warn against is this:
When i switched over to poly links the nut stripped off the bolt b/c it couldnt hold the tension of the bar with the non-giving bushings. They were not even all the way tightened when this happened either.
BUY good bolts and nuts. And make them slightly longer than OEM b/c it makes it easier to install unless your bar end sits lower than mine did.
...that is all.
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 Dsc_0110
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptySun Jun 27, 2010 6:47 pm
Good info, Matt. It shows the harder bushings do have a real effect - stiffening the operation of the stabi-bar even more. One other thing I would watch out for... If you mount the threaded (nut) end of the link aiming up, toward the car, you must take care so that it isn't too long, or else it could make contact with the axles during a severe suspension compression or hard bump. To be on the safe side, aim the nuts down, or trim them after installation.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptySun Jun 27, 2010 6:50 pm
...that is all.
What hardware did you use when it stripped? And I presume you had to go buy new bolts and nuts that were better and that took care of it? The Moog hardware has grade 5 bolts based off the markings.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptySun Jun 27, 2010 7:10 pm
i used the hardware that came with the autozone HD kit (might have even been moog) from years ago when i replaced the oem set.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptySun Jul 11, 2010 2:37 pm
UPDATE: after more than a year and a half of trying various parts and configurations, testing on the road and on track, I've improved upon the original design in this post, which revealed some less-than-optimal attributes. The resulting product is available for sale at this link: https://rivperformance.editboard.com/t8902-fs-high-performance-sway-bar-links-w-lifetime-guarantee#138993
Thanks to Codith and others for pictures and info posted above. I think a good link set-up is important, especially if you upgrade the bar and bushings. If your links are loose, the benefits are lost!
I recently upgraded to the Energy Suspension (red poly) link bushings and washers for the front stabilizer bar link. Since I didn't have new hardware, I reused my old Moog steel bolts and nuts - these were a little rusty after a few years, but still functional.
As I was reinstalling to the OEM recommended 156 lb-in torque, I realized the bushings felt quite loose, so I upped the torque to 220 lb-in, in doing so stripping the threads on the bolts. On closer examination, I could see what was going on - the old Moog link bolts were threaded only far enough to accommodate the Moog bushings, which were thicker (and softer) than the new Energy Suspension polyurethane. The result is, the nut runs out of thread and strips out.
With the nuts on tight, the end result in using the ES red poly bushings with Moog hardware is a loose-fitting link connecting the stabilizer bar to the control arm (not good). Even with full torque applied to the nut, I could still easily turn the link bushings by hand. You can see how loose they are in these images:
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 IMG_4256
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 IMG_4254
Since I needed to buy new hardware anyway, I decided to follow the same direction as Codith and buy some better quality bolts, spacers, and nuts. Might as well customize the set up to get a nice, tight, strong link between the bar and the control arms. In doing so, we're going to allow the bar more tightly control the forces of body roll.
McMaster-Carr sells high quality hardware in low quantities, and after some quick searching, I ordered the following that should work with our application:
Item# 91251A645 Black-Oxide Alloy Steel Socket Head Cap Screw 3/8"-16 Thread, 5-3/4" Length, 1-1/4" Threaded - (qty 2) $6.96
Item# 92510A808 Aluminum Round Spacer 3/4" OD, 1" Length, 3/8" Screw Size - (qty 2) $9.26
Item# 93591A300 Grade 9 Oval-Top Hex Locknut 3/8" - (qty 10) $6.29
I realize this is a bit pricey compared to the available kits, but for a custom selected set-up that fits the ES red poly bushings correctly, it's worth the price. And because the hardware is beefier and better quality, you can confidently remove and reinstall several times. Here's a comparison of the new hardware vs. old Moog, and the ES poly vs. Moog bushings:
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 IMG_4247
Note the difference in thickness between the Moog (black) and ES poly (red) bushings. Also note the larger dia 3/8" bolt, much larger spacers, and the grade 9 lock nuts. Most importantly, notice how much more thread we have on the new bolt. Now we can apply more torque to squeeze those bushings nice and tight on the bar. All of this works to form a very strong, durable link between the stabilizer bar and control arm to resist deformation during hard cornering. And yes, it makes a real difference, imo. Here is everything assembled:
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 IMG_4245
Installing the new link set:
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 IMG_4249
Torque to 200 lb-in (this is the point where the nut reaches the end of thread). The bolt head is 8mm Allen hex, nut uses 14mm (9/16") deep socket:
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 IMG_4250
Here is the assembly, viewed from in front of the control arm. Note the parallelism of the bar and the control arm. Also note how the link is very normal to the two, not skewed at an angle. Bushings are seated very tight against the bar and arm:
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 IMG_4253
I'm going to run this set-up for a while, hopefully try some more autocross, and inspect the parts - will report back results in a few months. I don't anticipate anything too bad will happen. I do predict hard corner handling will improve slightly.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptySun Jul 11, 2010 2:54 pm
Very nice job. Quality hardware and the parallelism of the sway bar to the lower control arm is perfect.
