Name : Mike Arthur Age : 71 Location : Muscle Shoals Alabama Joined : 2021-08-09Post Count : 8 Merit : 0
Subject: SUPERCHARGER OIL CHANGE Fri Aug 13, 2021 11:01 am
I was told that I should keep up with the oil in my supercharger. Being new to this piece of equipment, I've been studying up on it. I got my turkey baster,empty spray bottle,and 2 bottles of GM Supercharger oil from a company called "ZZPROFORMANCE. I followed all the steps for extracting the old oil, which was veey black and smelly. I had less than 3 ozs when it was completely empty (very low on oil,i guess) But,to my surprise, the new oil was clear, almost like machine oil. Is this correct? I don't want to mess up my Supercharger. Any help would be greatly appreciated.
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8606 Merit : 180
Subject: Re: SUPERCHARGER OIL CHANGE Fri Aug 13, 2021 11:44 am
Yes, the old oil stinks. Reeeeeeeally stinks.
ZZPerformance is great, just use that oil to fill your SC. Park on level surface, fill to the bottom of the SC oil bung opening.
My guess is your SC snout weeps/leaks oil.
mrdronenut likes this post
knoxbroadcaster Member
Name : Charles Location : Knoxville Tennessee Joined : 2018-07-26Post Count : 50 Merit : 0
Subject: Re: SUPERCHARGER OIL CHANGE Sat Aug 14, 2021 3:56 pm
I'm replacing my lower intake manifold gasket soon. The supercharger will be off the car. can I tip or turn over the supercharger to drain the oil? Thanks
Name : Rick Location : Lancaster, MA Joined : 2008-09-13Post Count : 6282 Merit : 119
Subject: Re: SUPERCHARGER OIL CHANGE Sat Aug 14, 2021 10:39 pm
Yes you can turn the SC upside down to drain it. Have done it before. Prepare for the stank of the oil.
Subject: Re: SUPERCHARGER OIL CHANGE Sun Aug 15, 2021 8:09 am
Just an FYI: The supercharger oil is a special oil with a very long (for this car's purposes, indefinite) service life. There are other posts about that on this site. Main reason to "change" the oil is to get rid of accumulated grit, of which there will not be much. I forget the reason why the oil becomes so stinky with age.
Some people with Series I superchargers use 5w-30 Mobil 1. It works but **really** needs to be topped/changed regularly as it is a somewhat lower spec than the special supercharger "whale oil" (it's not really whale oil). The nice thing is since you can fill the engine sump with 4 1/2 quarts of the stuff, the last 1/2 quart in that 5 quart bottle is more than enough for that top-off, usually.
