 My L67 swap from LesabreT.com
L67GAMSE93
gmann3001
pbrktrt
RoughNecks17
29 posters
Go to page : Previous  1, 2, 3 ... 6, 7, 8 ... 11, 12, 13  Next
Merit : 63
My L67 swap from LesabreT.com - Page 7 Empty
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySat Apr 14, 2012 5:36 pm
*drools all over the place*
If you don't post any more pictures I won't send you all the 'stuff' I said I was going to send you razz .
Merit : 123
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySat Apr 14, 2012 5:57 pm
... hrm... I've got a drink in-hand, its after 6... do I do a writeup? or just play Minecraft?
... ah why not... (uploading 38 pics...)
Merit : 123
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySat Apr 14, 2012 7:29 pm
Righto!
Its now time for the hand porting part of the program.
Usually I rough things in using a carbide burr dremel bit:
My L67 swap from LesabreT.com - Page 7 IMG_2648
The spots we need to be working on are the corners of the outlet triangle where I can work the shape in by hand:
My L67 swap from LesabreT.com - Page 7 IMG_2650
I start by knocking down the edge:
My L67 swap from LesabreT.com - Page 7 IMG_2651
And then blending in the rounded shape:
My L67 swap from LesabreT.com - Page 7 IMG_2652
I slowly work my way around to the other corners:
My L67 swap from LesabreT.com - Page 7 IMG_2653
Once the rough edges are knocked off I move to a rock drum bit:
My L67 swap from LesabreT.com - Page 7 IMG_2654
The same work is done on the top of the outlet triangle as well:
My L67 swap from LesabreT.com - Page 7 IMG_2655
More blending work:
My L67 swap from LesabreT.com - Page 7 IMG_2656
My L67 swap from LesabreT.com - Page 7 IMG_2657
My L67 swap from LesabreT.com - Page 7 IMG_2658
My L67 swap from LesabreT.com - Page 7 IMG_2659
Then a flap sander at 80 grit:
My L67 swap from LesabreT.com - Page 7 IMG_2660
Then 120:
My L67 swap from LesabreT.com - Page 7 IMG_2661
240:
My L67 swap from LesabreT.com - Page 7 IMG_2663
1000:
My L67 swap from LesabreT.com - Page 7 IMG_2669
This outlet is done!
My L67 swap from LesabreT.com - Page 7 IMG_2668
Moving to the inlet, I start by gently using the carbide bit clean away the crap:
My L67 swap from LesabreT.com - Page 7 IMG_2664
Then 80 grit:
My L67 swap from LesabreT.com - Page 7 IMG_2665
120:
My L67 swap from LesabreT.com - Page 7 IMG_2666
And 240 to finish:
My L67 swap from LesabreT.com - Page 7 IMG_2667
My L67 swap from LesabreT.com - Page 7 IMG_2670
Next is to push out the needle bearings from the casing. The most common method of this is by threading in Zerk grease nipples into the air relief holes and pumping in grease behind them.
My L67 swap from LesabreT.com - Page 7 IMG_2671
First the hold needs to be drilled to the tap-drill size. For anyone new to tapping, this is the diameter of a threaded hole at its tightest. So if you took calipers to a bolt, its the smallest DIA. You have to be careful to not nick the bearing, but make the hole as deep as possible.
My L67 swap from LesabreT.com - Page 7 IMG_2672
I have two flat bottom taps for this. One is a normal one, the other has been cut back so that I can tap a full size hole that is not very deep. (Taps are tapered.)
My L67 swap from LesabreT.com - Page 7 IMG_2673
Nipples installed:
My L67 swap from LesabreT.com - Page 7 IMG_2674
And the old bearings fired out:
My L67 swap from LesabreT.com - Page 7 IMG_2675
Next is bath time. All the chips, grease, and crap needs to be washed out of the casing. Leaving these clean holes for new bearings to be installed:
My L67 swap from LesabreT.com - Page 7 IMG_2677
Sorry Z-type, a bit of paint came off when cleaning. It had some galvinic corosion under it. You will need to touch up the blower a bit.
My L67 swap from LesabreT.com - Page 7 IMG_2679
For pressing in new bearings you will need a press. Most people do this carefully to get the bearing pushed in about one US dime depth. This is two Canadian dimes deep. The first SC that I did the bearings on, I measured the stock depth before removing them, and made this fine tool so its perfect every time:
My L67 swap from LesabreT.com - Page 7 IMG_2681
Brand new bearings:
My L67 swap from LesabreT.com - Page 7 IMG_2682
They come pre-greased:
My L67 swap from LesabreT.com - Page 7 IMG_2683
And in they go:
My L67 swap from LesabreT.com - Page 7 IMG_2680
Woo hoo!
