| Write-Up: Installing a Front Strut Tower Brace (STB) | |
+74Yardley joshuadalegrimes matt270avian Randy T. al_roethlisberger artlock llamalor2112 Mattwa drdivo nothincame2mind Riviera Randy ZEP rk0ehn gmann3001 charlieRobinson RivieraParadise flyingjunebugs bigdave RidzRiv BlownRiv crlombardi69 Derek J. Chris Davis VJD2 Abaddon 98inSFl duckstu 97 park ave DEMonte1997 LARRY70GS L67 nigelf Ash eagleblanks13 97rivsc ewolfe0050 EASHER Rickw 96RIVMANN SuperRiv07 Steve98 Chicken Karma lyonsperformance dreww 98riv 98RIV7777 rascal5478 ibmoses albertj robotennis61 Kustom Kreationz robertwolf86 rivparadise Joey98riv BillBoost37 oldsman105 deekster_caddy TonySmooth89 ender467 Buapo Jack the R 54_nailhead jimmyriv SpaceBar turtleman racinfan T Riley 99Rivman Mr.Riviera 1998 Riv AA jax95riv Jason 78 posters |
ibmoses Aficionado
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Sun Jun 08, 2008 3:33 pm | |
| - 98riv wrote:
- Try bending the mounting tabs so that you don't have to use as many washers.
With the bar just barely clearing the master cylinder I have hood bulge(see pic). Not sure but it seems like the master cylinder in this car is a fuzz higher than normal? Bert | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Mon Jun 09, 2008 1:26 pm | |
| You need to even out your spacers. You shouldn't have to make it that high on one side. Lower it back down a little and try to have equal spacing on both sides. Mine has less than 1/8 clearance to the mas. cyl. and I have no hood bulge at all. No contact to the hood whatsoever. | |
dreww Junkie
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Jun 17, 2008 1:10 am | |
| I only put one washer on each bolt (could maybe have gotten away with none). I used a sander and sanded ALOT off the top of the master cylinder - especially where the STB crosses over. Like so much, I almost cut all the way into it. Maybe 1 to 2mm of plastic left. I had to drill out the bolt holes on the STB. Put my dewalt to the test. My rubber mallet came in handy too. | |
lyonsperformance Enthusiast
Name : Michael Age : 40 Location : Buffalo N.Y. Joined : 2008-08-02 Post Count : 178 Merit : 0
| Subject: Strut tower brace Tue Aug 05, 2008 8:19 am | |
| Looking for a strut tower brace, checked ZZP, and Intense, will a tower brace for a GTP, fit a 96 Rivi? car handles well but stock suspension is a little on the soft side as you already know, i will be installing KYB shocks and struts, i would like to limit as much body roll as possible. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Aug 05, 2008 9:20 am | |
| No stb made specifically for the Rivs. However, a late model Caddy STS stb is almost a direct bolt on. Lots of guys here use it. W-body will not fit. | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Aug 05, 2008 4:49 pm | |
| what year is your car? Put some info in your sig. please. | |
Karma Aficionado
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Mon Aug 18, 2008 11:17 am | |
| here are some pics of my custom strut tower brace. I thought I'd better post them instead of having them just sitting around on my computer. I'm begining to find that either the series I engine sits a bit higher than the 2, or maybe sits farther back in the engine bay. All the pics I saw of others(all series 2) and how they used the STS STB seemed to have way more room at their disposal, as well as Eric's custom one. So i figured I was better off making one from scratch: The ends I had actually made almost 5 months ago, but then had no time to finish. I made rough blanks out of cardboard to figure the shape I wanted, made sure that the bolts were indeed square with the car(they are!), and then cut the shape from some steel plate I had around. And below we can see the clearance of the break res.: The thing is VERY stiff, the one ton press wouldent make the slight bends I needed so I used the ten ton. The angle needed was measured(something like 4 deg if i recall correctly), and then both ends were made to match. Dunno if it really makes a big difference, seems to roll less in the front... but its hard to tell with my rear shocks falling apart.(but not to worry, Ranchos are on order!) _________________ | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Mon Aug 18, 2008 12:39 pm | |
| You're gonna love those Ranchos Be sure to make an STB for the rear so it can handle them! | |
Chicken Aficionado
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Mon Aug 18, 2008 1:14 pm | |
| Anyone know if his 95 STB is compatible with the 96? | |
Karma Aficionado
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Mon Aug 18, 2008 1:32 pm | |
| I could check if there was a 96+ riv in the area... well there is, but i dunno what the "old dears" would think of , "hey, i just want to try something out on your engine..." from a stranger.... _________________ | |
Chicken Aficionado
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Mon Aug 18, 2008 2:12 pm | |
| you still have the template? | |
Chicken Aficionado
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Mon Aug 18, 2008 2:35 pm | |
| ...man this is crazy.....
