 white smoke at start up..
3 posters
hecc
white smoke at start up.. Empty
PostSubject: white smoke at start up..   white smoke at start up.. EmptyMon Aug 13, 2012 1:58 pm
when my 95 riviera sc is cold white smoke comes from tail pipe for aboutv5-6 secs then goes away,what is causing this white smoke on cold start up,it doesnt do it once car is warm please help..
PostSubject: Re: white smoke at start up..   white smoke at start up.. EmptyMon Aug 13, 2012 2:41 pm
If it's a light blue grey smoke, it's probably a small amount of oil being burned when you start up. If you have high miles on the engine, this is a sign of wear, but doesn't effect the overall operation. As long as it isn't happening when warmed up, I wouldn't worry about it. You may notice a small decrease in oil level between changes. Only way to fix is to rebuild the engine.
If it's really white, all engines emit some steam for a few minutes when it's humid or cold out. Perfectly normal.
mike97
PostSubject: re. white smoke at start up;   white smoke at start up.. EmptyMon Sep 24, 2012 2:08 pm
Have someone start your car while you smell the first exhaust fumes. (note- keep it under an hour or till faint)
If it smells sweet you probably have a leaking intake manifold gasket, a very common issue.
not big trouble unless cylinder fills with coolant.
I would check all spark plugs for signs of fouling, one or two more than others.
other symptoms are, loss of cabin heat,
frequent replenishing small amounts of coolant ,
slightly higher temps or over heating,
or the inability to purge air from cooling system.
gaskets aren't tough repairs just time consuming .
the amount and time of smoking indicates severity of any leaking.
if any leaking is indicated it should be addressed ASAP.
» white smoke / Need stock compression ratio
» Car will not drive white smoke from behind engine and exhust
» blue smoke from exhaust from 96 Riviera
» a little wiring prob also with noise and smoke
» 97 riv..with slight smoke coming frome front of engine
