Saliboat, can you post some pics of your brake caliper configuration?
I'll try and get some pics up at soon as possible but I just recently bruised my ribs while grappling so it's very painful to turn wrenches. I'll see what I can do
96_Juggernaut Fanatic
Name : Todd Balestrini Age : 41 Location : Beaufort S.C. Joined : 2013-07-08Post Count : 293 Merit : 5
Subject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement Sat Nov 02, 2013 2:10 pm
Longer than expected but while doing the swaybar end links I had the opportunity to snap a pic of my caliper config, ( Yes im the same person as SC_Sailboat ) here it is. im pretty sure this pic explains what I was talking about:
Subject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement Sat Nov 02, 2013 2:20 pm
Todd: username SC_Sailboat will be deactivated. Please post under Juggernaut from now on. Thx.
Subject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement Sat Nov 02, 2013 2:28 pm
Thanks!
llamalor2112 Junkie
Name : Evan Age : 31 Location : Granite Falls, WA Joined : 2012-07-13Post Count : 852 Merit : 13
Subject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement Sat Jan 18, 2014 4:32 am
Anyone confirm this for the 95s?
Was hopefully aiming to get at this today...but if this is the case I need to find some hex wrenches and a t55 wrench....
Subject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement Sat Jan 18, 2014 3:26 pm
The vid is standard procedure for changing the hub (in a perfect world, at least). Or, just see page one of this thread for a Riv-specific write-up. Some years have the Allen hex head screw for caliper brackets, later years have a regular hex head.
Every mechanic works a bit differently. I personally don't like using cheater bars and pipes as a first line of action for smaller bolts like the 3 on the hub. If you have an impact wrench, start at low setting and work up. You'll notice the video shows everything going as expected, except for the hub separation. Your situation will likely contain a few bumps along the way. The axle usually WILL NOT tap out that easily. Our write-up mentions a few of these situations and how to deal with them.
Finally, I had to laugh when they put new brakes on one side. Typical mechanics' way to make a buck. Pads and rotors should always be replaced in pairs, but hubs needn't be done in the same way. They may have done the other side, but they make no note about doing so. Either way, they made an extra dollar from their customer - unnecessary brake job, or unnecessary hub job.
llamalor2112 Junkie
Subject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement Sat Jan 18, 2014 7:44 pm
I'm without air tools/impact wrenches and the like so I welcomed my pvc cheater pipe haha Performed operation exactly like video save for new brakes of course. Hub came out in one piece and drifted out surprisingly easy. Simple job all in all. Definitely glad to have the experience and a fresh hub
Subject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement Sat Jan 18, 2014 9:23 pm
Congrats! Glad to hear things worked out. Your location probably helped a lot. In the snow belt, corrosion can sometimes make parts seize and fasteners a job to remove. I've broken my share of bolts (and tools) using long handled wrenches. An air or electric impact can be a big help when things get stuck on real good. Hope your new hub holds up for many thousands of miles!
llamalor2112 Junkie
Subject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement Sat Jan 18, 2014 10:50 pm
Oh my yes. The Riv was a Valencia, Ca car and the two Reattas are from Florida and Seattle so no real salt impact to any of them thank goodness. Here's lookin at another 100k at least! haha
matt270avian Expert
Name : Matt Age : 28 Location : Frederick, MD Joined : 2012-01-15Post Count : 2681 Merit : 54
Lmck3 Amateur
Name : Lance Mckinley Location : ft lauderdale Joined : 2013-10-03Post Count : 47 Merit : 8
Subject: dust shield rubs on brake disk Sun Apr 26, 2015 4:39 pm
after driving in a dramatic fort lauderdale thunderstorm, the in-dash ABS lamp in dash illuminated. this 95 riv set a dtc code suggesting RIGHT FRONT "wheel speed sensor erratic or missing". probably water, or maybe sand managed to get into the sensor/toothed-ring assembly
rock auto shipped a Raybestos hub bearing assembly with ABS sender integral. while removing the old bearing, the OEM unit broke into 2 pieces and left the speed counting assembly in the knucle.
this hub was disassembled 3 weeks ago and sat undisturbed while i was in Belize. after actually living in a brothrel and remaining inebriated for a couple of weeks, i managed to forget which way this RIGHT brake dust-shield gets re-installed.
so, yesterday it carefully went back together as per the factory repair manual. here is the scan:
should the dust shield be held on by the torx bolt heads as per the drawing in the book ? .or. should the dust shield be squeezed between the steering knuckle and the bearing housing ?
i'm hoping somebody can examine a correctly assembled Riviera and provide the answer.