My L67 swap from LesabreT.com - Page 7 IMG_2684
Now the other bits go back on:
My L67 swap from LesabreT.com - Page 7 IMG_2685
My L67 swap from LesabreT.com - Page 7 IMG_2686
My L67 swap from LesabreT.com - Page 7 IMG_2687
My L67 swap from LesabreT.com - Page 7 IMG_2688
Next I have some stainless steel bolts and other hardware to go on and the PCV intercept to make. That will be next weekend.
Got to love a perfect angled blower outlet:
My L67 swap from LesabreT.com - Page 7 IMG_2689
FIN:
My L67 swap from LesabreT.com - Page 7 IMG_2676
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySat Apr 14, 2012 7:35 pm
Very nicely done.
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySat Apr 14, 2012 7:54 pm
Will this increase HP?
Merit : 123
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySat Apr 14, 2012 8:45 pm
sure.
Its optimizing the blower for use with smaller SC pulleys. The outlet is opened a bit to move the CFM efficiency range more in check for the speed that the blower is spun at vs. stock. Also Eaton themselves say that a proper closing of the silencer holes improves efficiency and reduces heat. Which moves us to the next HP gain. The m62 makes boat loads of heat. ANY reduction that you can come up with is new HP.. The slightly opened outlet shape, the new shape of the outlet, and the inlet porting... all go to make the air-stream cooler. Which in turn improves HP. Like normal porting of heads and inlet manifolds, its taking a mass produced factory cast item and optimizing it for your current use.
Too bad this is likely my last m62 eh? wink
Merit : 17
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySat Apr 14, 2012 9:52 pm
Wow!
gmann3001
gmann3001
Name : Glenn W. Peck
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySat Apr 14, 2012 10:26 pm
Sweet! clap
http://gmann3001@yahoo.com
Merit : 63
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySun Apr 15, 2012 10:32 pm
Wow man that's AMAZING work...I can't wait to see this thing in person! The only thing that is really disappointing is that you simply cannot see this piece of art once it's installed frown razz .
Oh, and no worries on the paint. I didn't expect it to survive the machining process and all the handling. I can fix that in no time! No problem at all happy . Your 'payment' will be on the way in a few days!
Merit : 63
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyWed Apr 18, 2012 10:36 pm
Alright, time for a crap-ton more pictures!
Did a bit of work to the Lesabre in the last few days, none of it L67 related, but oh well! I have this thread already open razz . Me and dad tackled the rear struts. They've been slowly fading over the past few years and they finally bit it before this past Winter, so it was time to replace them. Instead of replacing with KYB's, like the KYB's I have on the front, I wanted something more for the rear. I took a page from my old Riviera once more and installed air shocks.
This isn't really a write-up, just more of an opportunity to take up space on the internet with pictures and give you all something to look at happy . Neither of us had really done anything like this kind of set up (I've replaced air shocks before, but not struts) so we just attacked it.
My L67 swap from LesabreT.com - Page 7 MaroonT432
Two bolts on top to hold the mount in, and two spindle bolts on the bottom.
My L67 swap from LesabreT.com - Page 7 MaroonT434
Dad wrenching on the bottom bolts. See the big silver bar on the floor? Breaker bar. Made from an old trampoline frame wink .
My L67 swap from LesabreT.com - Page 7 MaroonT435
One out.
My L67 swap from LesabreT.com - Page 7 MaroonT433
After some struggling and a broken impact extension later, both are out!
My L67 swap from LesabreT.com - Page 7 MaroonT437
Kind of a lack of pictures this time, but we were both tired and busy figuring out exactly what we were doing. Long story short, we had to install and remove the first shock 3 times because I kept assembling the mount in the wrong order lol...like i said, long story. We got the other side installed in a flash and quit for the night.
My L67 swap from LesabreT.com - Page 7 MaroonT436
This morning, I had a few errands to run, so I went to NAPA (hate that place, by the way) and picked up a bigger supercharger tensioner pulley. Stock on the left is 3", this replacement is 3.25". This is simply to pick up some of the slack of the belt from the smaller supercharger pulley I'll have, and to help prevent belt slip.
