jbeganny Enthusiast
Name : John Beganny Location : Litchfield, Maine Joined : 2011-09-05 Post Count : 120 Merit : 2
| Subject: adjusting trunk hinges Sun Mar 11, 2012 7:37 pm | |
| I attempted to adjust my trunk hinges to tighten up the trunk lid a bit but the little adjusting nuts would not move and I didn't want to break them so I stopped. It's a 95 and had the factory paint still in tact. What now?? How do I turn those without breaking something? Should I put a vise grip on the shaft ? And which way do I turn them to tighten the trunk lid? | |
jbeganny Enthusiast
| Subject: no help?? Wed Mar 14, 2012 11:19 pm | |
| I posted this the other day looking for help with it but it has no responses. I do not want to break the trunk hinges and I am not even sure I am doing it correctly. Won't someone help? | |
| Subject: Re: adjusting trunk hinges Thu Mar 15, 2012 12:50 am | |
| what shaft? from what I can tell is that you have to turn the rubber bumpers at the front of the trunk to tighten the lid against the body. | |
gmann3001 Fanatic
Name : Glenn W. Peck Age : 50 Location : Orland Park, IL. Joined : 2011-11-16 Post Count : 389 Merit : 9
| Subject: Re: adjusting trunk hinges Thu Mar 15, 2012 2:28 am | |
| Also are the lift strut supports ok? | |
| Subject: Re: adjusting trunk hinges Thu Mar 15, 2012 8:58 am | |
| Are you talking about the adjustments on the hinges up by the rear window? I adjusted mine and it wasn't hard to break the adjusting nuts loose. | |
jbeganny Enthusiast
| Subject: Re: adjusting trunk hinges Thu Mar 15, 2012 10:09 pm | |
| - deekster_caddy wrote:
- Are you talking about the adjustments on the hinges up by the rear window? I adjusted mine and it wasn't hard to break the adjusting nuts loose.
Yes, the adjustments on the hinges. Did you just crank on the nuts to break them loose? It feels like I am going to break mine. | |
| Subject: Re: adjusting trunk hinges Fri Mar 16, 2012 9:03 am | |
Yes, the adjustments on the hinges. Did you just crank on the nuts to break them loose? It feels like I am going to break mine. I don't have it in front of me, but I will see the car tomorrow and review it. I think that's all I did. If I can I'll post a pic or short video. | |
| Subject: Re: adjusting trunk hinges | |
