| Heater Core for IC Heat Exchanger | |
Northeast Member
Name : Joined : 2010-09-14 Post Count : 84 Merit : 1
| Subject: Heater Core for IC Heat Exchanger Fri Dec 10, 2010 12:25 pm | |
| Anyone here using heater cores instead of intercoolers for FMHE in their SSIC setup? Have you had much success? | |
| Subject: Re: Heater Core for IC Heat Exchanger Fri Dec 10, 2010 3:34 pm | |
| interesting idea? do they make heater cores that can handle the volume necessary for a s/c? | |
Northeast Member
| Subject: Re: Heater Core for IC Heat Exchanger Fri Dec 10, 2010 3:39 pm | |
| oh, not sure I knew there was a volume requirement. Good question. I was even thinking about stacking 2 of them, but am also aware I'd need cores with very little restriction, bends, etc.
Whats the average volume requirement to cool sufficiently? Do you happen to know? | |
| Subject: Re: Heater Core for IC Heat Exchanger Fri Dec 10, 2010 4:45 pm | |
| nope. but i do know that the openings of the average intercooler are alot larger than your average heatercore. | |
Northeast Member
| Subject: Re: Heater Core for IC Heat Exchanger Fri Dec 10, 2010 5:40 pm | |
| Whats the typical FMHE in/outlets 3/4"? A heater core is 5/8". So about 1/8" difference. I think a Cadillac heater core has the 3/4 fittings. | |
| Subject: Re: Heater Core for IC Heat Exchanger Fri Dec 10, 2010 6:05 pm | |
| no kiddin? well then...give it a shot. arnt heater cores pretty small though? | |
Northeast Member
| Subject: Re: Heater Core for IC Heat Exchanger Sat Dec 11, 2010 12:54 pm | |
| They vary. Caddy Fleetwood is around 10.12 x 5.62 x 2 in (for just one). Run 2 of these and it appears to me that it would work, and your only looking at about $40. | |
| Subject: Re: Heater Core for IC Heat Exchanger Sun Dec 12, 2010 2:02 am | |
| I don't have a ton of experience with ICing but when we installed a SSIC onto Manuels car with a full size (zzp stage 2) front heat exchanger, the front mount still got uncomfortably hot to the touch pretty quick as the car warmed up. For that reason, I'd say bigger the better on the front mount pretty much no matter what.
The SSIC core runs 1/2-5/8 hoses so that's right about in typical heater core territory. You wouldn't be running big 3/4 hoses on a SSIC. | |
Northeast Member
| Subject: Re: Heater Core for IC Heat Exchanger Sun Dec 12, 2010 10:55 am | |
| - turtleman wrote:
- when we installed a SSIC onto Manuels car with a full size (zzp stage 2) front heat exchanger, the front mount still got uncomfortably hot to the touch pretty quick as the car warmed up.
Thanks man. So you are saying that during just the idle/warm up, the intake air was hot enough to warm the water in the intercooler to the point where the actual intercooler was hot to the touch? WOW, I figured maybe it would get a little warm under heavy boost driving, but not from just the warm up. Thats crazy! | |
| Subject: Re: Heater Core for IC Heat Exchanger | |