My L67 swap from LesabreT.com - Page 7 MaroonT438
My L67 swap from LesabreT.com - Page 7 MaroonT439
So I know what you're thinking..."Air shocks? But you don't have a compressor!" Taking yet another page from my Riviera - when my Riviera's compressor died, I replaced it with a manual fill valve with new air lines. That way I could add or remove pressure and ride height/handling as I pleased. Did the same thing on the Lesabre! I decided to hide the fill valve inside the trunk. To run the lines, I had to remove the tail light assembly.
My L67 swap from LesabreT.com - Page 7 MaroonT440
I made a hole to the right of the trunk latch thing on the inside edge of the trunk. This is normally hidden by carpet.
My L67 swap from LesabreT.com - Page 7 MaroonT441
Ta da!
My L67 swap from LesabreT.com - Page 7 MaroonT442
This is where the tail light assembly is - this is right above the license plate.
My L67 swap from LesabreT.com - Page 7 MaroonT443
So that T valve stays there, and I started running the air lines. First thing, connect the line to the nipple thing on the shock.
My L67 swap from LesabreT.com - Page 7 MaroonT444
I ended up lucky enough to be able to run the lines nowhere near the exhaust so there's no chance of them melting or anything. Anywhere the line touched a rough or sharp edge, I ran wire loom around it. So, once those were run, I added the threaded compression fitting and an o-ring to attach to the T valve.
My L67 swap from LesabreT.com - Page 7 MaroonT445
Attached both the lines to the T...
My L67 swap from LesabreT.com - Page 7 MaroonT446
My L67 swap from LesabreT.com - Page 7 MaroonT447
Filled the system with 50 PSI, put the wheels back on, and set it on the ground. 50 PSI is probably a bit much for ride height, so after I took this picture I ended up bleeding out the pressure down to 30 PSI. Once the shocks wear in and i get an alignment, I'll probably need to add pressure.
My L67 swap from LesabreT.com - Page 7 MaroonT449
That's about it for now. Once the supercharger is on and everything is working correctly, the rear needs an alignment BADLY and the fuel filter changed. I didn't have the proper tools to replace the fuel filter so Ill let the guy who does the alignment do it razz .
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySun Apr 22, 2012 4:55 am
Magnificent!
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySun Apr 22, 2012 9:35 am
Nice job! You'll probably notice the ride height will settle when you take it out for the first drive. I found 40-50 works well. I installed the same kit on my Riv, but mounted the fill valve under the rear bumper. Makes adjusting a snap!
Merit : 63
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptySun Apr 22, 2012 10:06 pm
That's about what i figured Aaron...I vaugely remember the setup on my Riviera being the same way. I kept it at 30 for a good while, then as I drove it the shocks wore in and I kept it around 50 until the car was taken apart.
I considered putting the valve on the outside somewhere but I didn't really want it exposed too much or want anyone to see it. I do my best to keep things stock appearing smile .
I can't wait to try them out though - it should handle a lot better than it ever did. Should be able to drive the car in 2 or 3 weeks! I know Karma is hard at work putting the finishing touches on the supercharger happy .
Merit : 123
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyMon Apr 23, 2012 8:20 pm
Ok, so last bunch.
First we have the new stainless steel hardware:
Snout:
My L67 swap from LesabreT.com - Page 7 IMGP4876
Fuel rail and bits:
My L67 swap from LesabreT.com - Page 7 IMGP4877
My L67 swap from LesabreT.com - Page 7 IMGP4878
And I dunno if the shoulder is to big on these or not Andrew since I didn't have my spare TB at the shop, but I'll send em anyway.
My L67 swap from LesabreT.com - Page 7 IMGP4879
Now, this part of the show is making a PCV intercept.
Here is the first version I made, this is still running on my engine:
My L67 swap from LesabreT.com - Page 7 IMGP4881
My L67 swap from LesabreT.com - Page 7 IMGP4880
And goes in place of the stock PCV cover.
My L67 swap from LesabreT.com - Page 7 IMGP4882
Basically this takes a line off the PCV valve and shunts it away to a catch-can/oil separator and then sends it back to the proper stock location. Its plug and play so you can go back to stock at any time.
To start making the new version, we start with a bit of Delrin in the lathe:
My L67 swap from LesabreT.com - Page 7 IMGP4884
Then turn out a little nub that's the same DIA as the nub on the PCV valve:
My L67 swap from LesabreT.com - Page 7 IMGP4885
And done with a little hose barb:
My L67 swap from LesabreT.com - Page 7 IMGP4886
This sits just above the nub end of the PCV valve when its bolted down. The connection is made by a small bit of hose. The spring assembly goes around the whole issue.
Next is making the hole for the PCV exit to get out. This is done to a specific depth so the top is flawless unlike the prototype one where I had to plug it.