[ note: my dust shield was not abused during disassembly. it is not bent or damaged. this is a southern car and there is no corrosion or scuffing to the painted tin ]
my choices are to bend the dust shield .or. to disassemble and move the dust shield .3inch inboard, "behind" the bearing =.
thanks to the community in advance.
matt270avian Expert
The dust shield goes between the bearing and the knuckle IIRC. Depending on how badly it rubs and how lazy you are, you could probably just bend it out of the way.
Are you sure you didn't put it on upside down?
Lmck3 Amateur
in the nicest way, i will respond to the above reply while attempting to .not. flame.
1. i asked the community to be the definitive authority re where the dust shields live. [ the factory manuals do sometimes include rare mistakes ] 2. my dust shield was thoughtfully re-installed as per the illustration in the GM Service Manual. 3. matt270avian suggested the dust shields reside between the bearing assy and the steering knuckle .and. 4. matt270avian wondered if i "put it on upside down?" 5. matt270avian posited that, depending on how lazy i am, the dust shield could simply get reshaped by bending
reply: this 1995 riv has been pampered in every way i am not lazy even before this car was assembled in 1995 at Lake Orion, i held ASE Master Status Certification therefore, it's not likely this dust shield was installed "upside down". because of the clearances re the steering knuckle, the shield cannot be installed upside down or backward. it is shaped like a cereal bowl with holes & slots.
here's something to consider: my riv's left bearing is original, and a photo is attached:
the image indicates the LEFT dust shield is attached OUTSIDE of the bearing casting. i believe we can all agree that generally, GM does the same thing on the left and right sides.
THE QUESTION IS, HAS MY LEFT DUST SHIELD BEEN INCORRECTLY INSTALLED BY A INCOMPETENT DURING THE PAST TWO DECADES ?
so, PERHAPS my RIGHT SIDE dust shield is correctly installed, even though it scrapes lightly on the brake disk. "the world is a very strange place", and i have no explanation...
it would be excellent if a member who has a "positively" correctly-assembled right front hub could verify.
again, this is a great community. my riv is a wonderful car and is more fun than this:
I wasn't trying to be mean or call you lazy or anything. I just know how much of a pain it is to get the hubs out, especially just for the dust shield, and I would probably end up just bending them. When I took the '96 parts out on mine the dust shield was between the knuckle and the hub, and they were original as far as I know. That and the '95/'96 share the same front end as far as we know. Maybe it got bent at some point, so it needs bent back to where it needs to be?
ABerkman Rookie
Name : Ash Joined : 2018-05-12Post Count : 17 Merit : 0
Subject: Getting ready to swap both front hub assemblies... Mon Jun 04, 2018 4:55 pm
Does anyone know off the top of their heads what the OE torque setting is on the front axle nuts for a 96 SC Riv?
jcc3inc Special
Name : Jack C. Cain Joined : 2010-02-21Post Count : 7 Merit : 0
Subject: Re: Write-Up: Spindle / Wheel Bearing / Hub Replacement Tue Jun 05, 2018 8:59 am
Good Morning,
My '97 factory service manual says 107 ft-pounds for the axle nut.
Jack C.
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23Post Count : 2184 Merit : 149
So my driver's side wheel hub is making noise, not too loud, but I know the sound. No ABS light. So I pull it apart because I need to do front brakes as well. Everything goes great. I had bought a Timken bearing as a spare probably 4 years ago. I put the Timken in, get all done, turn the ignition on, and guess what?, ABS and traction ctrl off light on steady. Take the old bearing, and plug it in, ABS and TC light go off. At first, I thought maybe I pinched the wiring, or broke one, but no, everything looks just fine.
I go on Rock Auto, and a new Timken is 76.00. I then look at all the Hub bearings and there is a Power Stop brand, for 26.89, and it has a red heart next to it, which means one of their most popular parts. I say, what the hell, the Timken box says made in China, and I have no doubt that this one is made there as well. I'll take a chance and see. For 33.00 shipped, I bought one. Let's see how long it lasts. Today is July 6, 2021, and I have 201,097 miles. I'll update this thread if and when it fails. If I get a year out of it, I'll be happy. The Power Stop bearing looks good, and feels good turning it. It shut the ABS light off as before I even put it in, I plugged it in. I drive this car nice and easy, no slalom or auto crossing If this bearing is decent, it should last.
