 Write-Up: Installing a Front Strut Tower Brace (STB)
Yardley
Randy T.
artlock
Mattwa
drdivo
Riviera Randy
rk0ehn
gmann3001
RivieraParadise
flyingjunebugs
BlownRiv
crlombardi69
Derek
VJD2
98inSFl
duckstu
97 park ave
nigelf
Ash
eagleblanks13
97rivsc
EASHER
96RIVMANN
Steve98
lyonsperformance
98RIV7777
rascal5478
Kustom Kreationz
robertwolf86
Joey98riv
BillBoost37
ender467
54_nailhead
78 posters
Go to page : Previous  1 ... 6 ... 9, 10, 11 ... 18 ... 26  Next
Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 Empty
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyTue Oct 07, 2008 8:38 pm
Bend it so it fits, or make your own if you can weld.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyTue Oct 07, 2008 8:41 pm
And Its just the caddilac sts stb?
http://www.Chitownracing.com
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyTue Oct 07, 2008 8:42 pm
yes SIR! 98 STS in your case dude
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyTue Oct 07, 2008 9:01 pm
I think it's the bars more than anything. Make sure those bars are straight...
Mine was bent when it arrived. Even a slight curve will throw off the alignment.
I have NO doubt that the bars are anything BUT identical after cutting pipe, welding on brackets... I'm tempted to put a slight bend in my bar and do away with the washers (2 at each bolt). However, I seriously doubt the 2 washers have any negative effect on the bar's performance. What is really tempting is to take the bar into our shop at work, and have them cut and weld a spacer on the bottom of each bracket.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyTue Oct 07, 2008 10:29 pm
And I can only order this at gmpartsdirect?
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyTue Oct 07, 2008 10:32 pm
Any GM dealer can order the number for you.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyTue Oct 07, 2008 10:35 pm
And its the part number givin on like page one? and should I buy 2 or is the rear something else?
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyTue Oct 07, 2008 10:45 pm
There is no rear that I know of. I think somebody in here made their own. The part number for the front is in the first post, on the first page, in big bold numbers.
96RIVMANN
96RIVMANN
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyWed Dec 03, 2008 9:31 pm
Here is my strut tower brace that I finally got around to buying and installing. I milled a slot in a piece of 6X4 aluminum with a 1 inch ball end mill so that I could take a piece of 8 inch round aluminum to put the dent in the bar with a hydro press. The milled slot held the bar perfectly while being pressed. As you can see I welded up the sloted hole in the front and added some material so that I could re-drill for the stud. I don't need any spacers under the mounts and it sits perfecly with about 1/8 inch clearance above the brake fluid housing. Image hosted by servimg.com Image hosted by servimg.com Image hosted by servimg.com
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyWed Dec 03, 2008 9:51 pm
I finally got a hold of some paperwork that shows the underhood dimensions for these Riv's. Used by body shops for straightening and such.
The diagrams show the dimensions from strut tower to tower as well as triangulating all underhood dimensions and.....The 1995-97 has one set of spec's and the 98-99 are totally different.
This would explain to some degree why people have more trouble with the earlier cars than the later ones. The bar I bought bolted right up without having to ream the holes at all. Just raised the whole thing up with spacers about 1/8" to clear the master cylinder.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyWed Dec 03, 2008 11:54 pm
96RIVMANN - That looks real good.
Rickw - Thanks for digging up that info. It's good to know there's an explanation.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 12:00 am
NICE bar! MN reppin it up!
EASHER
EASHER
Name : ERIK M. ASHER
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 8:03 am
I just installed my front STB yesterday. All i did was get some longer bolts and use a couple of washers to get the clearance i needed without having to bend the tabs or mess with the holes. It worked fine and made a big difference in the feel of the car when cornering. I think for the rear brace, I will order the same bar as for the front and have the bar welded in place.
http://snardfarker.ning.com/profile/ERIKMASHER
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 2:31 pm
I'm more and more impressed with the difference these bars make. My Riv is really feeling like a nice car these days. I've got to drive like a maniac to make it roll. Most of the time, even when pushing it, it doesn't or it's very little. It's already more than I need and I haven't done sway bars or sticky tires yet.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 2:41 pm
Jack, that's largely why I decided not to do the heavier sway bars. The STB alone, with new KYB's, is sufficient for my driving habits.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 2:54 pm
Jack or Dave,
Did you all do the rear also ? If so, how much of a difference did that make in your opinion(s).
I've only done the front so far and have noticed an improvement.
96RIVMANN
96RIVMANN
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 9:47 pm
Jack did a write up about the rear brace! SEARCH engine is your friend.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 9:55 pm
I tried the Search And It Is Not MY Friend !!!!!!
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 10:11 pm
I have STB on both the front and the rear. the front was initially the Caddy bar but I decided to fab one up because of fitment issues... I did not like having several washers underneath the bar and it still rubbed the brake reservoir. I also wanted a much stronger bar considering the weight of our cars. When I put the rear bar on it made a noticable difference. The tail seemed more planted especially around bumpy curves and it made the feel of the car much more quick and responsive... almost twitchy but in a good way.
Front...
Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 P6110311
Rear...
Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 P6110313
Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 P6110314
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 10:21 pm
Also, the doors shut more solidly it seems. Actually it is hard to describe but the entire car seems to be firmed up.
Eric, what thickness is the wall of your rear bar?
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 10:25 pm
I don't recall off hand. They were left over tubes from a ASA car. I can probably find out for you tomorrow. The walls seem to be about 2.5 times the thickness of the Caddy bars at least. I guarantee they will never fail from abuse... The plates front and rear were made from 1/4".
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 10:52 pm
okay, not a big deal. I'm sure it doesn't take much. Nice work!
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Write-Up: Installing a Front Strut Tower Brace (STB) - Page 10 EmptyThu Dec 04, 2008 11:01 pm
1998 Riv - I hear ya. I'm a dumb fuck though and I'll eventually do sway bars just because I like building the car. It doesn't matter if the car ends up having 10X more capability than I use.
Rickw - https://rivperformance.editboard.com/brakes-suspension-f6/write-up-installing-a-rear-strut-tower-brace-t3131.htm
Keep in mind ewolfe and I have Rancho shocks. The Ranchos are more than the stock Riv chassis can handle. With the rear STB though the Riv can use them and the back handles surprisingly well. The change in handling dynamics from a rancho setting of 1, with no STB; to a setting of 6 with STB will make your eyes pop open. With the two STB's and Ranchos the Riv is a different car.
ewolfe0050 - Please find out what the thickness is. I like your design better and it looks like less work than modding the STS brace + it has a cleaner appearance. Can you find out the overall diameter of the bar as well?
What were the ends of the tubes flattened down with?
On the front are the end plates carved out of a square plate or were they round to begin with? That's the only part that looks hard to do.
Page 10 of 26Go to page : Previous  1 ... 6 ... 9, 10, 11 ... 18 ... 26  Next
» Write-Up: Installing a Rear Strut Tower Brace
» 2008 Lucerne Strut Tower Brace
» Write-Up: Installing KYB GR-2 Struts
» KYB front struts for ’97 ???
» Write-Up: Installing Intercooler (IC)
