| | Headlight bulb replacement. | |
| | Author | Message |
Name : Larry Age : 66 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2149 Merit : 149
 | Subject: Headlight bulb replacement. Fri Jun 24, 2011 11:41 am | |
| Is there a write up on how to get the headlight lenses out? I need to replace the bulb on one side (passenger side) FSM says you need to remove the entire lense on each side. I've done the cornering lights, but not the headlights. | |
|  | | AA Administrator
 | Subject: Re: Headlight bulb replacement. Fri Jun 24, 2011 11:57 am | |
| _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Headlight bulb replacement. Fri Jun 24, 2011 11:59 am | |
 | Subject: Re: Headlight bulb replacement. Fri Jun 24, 2011 4:38 pm | |
| According to the FSM, you need to remove the front bumper fascia, wheel house panel, and engine splash shield? Please tell me you don't have to remove the front of the car to replace a bulb. Are they kidding me? | |
|  | | Derek Fanatic
Name : Derek Age : 41 Location : New Jersey Joined : 2010-03-23 Post Count : 255 Merit : 10
 | Subject: Re: Headlight bulb replacement. Fri Jun 24, 2011 5:01 pm | |
| Wait a min! You DO NOT need to remove the lens to change the bulb. In the FSM after headlamp removal procedure is the bulb replacement procedure and it read as follows. Passenger side: 1 low beam right side - remove low beam socket from headlamp module by entering through the engine compartment, behind the upper tie bar. Turn socket counterclockwise to remove. -connector from bulb. Driver is almost the same but you have to remove the top of the air cleaner to make room. It can be a bit of a squeeze if you have large hands but it is doable. Pop the hood and look straight down behind the headlights and you should see the socket sticking out. Just be careful you change the right bulb, the high beam bulb is a lot easier to spot than the low beam bulb which is tucked more into the corner.
Last edited by Derek on Fri Jun 24, 2011 5:05 pm; edited 1 time in total (Reason for editing : addl info) | |
|  | | AA Administrator
 | Subject: Re: Headlight bulb replacement. Fri Jun 24, 2011 5:33 pm | |
| Good call, Derek. I totally missed that he is just replacing the bulb itself. Larry, the bulbs can rather easily be replaced as Derek says. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Headlight bulb replacement. Fri Jun 24, 2011 5:44 pm | |
- Good call, Derek. I totally missed that he is just replacing the bulb itself. Larry, the bulbs can rather easily be replaced as Derek says.
Thank You Aaron and Derek. I was just reading through the "silverstar" thread, and I saw that it can be done through the engine compartment. I am pretty sure I read in the owner's manual that the headlamp assembly had to be removed to change the bulb.I am glad it isn't that involved. | |
 | Subject: Re: Headlight bulb replacement. Fri Jun 24, 2011 7:04 pm | |
| OK, just replaced both head lamp bulbs. Took 10 minutes. Just had to remove the top of the air box on the driver's side, simple. My passenger side headlight had been out for a few weeks. If I tapped on the lense it would come on. This morning, it wouldn't come on with me smacking the lense. Got to work a bit early, so I opened the Owners manual, looked up Headlamp bulb replacement, and read the bottom of page 6-31. A little misleading. Had I turned the page, I would have seen that it could be done through the engine compartment. Thanks Again.  | |
|  | | AA Administrator
 | Subject: Re: Headlight bulb replacement. Fri Jun 24, 2011 7:09 pm | |
| That's more than misleading, it's contradicting. If the headlamps in fact "must be removed to replace the headlamps", there should not be instructions to do it from inside the engine bay on the next page! Seems like some incorrect copy got cut and pasted from a previous owners manual? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
 | Subject: Re: Headlight bulb replacement. Fri Jun 24, 2011 7:12 pm | |
- That's more than misleading, it's contradicting. If the headlamps in fact "must be removed to replace the headlamps", there should not be instructions to do it from inside the engine bay on the next page! Seems like some incorrect copy got cut and pasted from a previous owners manual?
