There are a ton of grounds on the Riviera. You would not believe the wacky problems you can get from a bad ground. If there are any leaks into the interior of the car, I would look at the areas that are wet for corrosion, and a bad ground.
98 Riviera SC3800 All stock except gutted air box.