My L67 swap from LesabreT.com - Page 7 IMGP4887
And done:
My L67 swap from LesabreT.com - Page 7 IMGP4888
Next we are done with the lathe, so I just use a cut-off bar:
My L67 swap from LesabreT.com - Page 7 IMGP4889
And off:
My L67 swap from LesabreT.com - Page 7 IMGP4890
My L67 swap from LesabreT.com - Page 7 IMGP4891
My L67 swap from LesabreT.com - Page 7 IMGP4892
Next it gets mounted into the mill to square it off. This is where it will end up cleaner looking than the first one made:
My L67 swap from LesabreT.com - Page 7 IMGP4893
Various turning around for each side. Only the first two sides were done with the end of the mill, the other two were run lengthwise.
My L67 swap from LesabreT.com - Page 7 IMGP4894
And done:
My L67 swap from LesabreT.com - Page 7 IMGP4895
Next the holes were put in and counter-sunk. Also a radius was put along the top edges. No pic of this process, but involves working from center of the part and running a circle function in the digital readout that finds the location of holes a certain radius from center.
Bolted on:
My L67 swap from LesabreT.com - Page 7 IMGP4896
Next the horiz holes were drilled to match out with inlet and outlet. You can see the return hole with relief space milled for air flow around the bits inside.:
My L67 swap from LesabreT.com - Page 7 IMGP4897
Inlet and outlet holes are tapped 1/8 NPT:
My L67 swap from LesabreT.com - Page 7 IMGP4898
Here is the whole arrangement under the prototype. Andrew, you can use smaller wall joining vacuum tube than I did. Just cut it a little small, slide it on the nub, add the spring, and push the whole assembly onto the PCV valve. Test fit without the spring first. Use a thin layer of rtv between the surfaces. Follow the directions of just tightening till the RTV oozes, wait 20 min, and then give teh screws another 1/4 turn. Be careful as Delrin can dent. It only needs to be snug. If you have any questions or its not clear, fire me a message.
My L67 swap from LesabreT.com - Page 7 IMGP4899
And on the SC. No barbs are threaded in in this pic. They go left and right, and orientation can be turned around whichever way you want. The outlet side is marked with a small scratch:
My L67 swap from LesabreT.com - Page 7 IMGP4900
Finished SC ready to ship:
My L67 swap from LesabreT.com - Page 7 IMGP4901
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyTue Apr 24, 2012 12:35 am
PERFECT......Andrew !-how you people do it?.,....
Merit : 63
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyTue Apr 24, 2012 10:55 pm
Wow! i think I changed my mind about the new bolts - they look awesome! I'm sure they look even better in person too!
Excellent EXCELLENT work, my friend. Maybe I'm over-excited, but this is one of the coolest things I've ever been a part of! I've said it a dozen times before, but I can't thank you enough!
To everyone else, installation pictures and vids coming in a week or two!
Merit : 63
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyMon Apr 30, 2012 9:28 pm
Got a present today, from Karma Customs:
My L67 swap from LesabreT.com - Page 7 MaroonT455
Woohoo!! I'm psyched to get this thing running! I have to get supercharger oil for it, then it'll be ready to install. Probably doing that in the morning, then Dad wants to help put it on tomorrow evening lol. Won't be driving it, but we will fire it up and check everything.
Some pics:
Probably the last time we'll see this thing out in the open. It's a beautiful thing, and a serious piece of engineering.
My L67 swap from LesabreT.com - Page 7 MaroonT456
Comparison - stock M62 on the right, ported M62 on the left.
My L67 swap from LesabreT.com - Page 7 MaroonT457
Reeeeeeeeeeally nice angles and edges as illustrated by Andrew in his previous post earlier in the month.
My L67 swap from LesabreT.com - Page 7 MaroonT458
My L67 swap from LesabreT.com - Page 7 MaroonT459
Stay tuned, hopefully construction concludes tomorrow.
Merit : 123
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyTue May 01, 2012 2:03 pm
Lemme know how/if those TB bolts I sent work. I wasn't sure if the sholders on them were too long or not.
.. How was the packing condition when it arrived? I tried to pack it as bulletproof as possible.
Merit : 63
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyTue May 01, 2012 10:53 pm
Andrew- the throttle body bolts didn't work out too well, and didn't look quite right, so i nixed them. Thanks though! I appreciate! And the package arrived great...no issues with it, nothing seemed damaged or out of place.