On the next few pages, it does describe how to do it through the engine bay, but I stopped reading right there because I had to get to work. Then when I got home, I looked in the FSM, and missed the bulb replacement pages there too, because I thought I would have to pull the entire assembly. I'd hate to replace the lense because it got cracked. What a pain in the butt that looks like. | |
|  | | AA Administrator
 | Subject: Re: Headlight bulb replacement. Fri Jun 24, 2011 7:20 pm | |
| Agree. Oh, the days when headlamps were made of glass, and you could replace the entire assembly in 10 mins for $10. But it does make some sense to reuse assembly, rather than throw it away each time the bulb burns out. My assembly has remained in really good shape over the years. Another case of inconvenience vs. wastefulness. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
|  | | LaFlare Member
Name : G Joined : 2010-07-14 Post Count : 84 Merit : 1
 | Subject: Re: Headlight bulb replacement. Wed Jan 25, 2012 3:48 pm | |
| for the (yellow) corner lights, what is the bulb replacement number? 194? and the manual doesn't show how to replace it right? | |
|  | | Mr.Riviera Expert
Name : Matthew Age : 36 Location : Florida Joined : 2007-01-17 Post Count : 4394 Merit : 101
 | Subject: Re: Headlight bulb replacement. Wed Jan 25, 2012 3:57 pm | |
| - LaFlare wrote:
- for the (yellow) corner lights, what is the bulb replacement number? 194? and the manual doesn't show how to replace it right?
It is not a 194. I believe it is 3057. There is a 8mm (i think) screw holding the lens on at the bottom. You will need to push down on the bumper to see it. One the screw is out, pull from the front and it should come loose. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily  | |
 | Subject: Re: Headlight bulb replacement. Wed Jan 25, 2012 4:43 pm | |
| The cornering lamp is a 3057, but it isn't yellow. Are you talking about the front/side yellow lamps in the bumper cover? If so, there are two bulbs in the lense. One is a 3057, and the other is a 194. To get to them, just remove the splash shield retainers at the front of the wheel well, pull the splash shield out a bit, and reach in there and twist the sockets to get to the individual bulbs. If it's the actual cornering lamp you want to replace, as Matt said, there is a small screw at the bae of the lense. Push down on the bumper cover, and remove it. Be careful the screw doesn't drop inside the bumper. After that, pull on the lense at the front edge. It will pivot out, and then you can pull the other side out from the clip that holds it. Twist the socket out and replace the bulb. | |
|  | | LaFlare Member
 | Subject: Re: Headlight bulb replacement. Wed Jan 25, 2012 6:13 pm | |
| thanks for the replies and yes i meant the corner lights not the orange signal lights. | |
|  | | Eldo Expert
Name : Mark Age : 58 Location : West Salem, Oregon... FINALLY Joined : 2009-04-09 Post Count : 3104 Merit : 104
 | Subject: Re: Headlight bulb replacement. Thu Oct 09, 2014 2:15 am | |
| This is something I SHOULD have mentioned many moons ago. On the other hand, I wonder if my car was the only one so 'blessed', as no one else ever mentioned it... It almost belongs in the "Didn't know this about my Riviera" thread. Now, the shop manual is just plain wrong about being able to replace bulbs without removing the entire friggin' lens assembly. However, despite my brain disbelieving, I just confirmed that it says that ALL headlight bulbs should be removed counterclockwise... Normally, this would be true. But in my '97, the passenger side bulbs are indeed backwards - I have to rotate them CLOCKwise to REMOVE...   boys | |
|  | | albertj Master
Name : Location : Finger Lakes of New York State Joined : 2007-05-31 Post Count : 8519 Merit : 181
 | Subject: Re: Headlight bulb replacement. Wed Oct 15, 2014 8:00 pm | |
|  | | Eldo Expert
 | Subject: Re: Headlight bulb replacement. Mon Sep 12, 2022 1:25 am | |
| Yes, per FSM for both high beams: Remove the 2 (forward-facing) headlamp-bracket mounting bolts at the inboard edge of the headlamp in order to allow access to the high beam sockets. Remove the sockets by reaching through the opening and turning the sockets counterclockwise (maybe.)
As an aside, I've always bitched about how a headlight used to - and SHOULD - be replaceable on a dark & stormy night with just a phillips screwdriver... Now I've learned how 'good' our Rivi's are. Here is someone's procedure for a Gen-I Cadillac CTS coupe:
"First, remove the top cover of the radiator. Next you remove the 2 outer black plastic clips on the top of the bumper cover along with the two 10mm bolts. Next you have to remove 2 plastic clips on each of the wheel wells. Then there are about 6 plastic clips on the bottom of the car. Pull the side of the bumper cover away from the wheel wells & pull towards you. Next there will be three 10mm bolts holding in the headlight & the harness on the bottom of the headlight. Once you have the light removed from the car, you have to remove the three 7mm bolts on the bulb cover. The D1S bulb is held in with 2 Torx screws. (I forgot to mention that there is one 10mm bolt behind each inner fender that holds the bumper cover to the fender.)"
FIRST KILL ALL THE LAWYERS... THEN KILL ALL THE ENGINEERS!!! | |
|  | | Sponsored content
 | Subject: Re: Headlight bulb replacement.  | |
Similar topics |  |
