| Write-Up: Installing Boost Gauge | |
+73RidzRiv 1997riv bigdave bmcd9179 stan joshuadalegrimes charlieRobinson Fromano matt270avian Johnny5 al_roethlisberger BKRIV Rod.G ghost88 rk0ehn J. Chris Davis GreenMonster GreenSupreme VJD2 7901mark Snowdog Its a car part now GMFreak8 brmcm15 Hometown Hero L67 Ryan from Ohio LARRY70GS 96Super robotennis61 texasfan010 woggy Rickw Fuzzy rivboy 97rivsc lyonsperformance 1wickedninja SuperRiv07 gliderguy agood1 Karma Chicken deekster_caddy albertj Supercharged blackbart95 99 Riviera 99 IBx1 palermocorey90 mr.19982tone Jack the R 98riv RIVhorsepwr RivMan okiedrifter jimmyriv AA 97rivman RhinoFLA urbsnspices dreww SpaceBar NO 4 EVR Jason TType_Riviera turtleman pwmin jax95riv Mr.Riviera oldsman105 1998 Riv T Riley 77 posters |
T Riley Guru
| Subject: Write-Up: Installing Boost Gauge Thu Feb 08, 2007 9:30 pm | |
| Subject: Re: Write-Up: Installing Boost Gauge Thu Feb 08, 2007 10:33 pm | |
| I haven't done one myself yet, but someone I know has his "T" 'd into a hard plastic line that runs across the rear valve cover. I really like his setup, he has an oil pressure gauge and boost gauge mounted in place of the ash tray. I'll have to post a pic. | |
| Subject: Re: Write-Up: Installing Boost Gauge Thu Feb 08, 2007 10:38 pm | |
T Riley Guru
| Subject: Re: Write-Up: Installing Boost Gauge Thu Feb 08, 2007 10:39 pm | |
| very very nice !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!111 (; | |
oldsman105 Junkie
| Subject: Re: Write-Up: Installing Boost Gauge Fri Feb 09, 2007 1:21 am | |
T Riley Guru
| Subject: Re: Write-Up: Installing Boost Gauge Fri Feb 09, 2007 1:24 am | |
| now im really jealous dud i have no idear how to install a boost gauge will u help me out olds | |
oldsman105 Junkie
| Subject: Re: Write-Up: Installing Boost Gauge Fri Feb 09, 2007 1:29 am | |
| http://www.bonnevilleclub.com/forum/kb.php?mode=article&k=47 this will help | |
T Riley Guru
| Subject: Re: Write-Up: Installing Boost Gauge Fri Feb 09, 2007 1:33 am | |
| dude thanks so much for ur help | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri Feb 09, 2007 3:34 pm | |
| so does that cover close up over the ash tray gauge? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
jax95riv Aficionado
| Subject: Re: Write-Up: Installing Boost Gauge Fri Feb 09, 2007 3:41 pm | |
| Has anyone tried a window post setup? | |
pwmin Enthusiast
Name : Paul Age : 43 Location : Denver, CO Joined : 2007-01-23 Post Count : 131 Merit : 6
| Subject: Re: Write-Up: Installing Boost Gauge Fri Feb 09, 2007 4:27 pm | |
| the cover closed on both setups i had in the same location, but i trimmed a little off of the lip on the cover the second time. havent seen a pillar setup, but i dont like them normally and think it would be even worse in this scenario since it wouldnt keep up w/ the sleeperness of the car. i cant remember which illumination wire i tapped into or how i did it anymore. | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri Feb 09, 2007 4:30 pm | |
| - Mr.Riviera wrote:
- so does that cover close up over the ash tray gauge?
Yeah, I'm sure it closes just fine. | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri Feb 09, 2007 4:31 pm | |
| i believe deekster_caddy (sp) has a pillar gauge setup _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: Installing Boost Gauge Thu Mar 08, 2007 12:04 am | |
| um i went to that site that shows how to put the boost gauge in on the Pontiac and I'm confused as to how you can measure boost using a vacuum path. Are there any ports below the roots on the manifold?
So the best place to run hoses and such through the firewall is through that plastic section near the brake pedal? | |
oldsman105 Junkie
| Subject: Re: Write-Up: Installing Boost Gauge Thu Mar 08, 2007 8:27 am | |
| - turtleman wrote:
- um i went to that site that shows how to put the boost gauge in on the Pontiac and I'm confused as to how you can measure boost using a vacuum path. Are there any ports below the roots on the manifold?
what year is your riviera? No one has made a write up on putting a boost guage into a riviera. The pontisc is basically the same engine (note the eninge in the link is a series 1 L67) . | |
TType_Riviera Fanatic
| Subject: Re: Write-Up: Installing Boost Gauge Thu Mar 08, 2007 5:43 pm | |
| i ran mine thru the rubber piece that the steering shaft runs through an Ted it into the plastic line that runs to the intake under the SC snout! | |
| Subject: Re: Write-Up: Installing Boost Gauge Thu Mar 08, 2007 5:47 pm | |
| the T is the best place to tap into, but as far as going through the firewall IDK. that water shield over the rack and pinion sounds like a good route. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Write-Up: Installing Boost Gauge Thu Mar 08, 2007 9:44 pm | |
| conveniently, theres a plugged port on the top that i am going to connect a vac. gauge i had from my last car to but i certainly do want to get a boost gauge. btw its a 97. This reminds me, Where's the PCV valve? | |
Jason Aficionado
| Subject: Re: Write-Up: Installing Boost Gauge Fri Mar 09, 2007 2:48 pm | |
| how to replace a pcv valve this is where it is also, modify your intake setup so you don't suck in hot air | |
| Subject: Re: Write-Up: Installing Boost Gauge Fri Mar 09, 2007 6:50 pm | |
| oh wow i didn't know it was inside. im not going to tell you what i thought... | |
T Riley Guru
| Subject: Re: Write-Up: Installing Boost Gauge Wed Mar 14, 2007 8:13 pm | |
| [quote="turtleman"] conveniently, theres a plugged port on the top that[quote] i looked at this port today and i couldnt see how to get it off LOL does anyone know if this comes off??quot;turtleman"] conveniently, theres a plugged port on the top that[quote] i looked at this port today and i couldnt see how to get it off LOL does anyone know if this comes off?? | |
| Subject: Re: Write-Up: Installing Boost Gauge Wed Mar 14, 2007 8:22 pm | |
| its stubborn, use a flat screwdriver or something of the like. just be careful not to push laterally too hard on the plug its self because i think its plastic | |
T Riley Guru
| Subject: Re: Write-Up: Installing Boost Gauge Wed Mar 14, 2007 8:28 pm | |
| Subject: Re: Write-Up: Installing Boost Gauge Wed Mar 14, 2007 8:59 pm | |
| - 98riviera98 wrote:
- have u taken it off yet>
if we are talking about the same thing (the vac. plug that's circled in the picture) then yes, that's what I connected my vacuum gauge to | |
| Subject: Re: Write-Up: Installing Boost Gauge | |