Also, nice looking new control arms.
This set-up can only help compared to what what is in there before.
Thank you for writing down the sizes of everything, now I can go to the Industrial Hardware supplier near me and get the parts ahead of time, instead of having to measure everything first. You saved me and my back some aggravation.
Thanks
Now who can possibly do the measuring of the rear's, Please.?
I notice the way mine are now the sway bar is not parallel to the control arm. I'm assuming the spacer length is incorrect.
The only way to measure is with weight on wheels and I can't get the measurements on the ground and don't have a lift available to me that supports the wheels.
Maybe one of the full time mechanics that have the necessary lift can measure for the proper spacer length to keep the bar parallel, please.
Unfortunately Back Pain has stopped me from doing even these simple jobs, so the more I know ahead of time the easier it is to do the swap or I'll pay the guy down the road to swap them for me as long as I have all the correct length spacers and bolts.
Thanks again.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptySun Jul 11, 2010 3:15 pm
Thanks again.
Is this a hint? lol
The rear factory link from a PAU F41 (which is what I used, along with the bar) already has poly bushings in them. They are also much shorter height wise. I think you'd have to "build your own" with a longer center piece to accommodate the taller bushings. I'll take pics next time it's up in the air.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptySun Jul 11, 2010 3:19 pm
Thank You. Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 Icon_smi
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptySun Jul 11, 2010 5:01 pm
In addition to the correct size bolts and spacers, make sure the bolt has 1-1/4" of threaded length. This is important for proper tightening/position of the links.
Also, the black oxide coating on the bolt makes it ideal for link duty. Get this if you can. According to Mevotech, supplier of aftermarket suspension parts:
"Black oxide coating provides high resistance to variable corrosion factors such as road debris and adverse road and weather conditions, ensuring prolonged life of the stabilizer link."
Btw, McMaster Carr ships very fast. I got my order within 2 days.
I may order a quantity of these parts at lower price and sell as a kit to anyone interested. The bushings come in red or black, and piecing together this kit cost me about $38. I can order a few sets at bulk rate and sell them for $30 shipped for the front set. It should be a similar cost for the rears, but haven't yet priced them.
bullseye-shawn
bullseye-shawn
PostSubject: temp   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Sep 06, 2010 10:27 am
Okay I noticed that the sway bar links were not on the car. Like the bolt has rusted and all has fallen off. There wasnt even a bushing there on the passenger side. Just hanging there doing nothing so i baught a set from energy suspension. It was the kit and I baught it for both sides. Ill post when they come in
Product ID: MOOG-K8989-Front
Product Name: Front Sway Bar End Link Kit
Quantity: 2
Unit Price: $10.53
Hopefully everything will go smoothly during the install and mostly hope it helps the cornering abilities of the car.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Sep 06, 2010 10:33 am
Well, simply replacing the links will help the handling, given that they were "missing". Although, just a urethane link mod won't really improve the handling over the stock links. The sway bars on the Riv are mush, especially the hollow rear bar. I found that a front and rear sway bar upgrade, along with a STB is what makes all the difference.
