 Cornering lamps. Do yours work without headlights on?
5 posters
Sweepspear
Sweepspear
Cornering lamps. Do yours work without headlights on? Empty
PostSubject: Cornering lamps. Do yours work without headlights on?   Cornering lamps. Do yours work without headlights on? EmptyThu Apr 21, 2011 12:38 pm
Unlike other cars I have owned with cornering lamps, the lamps on my '96 only work when the headlights are on.
Today on my way into work, I am sitting across an intersection from another '95-'98 Riviera that was making a turn.
I noticed it's cornering lamp was on despite the headlights being off.
Not a big deal, just curious if it is a year to year difference?
Like I said, every other car I have owned that had them, (including my '70) the lights always illuminate when the turn signal is on.
scratch
PostSubject: Re: Cornering lamps. Do yours work without headlights on?   Cornering lamps. Do yours work without headlights on? EmptyThu Apr 21, 2011 1:37 pm
Don't know for sure, but my guess is that the headlight should be on with the cornering lamp.
PostSubject: Re: Cornering lamps. Do yours work without headlights on?   Cornering lamps. Do yours work without headlights on? EmptyThu Apr 21, 2011 2:51 pm
mine only work when the headlights are on, but i have a 96 like you....so not much help.
Cornering lamps. Do yours work without headlights on? Dsc_0110
Derek
PostSubject: Re: Cornering lamps. Do yours work without headlights on?   Cornering lamps. Do yours work without headlights on? EmptyThu Apr 21, 2011 8:16 pm
Same on my 95, only with the headlights on. I've never tried it with just the marker lights on to see if they come on.
Merit : 104
PostSubject: Re: Cornering lamps. Do yours work without headlights on?   Cornering lamps. Do yours work without headlights on? EmptyThu Apr 21, 2011 9:22 pm
My '97 is the same way, and traditionally that is the way they've been wired.
Our '71 Lincoln and '77 through '84 Cadillacs also only turned them on with the headlights (not really any point to use 'em in the daylight...)
Perhaps your '70 had them added after the factory?
» Write-Up: Yellowed Corner Lenses
» Exterior LED lighting
» Front Cornering Lamp Bulb Replacement?
» FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On
» Does this really work?
