 Door unlock problems/new fob pairing failure
3 posters
BuickRivieraGeorgia
BuickRivieraGeorgia
Door unlock problems/new fob pairing failure Empty
PostSubject: Door unlock problems/new fob pairing failure   Door unlock problems/new fob pairing failure EmptySat May 27, 2023 10:58 am
Hi,
I was trying to program a new fob and jumped 4&8 pins couple of time and I accidentally touched the 16th too, so 16,8&4… the pin turned red and i got it off in like a second or two… the pins do look burnt but the car started up fine
As a result, when i press the unlock button on the door panel - it only unlocks the driver’s side, the passenger side is unresponsive…
Also my old fob doesn’t work anymore and the new one did not get paired either… can’t leave the car for too long, as it’s unlocked, please advise
How much damage could I have caused? And how would I go about finding the problem?
PS
The fob couldn’t get paired cause after i jumped 4&8, doors get unlocked, when I close the doors and turn the ignition - it doesnt lock the doors, it stays unlocked, no reaction after i turn the ignition on… any ideas?
PostSubject: Re: Door unlock problems/new fob pairing failure   Door unlock problems/new fob pairing failure EmptyMon May 29, 2023 3:04 am
FWIW I've found it takes two button pushes to unlock the passenger side door. The first only does the driver side door.
BuickRivieraGeorgia
BuickRivieraGeorgia
PostSubject: Re: Door unlock problems/new fob pairing failure   Door unlock problems/new fob pairing failure EmptyMon May 29, 2023 4:01 am
It doesn’t open no mater how many times I press it… I might have burnt a fuse or something…
But I really need to figure out the pairing issue
Merit : 180
PostSubject: Re: Door unlock problems/new fob pairing failure   Door unlock problems/new fob pairing failure EmptyMon May 29, 2023 9:49 pm
1) If you think you burned a fuse then you need to find and fix it. Do you know where the fuse panels are?
2) The car's response to a fob is somewhat programmable. You may want to get an owners manual and check the settings for your working fob. As for the nonworking one check the batteries.
» FAQ: Power Door Lock Problems
» FAQ: Fuel Door Release Problems
» Polished SS door handle cover to hide door panel seam separation
» MAP failure
» Power trunk failure