I work for one of the largest machine shops in the country....I should see if I can make one here.... | |
Steve98 Member
Name : Steve Location : Atlanta, Georgia Joined : 2008-06-10 Post Count : 93 Merit : 2
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 3:42 pm | |
| I installed this brace over the weekend. I have a 98, so the holes matched up with the bolts. I had major clearance issues, though, and had to use 8 washers all around. I've got a slight bulge in my hood now, which I don't like. I love how much better my Riv drives, though. It corners better and just feels more solid in general. This is a great mod and I agree that the brace should have been stock. I want to brace the rear strut towers, too. | |
ibmoses Aficionado
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 4:45 pm | |
| Thats the same problem I had with the wifes 99. Big stacks of washers, slight hood bulge and still just barely clearing the master cylinder. Bert - Steve98 wrote:
- I installed this brace over the weekend. I have a 98, so the holes matched up with the bolts. I had major clearance issues, though, and had to use 8 washers all around. I've got a slight bulge in my hood now, which I don't like. I love how much better my Riv drives, though. It corners better and just feels more solid in general. This is a great mod and I agree that the brace should have been stock. I want to brace the rear strut towers, too.
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 4:57 pm | |
| Interesting. I wonder why some have clearance issues and some do not... | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 5:02 pm | |
| I think it's the bars more than anything. Make sure those bars are straight...
Mine was bent when it arrived. Even a slight curve will throw off the alignment. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Karma Aficionado
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 5:19 pm | |
| I'd offer to make custom ones, but it sure wouldn't be cheaper than getting the STS one... _________________ | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 8:06 pm | |
| - Karma wrote:
- I'd offer to make custom ones, but it sure wouldn't be cheaper than getting the STS one...
I wouldn't mind having better ones with no clearance issues. I've got other $ priorities at the moment though, but I bet I'm not the only potential buyer. | |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 8:27 pm | |
| I want one? I really dont want to buy this caddilac one and it dont work and I strecth it to work and while doing that i weaken it | |
T Riley Guru
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 8:30 pm | |
| - SuperRiv07 wrote:
- I want one? I really dont want to buy this caddilac one and it dont work and I strecth it to work and while doing that i weaken it
mine worked perfect not to brag or nothin | |
SuperRiv07 Addict
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 8:32 pm | |
| yeah but I read all the pages and they seemed to work on 98's with no problem but seem not to line up on earlier models and I have a 96 | |
T Riley Guru
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 8:33 pm | |
| - SuperRiv07 wrote:
- yeah but I read all the pages and they seemed to work on 98's with no problem but seem not to line up on earlier models and I have a 96
modify it...... thats what ewolf did..... he basically custom made one! | |
SuperRiv07 Addict
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 8:34 pm | |
| Yeah I dont have anything to do that with and I dont have a garage to work in at the moment? What kind do you use in the rear? | |
Karma Aficionado
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 8:35 pm | |
| ewolf did custom make one, did he not? It was similar to the one I custom made, but mine had a bit more material in around the strut tower... _________________ | |
T Riley Guru
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) Tue Oct 07, 2008 8:37 pm | |
| - SuperRiv07 wrote:
- Yeah I dont have anything to do that with and I dont have a garage to work in at the moment? What kind do you use in the rear?
i have a sub box so i chose NOT to make a rear one | |
| Subject: Re: Write-Up: Installing a Front Strut Tower Brace (STB) | |