Alright guys, everything got back together, but there's a problem. Rocker noises GALORE. The car started right up though, has great vacuum, no visual or aural problems besides what sounds like the rockers. This video here is the first startup after re-assembly. It's hard to hear the noises exactly, but the sound that sounds like a lot of static-y air is what sounds like every rocker/pushrod on the engine.
My L67 swap from LesabreT.com - Page 7 Th_20120501_222052
When I installed the rockers I noticed that there was a bit of back and forth play on some of them even when torque down, like whenever both valves would be closed on a certain cylinder. The pushrods would have a bit of play. After cranking the engine a few times when I first installed them, it seemed like they tightened up some but not all of them, and not consistently.
What concerns me is the Yella Terra mounting plate...it doesnt have guides for the pushrods to be right on center with the rockers. I ran the car for two minutes, twice, and the noise never quieted down.
Has this happened to anyone before? Could my pushrods be too short somehow? I didn't think that was a factor with the '94-'95 engines...
EDIT: Here is a video of someone else's 3800, doing exactly what I experienced when I installed them.
https://www.youtube.com/watch?v=2MyfPHWNyno
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyTue May 01, 2012 11:13 pm
Crazy man,just crazy!
Merit : 123
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyWed May 02, 2012 12:16 am
Yeah, they should all be right tight. A collapsed lifter could give them that movement and noise. Quickest way to check that for you might be to swap on the stock rockers, if the noise is still there you know a lifter is collapsed. If not, well you know to dink around with the YT rockers some more.
Did you make sure that the pedestals all fit properly into the guide plates? The tolerances aren't great on the YT guide plate and I found I had to swap the pedestals around a bunch to have them sitting right seated. Some pedestals fit too tight, others looser. Make sure they are all right flush. I'd check that out first. Also be sure the flat bits on the rocker barrels are up. They can rotate all the way around. ... also you put the guild plates the right way around right? You should be able to read Yella Terra right side up and facing you on each side.
(I also just checked the part number on yours vs mine, just in case Intense sent you the S2 ones. But you are all good in that regard.)
Merit : 63
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyWed May 02, 2012 12:25 am
I came across two cases on the PontiacBonnevilleClub.com forum that were just like this, neither with conclusions so far.
I think it has something to do with the lifters but on ALL 12 rockers? In person it's easier to hear, but it sounds like all 12 pushrods are making noise against the rockers. I just think since the engine has been sitting for so long (4 months) the lifters might not have pumped up yet. But anyway, yes all the pedestals eventually fit into one hole or another, after messing with them. The flat parts are all facing upward.
I'm going to take the front off tomorrow and see if there's anything obvious going on, and maybe swap on the old rockers. Any other advice Karma? I'm going to be hugely disappointed if I can't use these things.
Merit : 123
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyWed May 02, 2012 9:31 am
The swap to the old ones would be the surefire way to rule in or out the new rockers as the issue. The same noise with the old ones would point directly to the lifters.
Other thing you can try is run it with the VCs off and be sure that you are getting proper oiling form each pushrod, and have proper rocker movement. That will also help locate if the noise is right at each rocker or deeper.
There should be no reason you can't use the new rockers. You just need to find out whats up.
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyWed May 02, 2012 12:52 pm
I dimly recall having to shim the camshaft mounts or some darn thing to get rockers to set right without clacking like maracas... but it was LONG ago and far away. Please consider that you may need to fab shims (for the mounts)? maybe?
Merit : 63
PostSubject: Re: My L67 swap from LesabreT.com   My L67 swap from LesabreT.com - Page 7 EmptyWed May 02, 2012 1:17 pm
Well friends, I swapped the old rockers back on (only took me an hour, woohoo!) and there's zero noise whatsoever now. Before I took the Yella Terras off, though, I checked for play and torque. There was a very minute amount of play on some of them (I assume ones with valves that were closed for the moment) and torque didnt change. Still 25-26 ftlbs. I don't get it. The car starts and idles like the champ it's always been right now with the old rockers. And yes, I used the Yella Terra bolts.
No noise coming from the lifters that I can decipher, so I would assume they're all good for now. Pushrods must be the problem.
Albert - I wonder if that would apply as much to my Series I as it does to the Series II? Do you mean the rocker mounts perhaps? If anything they would need shaved down a hair. maybe I misunderstood razz .
Thoughts?
Page 7 of 13Go to page : Previous  1, 2, 3 ... 6, 7, 8 ... 11, 12, 13  Next
» 96 to 97 PCM swap?
» PCM swap
» I think I might actually go with my M62 instead of an M90 top swap
» ls4 engine swap?
» Write-Up: L32 (Series III SC) Install/swap, the saga continues