bullseye-shawn
bullseye-shawn
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Sep 06, 2010 10:43 am
Thanks for the advice. I am fabbing up my own STB now and will be installed in the next few weeks. Ill post pics as I install it. Im having all the mounts and bars made so ill have enough STB for 6 cars. The price for all the plates to be laser cut and the car stock was cheaper than just enough to do mine
New shocks are next on my list for the rear. Im going with GR-2's
Derek
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Sep 06, 2010 1:10 pm
If you have extra mounts and you're willing to sell them I might be interested. I wanted to do the caddy stb for my car but the fitment was off too much for my liking. I'd love to see pics when you get it finished and if you are interested in selling the extras you can pm me.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Nov 08, 2010 8:20 pm
When I had my swaybar endlinks break, I heard it happening. I was turning and going over a bump and heard a loud snap. I would then hear a loud clunk everytime I would go over a rough spot in the road. You could feel the clunk in the floor and the car didn't feel right while driving. It just felt off. I found it was broken by using a crow bar and prying the sway bar up and you could see the sway bar move up and down while the endlink stayed put. Hopefully that is your problem because it is an easy fix.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Nov 08, 2010 9:09 pm
This definitely works if you are lucky enough to pry the busted side. And yes it is an easy fix.
PostSubject: Re: Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Nov 08, 2010 9:49 pm
Well, I replaced my front rotors, pads and sway bar links today. I couldn't wait for feed back on how to support things so I just jacked up both sides to do the breaks and using socket wrenches and an impact gun I disassembled the sway bar links slowly watching to see if anything was opening up as I loosened it, but everything stayed put, so I had at her.
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 IMG_9099
Here are the links...
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 IMG_9092
The sway bar links were not broken but the bolt was seized in the spacer.
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 IMG_9100
Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 IMG_9101
So to loosen the bolt from the spacer I secured the spacer witha vice grip while the impact gun broke it loose from below. On the right sway bar link ( where the noise was coming from ) the angle on the bolt was so severe that the bushing had moved up and allowed the bolt to come into contact with the sway bar, so using a "C" clamp I squeezed the new bolt away from the sway bar and made sure the new bushing was properly in place. With my Dads help, I gave the wheels a good shake down and pushed on it in every direction to see if there is any play in the ball joints and tie rod ends. I must be missing something cause I couldn't find any play. I can confirm though that the ball joints are OEM as the three rivets are in place instead of the bolts, otherwise I would have replaced them too. I visually inspected tranny mounts, cradle mounts and struts but don't see any obious issue or perhaps, I am not sure what to look for. Anyway, I haven't heard the "pop" sound as of yet so I am keeping my fingers crossed that the problem is solved. Thanks for all the responses and great info guys.
PostSubject: temp   Write-Up: Stabillizer (Anti-Sway) Bar Link Upgrade - Page 2 EmptyMon Nov 08, 2010 10:19 pm
OK I see better now.
Your sway bar links have been replaced before.
If the POP is gone it just means that one link loosened or was not tight enough in the first place.
I'd be sure to check the strut mounts - with wheels on like normal open the hood and bounce the car to see if the struts move too much as evidenced by the strut rod in the bushing in the mount. They are supposed to move a little but only a little.
Also it may be that when you did the brakes you tighetned the calipers so they no longer clunk, if that was the problem.
O by the way in the photo that tie rod ends looks worn out or damaged. Is it? Did you wipe it off and check? It does not look original (has a grease zerk this is not a bad thing by the way) and looks like the boot is chewed off (meaning it gets gritty inside and wears out fast - ball gets smaller then it starts to clunk in the internal seat).
» Sway bar link recommendations
» Seville Rear Sway Bar Upgrade Questions
» FAQ: G-Body Suspension Basics
» Write-Up: Cadillac STS Rear Sway Bar Install
» upgrade brakes
